Toon firmware - update script
Postby Toonz » Sun Aug 05, 2018 7:33 pm
TheHogNL wrote:Yes it is installed on each Toon also (called resources-static-ebl.rcc or something). Only need to reverse engineer all the code again (very hard labour.. but worth it).
Ah ok, no problem then....
Postby makkie2002 » Sun Aug 05, 2018 9:47 pm
TheHogNL wrote:In a PM conversation I adviced him to install 4.16.8. The logs from qt where not that conclusive but my best guess what that the 4.15.8 installation had failed somewhere.
tAfter the update to 4.16.8 his Toon is working fine.
@Toonz, please make a 4.16.8 (and 4.18.8 ) resources file for the Boxx for him so he can tentantize towards Boxx (he's belgian :) )
Indeed ... big thanks to TheHogNl for sticking with me during this ordeal :P ! Update to 4.16.8 did it!
I like you guys that you are all trying to help the few belgians with a Toon or Boxx ... :wink:
makkie2002
Postby Toonz » Sun Aug 05, 2018 9:54 pm
I will create a resource file for boxx as per the V2 version in this topic : https://www.domoticaforum.eu/viewtopic. ... 071#p86615
Will be ready second half of August and posted in the topic above.
Postby newwolf » Mon Aug 06, 2018 4:02 pm
Toonz wrote:I will create a resource file for boxx as per the V2 version in this topic : https://www.domoticaforum.eu/viewtopic. ... 071#p86615
Will this give us the possibility to switch from the Eneco layout to the Boxx layout?
Because I like the Boxx colours more then the Eneco colours.
newwolf
Postby Toonz » Mon Aug 06, 2018 5:06 pm
Not really, that requires installation of the Eneco tenant configuration.
Postby TheHogNL » Tue Aug 07, 2018 10:39 am
To switch back and forwards between tenants configurations you only need to 'opkg remove' the tenant-eneco-nl package and add the 'tenant-engie-be' package AND you need the modified resources.rcc file (at least, if you want toonstore and other custom apps).
Postby makkie2002 » Wed Aug 08, 2018 10:44 pm
I did a reboot today ... still the same issue as before ... not able to boot into the GUI and after a while an automatic restart :? .
Now my Toon is not booting ... this is the logfile for a manual qtstart until an automatic reboot caused my ssh session to disconnect:
Mem: 64656K used, 61540K free, 156K shrd, 0K buff, 20120K cached
CPU0: 60.0% usr 40.0% sys  0.0% nic  0.0% idle  0.0% io  0.0% irq  0.0% sirq
Load average: 12.39 11.31 7.14 2/144 2350
  PID  PPID USER     STAT   VSZ %VSZ %CPU COMMAND
  769     1 root     S     336m272.5  0.0 {hcb_comm} HCBv2 hcb_comm       [OK] [20 clients] [S1|N1]
2284     1 root     R    66908 52.8 85.7 /qmf/sbin/qt-gui -platform linuxfb -plugin Tslib
  808     1 root     S    37564 29.6  8.2 {hdrv_zwave} HCBv2 hdrv_zwave     [OK] [EAD4D3ED SIS 3.67]
  792     1 root     S    23916 18.9  0.0 {hcb_config} HCBv2 hcb_config     [OK] [S1|N1]
  806     1 root     S    22676 17.9  0.0 {hdrv_hue} HCBv2 hdrv_hue       [OK] [S1|N1]
  785     1 root     S    22212 17.5  0.0 {happ_weather} HCBv2 happ_weather   [OK] [S20|N1]
