so output to 1-wire counter
Forum about 1-Wire devices.
Kroonen
Post by Kroonen »
Can you just put a S0 output direct to 1-wire counter??
This I want to buy
http://www.eltako.com/dwl/EWZ12E_nl_internet.pdf
I have had a combination of one of those KWh meters connected to a Hobbyboards Dual Counter and it worked ok.
Jfn
Post by Jfn »
You might have to use an resistor in series between the power-supply and the S0+ input of the meter (current limiting), but other than that it should work OK with the Hobby Boards counter (I have been using this setup for some time now and it works fine).
Kroonen
Post by Kroonen »
Is the 32A enough? I have 7 groups and you put it between the master switch and the groups??
What does your main fuse say? 40A? Then 32A is not enough. That's why i chose the 65A version and i put it between the main fuse and the groups.
Kroonen
Post by Kroonen »
I only see 3 fase 65A not with 1 fase, or don't they sell it through internet?
I'm using the Eltako WSZ12E-65A.
Return to “1-Wire Forum”
