Two days ago I finished building my OTGW kit bought at the shop and I spend a lot of time reading and searching the forum but can't find the answers or the answers I found are not working for me.
I want to use it, without a thermostat, controlled by homeseer (I want homeseer to be the on/off thermostat using the temperature sensors in various points of the house) via HTTP or MQTT. I know Homeseer will have to calculate the the necessary parameters (like Control setpoint, CH-enable, Max Relative Modulation level).
I have my OTGW connected to a Remeha Calenta via wifi with an ESP8266. Apparently the gateway is receiving data from the boiler but I can't send commands to it. Seems like the boiler just ignores these messages.
If I try to change the setpoint (sending "CS=11.00", "CS=11,00" or "CS=11" from otmonitor Miscellaneous screen) it doesn't changes and can't see in the log a "Response: "CS: 11.00" or any other answer:
In this same screen the operating mode appears as Unknown and if I press Gateway or Monitor buttons it doesn't changes.
May be my issue is related to this http://www.domoticaforum.eu/viewtopic.php?f=75&t=10857 but in my case is not intermittent issue, I already tried resetting the gateway and the issue persists.
At this point I'm lost. I don't know if the gateway is working fine or if homeseer can act as a thermostat and how (a din't look in detail at hot to send Control setpoint, CH-enable, Max Relative Modulation level) but first I don't know if my actual problem is a use/hardware/firmware/configuration issue and if I should dismount the OTGW from where it's mounted to follow the Troubleshooting section.
In the docs regarding stand-alone operation (http://otgw.tclcode.com/standalone.html) I can't find information about using it without thermostat (other than the considerations about the complexity of making a program to control central heating), just in the introduction I can see "Support modulating and on/off thermostats, or even no thermostat at all".