  776     1 root     S    21388 16.9  0.0 {happ_thermstat} HCBv2 happ_thermstat [OK] [ON/OFF] [S20|N
  768     1 root     S    20360 16.0  0.5 {hcb_netcon} HCBv2 hcb_netcon     [OK] [S1|N1]
  772     1 root     S    20304 16.0  0.0 {happ_kpi} HCBv2 happ_kpi       [OK] [S1|N1]
  805     1 root     S    20100 15.8  0.0 {hcb_watchdog} HCBv2 hcb_watchdog   [OK] [S20|N1]
  773     1 root     S    20024 15.8  0.0 {happ_pwrusage} HCBv2 happ_pwrusage  [OK] [S30|N1]
  794     1 root     S    19608 15.5  0.0 {hcb_rrd} HCBv2 hcb_rrd        [OK] [S1|N1]
  807     1 root     S    19372 15.3  0.0 {hdrv_p1} HCBv2 hdrv_p1        [OK] [C:NCONN E:DIS G:DIS ]
  775     1 root     S    19180 15.1  0.0 {happ_smartplug} HCBv2 happ_smartplug [OK] [S1|N1]
  774     1 root     S    19152 15.1  0.0 {happ_scsync} HCBv2 happ_scsync    [OK] [S1|N1]
  777     1 root     S    19108 15.1  0.0 {happ_usermsg} HCBv2 happ_usermsg   [OK] [S1|N1]
  791     1 root     S    13752 10.8  0.0 {hcb_bxtproxy} HCBv2 hcb_bxtproxy   [OK] [S:6:2:0 R:4:0 Q:
  809     1 root     S    11984  9.4  0.0 /HCBv2/bin/lighttpd -D -m /HCBv2/lib/lighttpd -f /HCBv2/et
  770     1 root     S    11604  9.1  0.0 {happ_eventmgr} HCBv2 happ_eventmgr  [OK] [S1|N1]
  793     1 root     S    10936  8.6  0.0 {hcb_log} HCBv2 hcb_log        [OK] [S1|N1]
1204     1 root     S     4688  3.7  0.0 /usr/sbin/openvpn --config /etc/openvpn/vpn.conf --verb 0
  610     1 root     S     4064  3.2  0.5 /usr/sbin/wpa_supplicant -B -P /var/run/wpa_supplicant.wla
1145     1 root     S     3472  2.7  0.0 /usr/sbin/nmbd -s /etc/samba/smb.conf
2315  2312 root     R     3136  2.4  2.3 top
2312  2283 root     S     3136  2.4  0.0 -sh
  399     1 root     S     3124  2.4  0.0 /usr/bin/psplash --angle 0
  766     1 root     S     2964  2.3  0.0 /sbin/getty -L 115200 ttymxc0 vt102
1155     1 root     S     2960  2.3  0.0 udhcpc -b -R -i eth0 -A 5 -p /var/run/udhcpc.eth0.pid -H e
  715     1 root     S     2960  2.3  0.0 /sbin/klogd -n
  712     1 root     S     2960  2.3  0.0 /sbin/syslogd -n -O /var/log/messages -s 32 -b 1 -m 20
2298  2283 root     S     2960  2.3  0.0 sh -c /usr/libexec/sftp-server
eneco-001-081284:~# /usr/bin/startqt
Starting Qt
[hxml] libhcb_xml          v0.1 r121   (Jan 29 2018 09:44:33) [master#4207cfbd9a] (ezxml 0.8.6)
[hbxt] libhcb_boxtalk      v0.1 r136   (Apr 18 2018 13:07:50) [master#fe52c477ee]
[hcom] libhcb_com          v0.1 r139   (Apr 16 2018 17:47:03) [master#6516d0584c]
[hdrv] libhcb_drv          v0.1 r372   (Apr 17 2018 16:02:58) [master#1513da250d]
[hbas] libhcb_base         v0.1 r332   (Jan 29 2018 16:47:03) [master#1aa70136c0]
QIconvCodec::convertToUnicode: using Latin-1 for conversion, iconv_open failed
QIconvCodec::convertFromUnicode: using Latin-1 for conversion, iconv_open failed
QTsLibMouseHandler "tslib" ""
Loading resource "../qml/drawables.rcc"
Loading resource "../qml/resources.rcc"
[hbas]Config from /qmf/etc, loading 4 files with decreasing importance.
