Toon firmware resource file (as from 4.16.8)
Re: Toon firmware resource file (as from 4.16.8)
Post by TheHogNL »
Yes that is (probably) in the other resources file containing all images. Will look into this, but low prio :-)
Can also fix this is the next resource file with the other mods, that way we can leave the image files untouched.
Arcidodo
Post by Arcidodo »
how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
makkie2002
Post by makkie2002 »
Toonz wrote: 1. by default all custom apps will be loaded from /qmf/qml/apps/ at startup.
Globals.qml is not used anymore for that purpose. If you don't want an app anymore, remove it from the apps folder
My apps folder looks like this ... as you can see some apps have multiple versions + links in the same directory ... is this a problem ?
No. The app loader follows the link rather than the directory. So the code from the directory where the link points at is used as app, all the rest is ignored.
newwolf
Post by newwolf »
makkie2002, I see you have a webcam app?
Where did your get that from and what's in it?
Because I'm looking for something to show a webcam feed or photo of my frontdoor camera when there is someone pushing my doorbell.
I allready have a script that's sending a picture when the doorbell is pushed but if it also can be showed on my Toon it would be very cool :D
Post by TheHogNL »
Arcidodo wrote:how do i edit an *.rcc file? i found an app "QT" but i can only view it as an binary file.
What do you want to do? It is not possible to edit the .rcc file as it indeed a binary file.
We create our own .rcc files to make it work on a > 4.16.8 toon.
makkie2002
It is a homemade app ... it is functional but not very performant ... but it does the job to display my IP-cam image (via a weblink to a (m)jpeg) ... please feel free to experiment with it !
webcam-0.0.7.zip
(16.39 KiB) Downloaded 488 times
Arcidodo
Post by Arcidodo »
i want to edit it.. to remove the "toon" logo in the left top and add an custom picture :D but if its not possible then its an no go for me :cry:
TerrorSource
Post by TerrorSource »
Can you make it available via the ToonStore?
You can find the guideliness for submitting to the ToonStore here: viewtopic.php?f=100&t=11235#p83091
newwolf
Post by newwolf »
makkie2002,
Thanks it's working.
makkie2002
newwolf wrote:makkie2002,
Cool :D
The new resource file for 4.18.8 has been published (see first post for details)
I attempted to hide the Toon logo in dim state as well but failed miserably for now.
Will look into that further at some point.
mAiden
Post by mAiden »
Eneco release today 4.19.10. Dont update it, if you like the custom apps. :-)
Post by TheHogNL »
mAiden wrote:Eneco release today 4.19.10. Dont update it, if you like the custom apps. :-)
I think a 4.19.10 release of the resource file is expected in a few days. However, I also advice not to upgrade if you don't have the 'flatline' graph issue.
Return to “Toon Firmware”
