Toon app: Buienradar
Rudolf
Re: Toon app: Buienradar
Post by Rudolf »
Nevermind; QML's httpRequest and wget-ssl are probably entirely unrelated.
Rudolf wrote:The app uses an http-url that is auto-forwarded to https by buienradar.
Ho ho ho, they started redirecting to https yesterday afternoon, which makes the buienradar app non-functional at the moment.
All existing users probably noticed that the temperatures aren't updated anymore since yesterday afternoon
Workaround will be to retrieve the https page via wget every 10 minutes and store it locally.
And I need to change the app to read the data from the local file instead.
@basvandesande: this also explains why you get no weatherstations, the file simply cannot be retrieved anymore.
Will post here when done..... (I was planning to watch a movie this evening....sigh...)
Regardz,
It will require some significant changes (under the hood) in the buienradar app to make it work again via https.
I have the proof of concept working, it just takes some time to complete and finish repackaging for the ToonStore.
The goal is to make this update seamless for you. No need to fiddle around with wget (which isn't working in this case by the way).
I finish with the famous quote from Schwarzenegger: "We'll be back"
michel30
Post by michel30 »
Hey Toonz no hurry
Rome is also not built in one night :-)
michel30 wrote:Hey Toonz no hurry
So true..... but I need to keep some momentum to satisfy local management over here :D
Core functionality is working again: big radar screen, detailed weatherforecast screen, rain tile.... progressing nicely but a lot more to do.....
lxz
Post by lxz »
wouldn't it be possible to run some kind of https-to-http proxy?
If it is only https://xml.buienradar.nl being used, we can try to run something like this:
<?php
    $xml = simplexml_load_file(rawurlencode("https://xml.buienradar.nl/"));
    print_r($xml);
on a private server.
Could probably work if you find someone willing to host it long term....
By the way much more is retrieved from the buienradar website (radarimages, other maps etc)
But I prefer a 'Toon' only solution to be independent of other infrastructure.
Current solution is using curl and crontab jobs on Toon.
I am almost done with the gui part, it just needs further work to install everything nicely via the ToonStore.
small update: final version now running on my Toon.
Will test it a few days. Will need some further work to repackage it for ToonStore.
Stay tuned (no ETA because of Xmas activities)
Henk-JanS
Post by Henk-JanS »
I am pleasantly surprised by the speed that the community picks this up and works towards a solution! I noticed the problem only on tuesday, rebooted Toon and checked internet connection. When that didn't resolve the issue the forum quickly provided and answer!
I am aware my skills are somewhat limited, but I am quit good at supporting and cheering, so 'go go team!' :D
basvandesande
Post by basvandesande »
Toonz wrote:small update: final version now running on my Toon.
Fantastic job! looking forward to see the update in the store :)
basvandesande wrote: Fantastic job! looking forward to see the update in the store :)
It will have to wait a little while; the packaging department has their annual christmas reception tonight :-).
buienradar-8.2.1 is available from the toonstore.
Enjoy.
mennom
Post by mennom »
I know i am new to this rooted Toon, but i tried to update / remove / reinstall it but it would not install trought the store. removed is fine. al other apps i can uninstall and reinstall. Is this only with me?
jenske
Post by jenske »
have the same problem.I think we must wait for another uodate
jenske
Henk-JanS
Post by Henk-JanS »
I have the same issue: the Toonstore lists the new Buienradar app as available. Installation starts, Toon restarts, but there is no new Buienradar app.
I removed the old version and restarted the installation, but no joy: somehow the installation fails. No 'buienradar' directory for instance in /qml/qmf/apps/. If anyone can point me to potentially useful logfiles of the installation I can post them here.