[hbas]Config from /qmf/etc/qmf_tenant.xml priority 4
[hbas]Config from /qmf/etc/qmf_release.xml priority 3
[hbas]Config from /qmf/etc/qmf_project.xml priority 2
[hbas]Config from /qmf/etc/qmf_hardware.xml priority 1
[hbas]Config '<qt-gui>ScreenOffToBlank' not found, using default '0'
[qt-gui] qt-gui            v0.1 r8547  (May  9 2018 10:28:40) [master#53d0662892] pid(2351)
[hbas]Config '<qt-gui>noDiscoByebye' not found, using default '0'
[hbas]Config '<qt-gui>configProvider' not found, using default '(null)'
[hbas]Config '<qt-gui>packageUuid' not found, using default 'eneco-001-081284:qt-gui'
[hdrv]Adding internal handler default'7'quit
[hdrv]Adding internal handler default'7'ping
[hdrv]Adding internal handler default'7'doInit
[hdrv]Adding internal handler ConfigProvider'8'GetPackageConfigResponse
[hdrv]Adding internal handler ConfigProvider'7'StoreConfig
[hdrv]Adding internal handler default'7'SetStdoutLvl
[hdrv]Adding internal handler default'7'SetNotifyLvl
[hdrv]Adding internal handler default'9'QueryStateVariable
[hdrv]Adding internal handler default'7'RegisterStateListener
[hdrv]Adding internal handler default'7'webRequest
[hdrv]Adding internal handler default'7'UpdateDataSetSubscription
[hdrv]Adding internal handler default'7'GetDataSet
[hdrv]Adding disco handler 0x400AA4A4 for hcb_log
[hdrv]Adding disco handler 0x400AD000 for hcb_web
[hdrv]Adding disco handler 0x4009B4F4 for hcb_config
[hdrv]Adding disco handler 0x955F8 for happ_kpi
[hbas]OpenProcess: `grep -h -E 'Package:|Version:' /usr/lib/ipkg/info/base-*-*.control /var/lib/opkg/info/base-*-*.control`
grep: /var/lib/opkg/info/base-*-*.control: No such file or directory
[hbas]Found FirmwareVersion: 4.16.8
[hdrv]Adding driver handler specific1'7'UpdateDataSet
[hbas]Config '<general>Tenant' is 'Eneco'
[hdrv]Adding disco handler 0x487B0 for happ_thermstat
[hdrv]Adding driver handler default'7'setScreenState
[hdrv]Adding disco handler 0x487B0 for happ_scsync
[hdrv]Adding disco handler 0x487B0 for hcb_config
[hdrv]Adding disco handler 0x487B0 for happ_kpi
[hdrv]Adding driver handler specific1'8'GetAgreementDetailsResponse
[hdrv]Adding driver handler specific1'8'GetRegistrationInfoResponse
[hdrv]Adding driver handler ConfigProvider'8'GetPackageConfigResponse
[hcom]Connecting to hcb_comm @ localhost:1337 as 'eneco-001-081284:qt-gui'...
[hcom]Connected to: Home Control Box -- hcb_comm/r187 hbas/r332 hdrv/r372 hcom/r139 hbxt/r136 hxml/r121 -- V=3 E=none A=none -- BoxTalk Hub Ready.
