Toon app: ToonStore
Re: Toon app: ToonStore
Postby ericT » Fri Jan 26, 2018 4:22 pm
I've tried to install ToonStore on my 4.11.6, but get the following error:
eneco-xxx-xxxxxx:~# opkg install toonstore_1.1.1-r0_qb2.ipk
Installing toonstore (1.1.1-r0) to root...
Executing pre-install script for toonstore-1.1.1
grep: /usr/lib/opkg/info/base-qb2-ene.control: No such file or directory
sh: bad number
Hmmm ... no project file found. Shouldn't happen.
The file base-qb2-ene.control doesn't exist, but there is a base-qb2-uni.control...
Eric
ericT
Postby marcelr » Mon Jan 29, 2018 7:58 pm
This issue has been resolved.
If you have tried to install toonstore-1.1.1 or earlier on FW 4.11.6, please make a copy of /etc/hosts.toonstore_backup before installing a newer version.
Oh, by the way, toonstore-1.1.2 is now available from the toonstore :-)
Postby Toonz » Tue Jan 30, 2018 9:45 pm
ToonStore 1.1.3 is available now.
Changelog:
- when there is a ToonStore update available, the button to remove ToonStore was accidentally enabled.
Button will not shop up anymore to prevent unwanted removal of ToonStore.
Postby ericT » Thu Feb 01, 2018 7:45 pm
@Marcel Thanks! Install succeeded.
ericT
Postby TheHogNL » Fri Feb 16, 2018 1:40 pm
Could you please update the easyEnergy app on the store? 1.2.3 is already available in the topic about easyenergy (first post) but the store still provides 1.2.0 which contains a few errors
Postby Toonz » Fri Feb 16, 2018 1:58 pm
TheHogNL wrote:Could you please update the easyEnergy app on the store? 1.2.3 is already available in the topic about easyenergy (first post) but the store still provides 1.2.0 which contains a few errors
Sure, can do over the weekend. With future updates drop me a PM when ready......
Postby Toonz » Sun Feb 18, 2018 8:57 pm
EasyEnergy version 1.2.3 is available via ToonStore ......
Postby TheHogNL » Sat Feb 24, 2018 4:22 pm
Just upgraded Toon to 4.11.6. Toon store isn't showing the firmware in the bottom screen. Because the Toon changed from ene to uni, the firmware check is now pointing to the wrong file.
Postby marcelr » Sat Feb 24, 2018 4:59 pm
Has been resolved in toonstore-1.1.2.
Postby TheHogNL » Sat Feb 24, 2018 5:42 pm
Hmm I see that in the changelog indeed however, I'm running 1.1.3 and it didn't show the firmware version. Only after I changed the code to look at the uni file instead of ene.
Postby marcelr » Sat Feb 24, 2018 6:07 pm
Could be. I changed the installer to reflect the right FW version file (base-qb2-uni<whatever>). Not sure if that also landed in the qml code. Will take a look.
Postby Toonz » Sat Feb 24, 2018 11:05 pm
The displayed version number in ToonStore is taken from the file /usr/lib/opkg/info/base-qb2-ene.control.
This should be taken from the file /usr/lib/opkg/info/base-qb2-uni.control for the newest firmwares.
Will change this in next version of ToonStore (next weekend or so)
Postby marcelr » Sat Feb 24, 2018 11:12 pm
Never mind, Toonz, it's done already, but thanks anyway. Will test tomorrow. (It's too cold in my attic, right now).
Postby marcelr » Sun Feb 25, 2018 12:51 pm
Toonstore updated to 1.1.4, available from the Toonstore. FW version display fixed.
Postby odelay99 » Sat Mar 10, 2018 1:47 pm
I updated my Toon with the Toon firmware - update script from TheHogNL from 4.4.21 to 4.10.6 and again to the latest 4.13.7 which all went great (thanks for that TheHogNL).
Then I realized that my apps from the toonstore where gone. So I deleted the folders from /qmf/qml/apps including toonstore folder itself. I reinstalled the latest Toonstore but still no apps, I uninstalled with "opkg remove toonstore" and reinstalled again but without any luck.
So now I got the Toonstore installed but when I install an app it shows as not installed after the reboot..
I have attached the log.
Can someone tell me what I'm do wrong?
_opkg.qb2-uni-9.9.99.script.sh.zip
log file
(1.19 KiB) Downloaded 160 times
odelay99
PreviousNext
Return to Toon Apps
