smile ip adres
smile ip adres
Postby Harry » Sat Apr 23, 2016 12:20 pm
is it possible to give the smile a fixed ip adres?
i get the values from the divice with smilereader and once in a while the software can not find the device couse of the changed ip adres.
i use a wired connection not the Wlan.
Re: smile ip adres
Postby Akatar » Sat Apr 23, 2016 1:38 pm
i'm not sure, but there are routers with a static ip option for dhcp
i used this often
Akatar
Re: smile ip adres
Postby PietjeNL » Sun Apr 24, 2016 1:27 pm
Login on HTML page, by going to the ip address.
Login is smile and the id as password.
Under settings u can disable DHCP and set a static IP address.
PietjeNL
Re: smile ip adres
Postby Harry » Mon Apr 25, 2016 3:31 pm
when i open the html interface i only get the meters . there are now buttens on the button where i can choose "setting"
when i looked it up in the manual there are tree buttons on the buttom of the page.?
can it be that i am connected with LAN and not WLAN ?
when i try it with the app on my Phone the same thing. :(
Re: smile ip adres
Postby Harry » Sun Oct 02, 2016 5:17 pm
i like to upgrade the firmware from the smile, when i use source it gives the massage that there is no update.
the frmw i now use 1.2.14 are there other ways to get the smile upgrade.
trough html i don't have options to upgrade
Re: smile ip adres
Postby PietjeNL » Mon Oct 03, 2016 3:44 pm
Try IP/system/status
PietjeNL
Return to Plugwise Forum