[hcom]Sending HBXT_DISCOVERY_ALIVE from eneco-001-081284:qt-gui:
[hdrv]Adding disco handler 0x487B0 for happ_usermsg
Canvas::onCompleted
Loading Open Sans font from imports
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:hcb_comm to UNKNOWN_CLIENT/boxtalk1: n=doInit sessionKey=769-1533761169
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_smartplug: 5f0e67f2-9ea3-446b-b4b9-697fdb1d2441
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_thermstat: 04cbb2f7-7f15-4a8e-8a59-3827d909e779 a871cf97-88c1-44a8-ba50-e1b65c788177 8e3db086-5674-4fef-bb04-7946a43276f5 1edc5383-3cae-4c09-914f-256c88a0e5cf 67edae2a-6527-414f-9cee-10db42bf2acd 6f4ba546-727b-4707-ac3b-7ac4d5c6be35
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:happ_thermstat/specific1: n=UpdateDataSetSubscription updateAction=add dataSet=features autoExpire=0 supportsNaN=1 supportsPartial=0
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_bxtproxy: a0b6a2690-f343-11e1-a21f-0800200c9a66 e3ba5ff0-358d-11e3-aa6e-0800200c9a66 b71faf84-8d29-4649-8919-3a5e191efb1c 90a2c2f6-5e0c-481f-a3ad-8ada2bc83feb d54c0673-c956-4892-8c2a-9d8750340ca8 77121afb-37eb-4b7c-a101-c6f088ef3a2a 5445b336-f590-4ccb-919d-b5a0866881c6 21764550-48f6-11e2-bcfd-0800200c9a66 cc520c55-fb32-4283-af86-4357d0349720 0adc8160-fdb4-11e2-b778-0800200c9a66 b4990910-2ed8-11e5-a2cb-0800200c9a66 16ced557-3b21-46e1-b3b4-8f06f19584fb d2264470-23de-11e0-ac64-0800200c9a66 05a8a3b0-2ddb-11df-8a39-0800200c9a66 761f9626-ebb6-4ee2-9f3f-09d877fc320b 0429a450-bd0c-11e0-962b-0800200c9a66 cc7418e9-a723-4bed-b523-732955c7c520 3096fb90-57f8-11dd-ae16-0800200c9a66 3ea9af30-2cfe-11e3-aa6e-0800200c9a66 8232fd20-145c-11de-8c30-0800200c9a66 3a2f53ba-d440-48d8-8a7e-a21d68b769cc 3b13e1d1-e83e-11e0-9572-0800200c9a66 38715664-1ec5-4bc4-baea-676985ad09ed f73c4e60-37ad-11e1-b86c-0800200c9a66 ff2787d0-4d87-11e1-b86c-0800200c9a66
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hdrv_p1: ac8ccf65-6626-49d9-b3d4-c725159031aa 9573cf6c-34b6-457a-8b26-dac2e9832399 6ccc0d2b-e785-4bcc-a8ca-704a1ee0bf90 cc36bd0f-7b42-4a28-b361-dbb3e0b62151 7a5938b6-1089-47f0-aa99-227552ec0173 61a2afa9-42b6-44a2-a043-d05a361697d3 e2389e9b-f3a3-4ad8-8211-641aea39f7dd 28e166ce-a4b7-4305-a3e6-a8efb6dc8a62 4f9b13d5-b036-4bda-bfca-d6483ac2ccbd 1ade3c06-8b31-4057-b013-ce93a3b5fb31 d986d357-9b49-4f1f-9e9f-25d37e623273 08f325a9-dd94-437c-9146-fbee4e136e6a 7fc0e416-955f-4976-83ef-b8481047ee79 5a306ee1-1a44-4a08-b0bc-75e4e80cf63f af2bcf8b-7e5e-4686-980e-153ec9124c11
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_comm:
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_log:
[hbas]Config '<qt-gui>logProvider' not found, using default '(null)'
[hbas]Set (new) uuid for logProvider: eneco-001-081284:hcb_log
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:hcb_log/Logger: n=LogMessage facility=1 timestampGenerated=2018-08-08 23:19:55 +0200 timestampExpire=2018-09-07 23:19:55 +0200 categoryId=99 entryType=1 appId=1 objectType=9 objectId=libhcb_drv logText=qt-gui starting logTextF=
