Philips Hue Control Script
Alles m.b.t. de Homeseer Philips Hue HS3 Plugin van Willem Eradus (Dutch Forum)
Moderator: Willem4ever
Re: Philips Hue Control Script
Post by Harry »
are there new developments on the heu control? i am still a HS2 user,...what is the best way to go ,.to implement the heu?
bartbakels
Post by bartbakels »
Try Jon00Hue pplugin/app for HS2
regards
bart
(ON ESXI )on NUC
Post by Harry »
Hi Bart
Is there a way t set colors with your script, i have problems to get the JonooHeu plugin to work... you script works perfect.
or if colors is not posible ,...perhaps is calling a assisting scene a way to get colors?
bartbakels
Yes this is possible. by use of sat and hue control by use of the mode device... Not by selecting a color directly. I don't use this now for more than a year. I am running jowihue on HS3 wioch fullfll all my hue needs for the moment.
regards
(ON ESXI )on NUC
Post by Harry »
I still use HS2 so jowiheu,is not an solution for me.
deuang
Post by deuang »
You can easily use HUE plugin for HS3 from here.
http://www.smartercontrol.net/PhilipsHue
Return to “Homeseer Philips Hue - Plugin HS3”
