Honeywell lyric t6, Intergas HReco 36
Postby droombox » Wed Mar 21, 2018 10:50 am
Hi Guys,
I own a Honeywell lyric t6 thermo and a Intergas HReco 36 boiler. I tried to send a TT = 25 and got a response TT:25 back. The room temp was 20 at that time so i should expect that the heater would start. But nothing happens and the flame status stays off. The room setpoint was 15.
What is the problem? What am i doing wrong? Is there a way to change the room setpoint?
Grts,
Droombox
droombox
Re: Honeywell lyric t6, Intergas HReco 36
Postby hvxl » Wed Mar 21, 2018 6:03 pm
Most likely your thermostat does not (fully) support OT message ID 9.
Postby yjb » Wed Mar 21, 2018 8:39 pm
Correct, you can't set a temporary temperature with the Lyric Thermostat, at least not using the OTGW.
The only option that I''m aware off is using IFTTT. I'm using IFTTT combined with a html request from my server to IFTTT to regulate the temperature manually.
Ysbrand
yjb