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_scsync: eb6334f3-18b6-44a5-a3f7-0e78eb13a502 61851a1d-3e4e-44d6-be41-e801c0e65b74 ffc6bbe4-1eb0-4835-af64-aa596965b227 50b62c3d-6531-4fb0-adb9-cd38b708e245 0acdbcfc-50b8-42ca-a250-612beb1fc7ce
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:happ_scsync/specific1: n=GetAgreementDetails
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:happ_scsync/specific1: n=GetRegistrationInfo
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_watchdog:
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hdrv_hue: d757bdd5-353d-4504-ab68-e51e169bc8db
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_config:
[libhcb_drv:../../src/deviceConfig.c@_hdrv_configDiscoUuidHandler():1134]Stored (new) uuid for configProvider: eneco-001-081284:hcb_config
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:hcb_config/ConfigProvider: n=GetPackageConfig PackageName=qt-gui
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:lighttpd:
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:lighttpd/specific1: n=registerHandler handler=qt-gui
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hdrv_zwave: fdad2a20-4f22-4919-8aea-3226f0916a14 bc88556c-7709-4367-9413-7d8849d9153c c23e118c-2763-4960-958f-fb8448eb0426 fe53efe2-9fb8-4add-aeaf-17e59e87d43a 401f6b3e-ddfb-4256-8221-0106cb49d69a 6d549c74-98d6-4dd3-8b33-ca4971e955b7 399c3054-1148-4e7b-9c0a-28404c33a0cf 036063d7-6505-4e36-a125-511ccd05f4f3
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():99]Moving receive buffer contents to beginning ...
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_usermsg: 05b0102c-5254-4ea5-acbd-107ae656264c cb645f73-24d2-4de0-8524-e92c7d3e042c f15081df-e396-4434-9a8a-6deccb628f2d 6119faba-50d0-47ae-8ba8-2085b6007b31 a0169da1-7c51-4fcd-8f18-91ca54b2df69 7e7a5981-d941-4bad-b785-ce517e817a5e 1dca37ac-cc76-4636-9338-480fe2798775 48d7203b-de3c-48e6-9399-fd9778be660e 8a9c17fc-2b50-4d3e-8701-4162159b700c b5380b3d-f61b-46f6-b1c6-756d2bb3d13c 445093af-7c1a-45e4-a527-6823d87f06f6 74a5316e-f7ac-4073-9e54-b411db2ba192 074822a2-6c4f-494f-a8f4-eaa7a44b593a 28f5675d-bc84-4bfb-a786-d379ebed9074 68ecff7a-f40d-4882-bcfe-c75e62857556 b201b88b-7ced-4e3f-a530-6c4a4c313e78 18eb16e7-05ff-4a2f-b7c7-ff58558095dd 1220bf7f-7b5f-494a-8744-2fbcb39a60ef 921c124e-a229-4241-b764-0856aced4873 b9774d01-b668-42b2-9478-67ed6e3cb268 ce03149a-4e0e-41ea-b832-65768e6f5648 c7f0dc13-ad3c-4f18-80d9-f139e8c0aeaa 21dad5f3-4ed0-4a85-81d7-77109327bc5c f4661f63-cf8f-4844-9b2f-0a85b4430d7e 20923feb-e6d4-437a-94c8-6558e45b27ca 32da8392-e627-4b74-9cce-560065d49776 62518807-78f6-4bb3-b6c5-fdc60cf3e30f 9cf103f6-a4c8-489c-9f6b-a416ca08a4a0 d510015a-eca3-4a29-9d39-05b88429efe6 e3fc98df-3f8b-4220-9989-c0d6aa02c708 bf53012c-d189-46f6-aafc-725fb22e6fe2 c0dfbd8c-89dc-4c02-a10e-e3133a54e6ec 42e1892b-54da-40a8-b31c-2c8955ebaac6
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:happ_usermsg/specific1: n=UpdateDataSetSubscription updateAction=add dataSet=notifications autoExpire=0 supportsNaN=1 supportsPartial=0
