MQTT - Authentication
nickyb2
Post by nickyb2 »
I'm trying to connect my OTmonitor to a MQTT bus (mosquitto). When i configure mosquitto to use NO AUTHENTICATION it works like a charm, however when i wish to use authentication to message are not sent to mosquitto.
My username/password combination is correct, since when i use mosquitto_pub/sub it all works.
My config for otmonitor:
mqtt {
  enable true
  broker 192.168.153.1
  port 1883
  devicetype central_heating
  deviceid otmonitor
  format simple
  username otmonitor
  password [redacted]
  retransmit 10
  qos 1
  keepalive 120
  messages false
  client zonnestroom-otmonitor
And i get these errors:
./otmonitor-ahf --daemon -f /opt/zonnestroom/otgw/etc/otmonitor.conf
can not find channel named ""
    while executing
"read $fd 1"
    (class "::mqtt" method "receive" line 3)
    invoked from within
"my receive"
    (class "::mqtt" method "listen" line 26)
    invoked from within
"my listen"
    (class "::mqtt" method "init" line 9)
    invoked from within
"my init $host $port"
invalid command name "::oo::Obj12_coro"
    while executing
"::oo::Obj12_coro connect sock13d4780"
    while executing
"::oo::Obj12_coro receive"
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 20"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 21"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 22"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 23"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 24"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 25"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 26"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 27"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 28"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 29"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 30"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 31"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 32"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 33"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 34"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 35"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 36"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 37"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 38"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 39"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 40"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 41"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 42"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 43"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 44"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 45"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 46"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 47"
    ("after" script)
    while executing
"::oo::Obj12_coro retransmit SUBSCRIBE 48"
    ("after" script)
Is this a bug, or did i configure it wrong?
Thanks.
Nicky
Re: MQTT - Authentication
You should never get a stack trace like that, so there is a bug somewhere. However, looking at the source code I cannot imagine how this error can happen. Also, MQTT with authentication works fine when I try it myself.
Would it be possible for you to run mosquitto with the -v option and report (the first part of) the log it produces?
nickyb2
Post by nickyb2 »
mosquitto.conf
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
password_file /etc/mosquitto/passwd
allow_anonymous false
log_type all
There is not much info in it. The 192.168.153.7 is a PI which runs the otmonitor-afh
mosquitto.log
1466771999: mosquitto version 1.4.8 terminating
1466772000: mosquitto version 1.4.8 (build date Fri, 19 Feb 2016 12:03:16 +0100) starting
1466772000: Config loaded from /etc/mosquitto/mosquitto.conf.
1466772000: Opening ipv4 listen socket on port 1883.
1466772000: Opening ipv6 listen socket on port 1883.
1466772021: New connection from 192.168.153.7 on port 1883.
1466772021: Sending CONNACK to 192.168.153.7 (0, 5)
1466772021: Socket error on client <unknown>, disconnecting.
That log indicates that mosquitto doesn't have the username in its password file (CONNACK return code 5). So either you made a typo there, or otmonitor is sending the wrong username. You can check that last possibility by switching off authentication on mosquitto and run it with -v again. It will then report the username that the client connects with. In your case that should be something like:
  • 1466784084: New client connected from 192.168.153.7 as zonnestroom-otmonitor (c1, k60, u'otmonitor').
If that's what you get, the problem must be in your password file.
nickyb2
Post by nickyb2 »
Lots more logs, just trying to supply a lot of info.
First, all the logs of when it goes wrong.. WITH authentication.
As you can see, the otmonitor user exists and it works with mosquitto_sub.
pi@zonnestroom:~ $ mosquitto_sub -d -t '$SYS/broker/load/bytes/sent/1min' -v -h 192.168.153.1 -u otmonitor -P 'iGIzbBvCnAskg96wu3Gt'
Client mosqsub/10940-zonnestro sending CONNECT
Client mosqsub/10940-zonnestro received CONNACK
Client mosqsub/10940-zonnestro sending SUBSCRIBE (Mid: 1, Topic: $SYS/broker/load/bytes/sent/1min, QoS: 0)
Client mosqsub/10940-zonnestro received SUBACK
Subscribed (mid: 1): 0
Client mosqsub/10940-zonnestro received PUBLISH (d0, q0, r1, m0, '$SYS/broker/load/bytes/sent/1min', ... (7 bytes))
$SYS/broker/load/bytes/sent/1min 2841.09
Client mosqsub/10940-zonnestro received PUBLISH (d0, q0, r0, m0, '$SYS/broker/load/bytes/sent/1min', ... (7 bytes))
$SYS/broker/load/bytes/sent/1min 2412.69
^C
My otmonitor.conf, just so that we can verify i have the correct values filled in for username and password.
pi@zonnestroom:~ $ more /opt/zonnestroom/otgw/etc/otmonitor.conf | grep -A 14 mqtt
mqtt {
  enable true
  port 1883
  deviceid otmonitor
  format simple
  username otmonitor
  password iGIzbBvCnAskg96wu3Gt
  retransmit 10
  qos 1
  keepalive 120
  messages false
The otmonitor errors.
pi@zonnestroom:~ $ /opt/zonnestroom/otgw/bin/otmonitor-ahf --daemon -f /opt/zonnestroom/otgw/etc/otmonitor.conf
    while executing
"read $fd 1"
    invoked from within
"my receive"
    invoked from within
"my listen"
    invoked from within
    while executing
Mosquitto log with log_type all.
root@bijmij:/etc/mosquitto# tail -f /tmp/mosquitto.log
1466831777: New connection from 192.168.153.7 on port 1883.
1466831777: Sending CONNACK to 192.168.153.7 (0, 5)
1466831777: Socket error on client <unknown>, disconnecting.
It this point i turned authentication off as you suggested by commenting out the following two lines:
#allow_anonymous false
#password_file /etc/mosquitto/passwd
And then it starts to work.
1466832002: New connection from 192.168.153.7 on port 1883.
1466832002: New client connected from 192.168.153.7 as zonnestroom-otmonitor (c1, k120, u'otmonitor').
1466832002: Sending CONNACK to zonnestroom-otmonitor (0, 0)
1466832002: Received SUBSCRIBE from zonnestroom-otmonitor
1466832002:     actions/otmonitor/+ (QoS 2)
1466832002: zonnestroom-otmonitor 2 actions/otmonitor/+
1466832002: Sending SUBACK to zonnestroom-otmonitor
1466832003: Received PUBLISH from zonnestroom-otmonitor (d0, q1, r1, m2, 'events/central_heating/otmonitor/returnwatertemperature', .
It seems that otmonitor is indeed using the user otmonitor... but, if the problem is in my password file why does the mosquitto_sub work?
I would have expected that mosquitto_sub would also not work if there was an error in my password file.
Any more ideas? Since i'm at a loss here.
Strange indeed. One thing I notice is that on your mosquitto_sub command you specify the exact same value that is also stored in otmonitor.conf as the password. Did you edit otmonitor.conf by hand to set the password in there? OTmonitor stores passwords in otmonitor.conf in an encoded form, so they shouldn't be the same.
The CONNACK return code is 5, which usually points to a wrong username. But putting the configured password through the decoding algorithm produces binary data, which the MQTT specs allow, but it may not be handled correctly by my code. Maybe mosquitto also returns code 5 if the CONNECT message is corrupt.
[EDIT]: I just checked. OTmonitor correctly handles the binary data, but mosquitto indeed sends a return code of 5 in the CONNACK in this situation.
nickyb2
Post by nickyb2 »
We solved it then. It never occurred to me that the otmonitor.conf is written by otmonitor, so yes the password in my config file was unencrypted. When i 'save' the otmonitor.conf by otmonitor i get an encrypted password which works as expected when i turn on the authentication on mosquitto..
Thanks for your help.