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_weather: 07d50407-09f1-4fd4-b674-7e9f312f3c2b af908c39-3c6f-419d-aa90-d249babd7a44
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_pwrusage: 684b2818-8671-4bea-8d3e-48008d587379 092ce85e-85d4-4b0e-ad3e-ed14b0a7f349 792966b2-06aa-4033-a439-b1d3c09d5735 a69eb1b0-d945-4427-ba9b-05f3ca0f0af7 de3fe1a0-2f50-4744-83cb-ee129f8092fd
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_netcon: 0a6139e3-fd77-4853-9dcc-1bacb815843d e5b012f9-0204-49dc-a1ee-ac7829a73329
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_eventmgr: 5afbfedf-1f0d-4ee9-82c4-f6202c3e8e47 23b6d9bc-0b80-4513-9c37-a41fc08861fb f23ef2f8-c8fa-458c-87f9-a0243ed35daf
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:happ_kpi: 0fbaa41c-88de-467f-acdd-21461cc7b83f 9b7d51b7-a7e3-4760-acd6-a58d9068a02f
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:hcb_log/Logger: n=LogMessage facility=1 timestampGenerated=2018-08-08 23:19:55 +0200 timestampExpire=2018-09-07 23:19:55 +0200 categoryId=99 entryType=1 appId=1 objectType=9 objectId=qt-gui logText=qt-gui starting logTextF=
[hcom]Sending HBXT_ACTION_INVOKE from eneco-001-081284:qt-gui to eneco-001-081284:happ_kpi/Logger: n=LogMessage appKey=driver starting appValue=qt-gui timestamp=1533763195
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:hcb_rrd: e44a898e-13a9-4190-bd42-0fd58462ea8a b9389a9a-9c38-48d2-b331-860ed9125108 d28ef2ca-dae9-4f06-991e-862f74d9b3e2 cf83539d-5d0c-454b-893d-f0930c848d4b 5676f29a-5f0d-4030-940e-6b0e9aa941a1 9c97ea53-d0b8-4452-b013-e93ebf121c51 09c6ad41-70ba-448d-ad0b-75d2614bead2 81102ad8-8253-438d-90fb-939777ee92d2 ddb138e3-b8fd-4b32-805a-177a089405b0 c86bd8b9-b416-4231-8ef0-59a0dd3e0290 fce7695e-2a00-4f5f-8f96-21b6deecabad 7614504a-2dcd-4de0-a583-92d22c560d0e cddf68d0-c8d4-4f52-a9ea-1becd9d4f4a5 e81b5b14-14a8-408d-8f81-02a1ec391e66 cc3908e8-79eb-4090-a37b-68481c2e7353 738a0203-6a56-42bb-9725-0db453f8e551 6d748839-88cc-43cb-8fa1-09e88ff27411 237f0317-51c2-4450-a47a-a1c6a944a220 de80e940-9fc0-41b2-9909-f10488ec11ba 5a9bc278-0598-4fad-b710-b1fdd9742d70 ddefaa92-fec3-47d9-842c-fdd03a9e65cf 660b9f5d-bb48-48b1-a68d-af0f640cc2f6 25d62501-bb81-40d8-9b56-6d3f23492c1d 8f5c41d9-a967-43b3-96a7-a5af4121814a e4b5a595-830b-4073-9df1-b6eedf4a7e2c 20c3803c-bf78-420a-afdc-5ba401dd5b57 e381c2b2-2850-488d-a646-cab8345f559c
[hcom]Received HBXT_DISCOVERY_ALIVE from eneco-001-081284:qt-gui:
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet features=
Firing handler 10E1F68 for eneco-001-081284:happ_thermstat:features
thermostatFeatures: {"FF_Dhw_UiElements_Settings":false,"FF_Dhw_PreHeat_Settings":false,"FF_Dhw_UiElements":false,"FF_HeatingBeat_UiElements":false,"FF_BoilerControl_Edge_approve":true,"FF_BoilerControl_Zwave_approve":false,"FF_BoilerControl_reveal":true}
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_scsync to eneco-001-081284:qt-gui/specific1: n=GetAgreementDetailsResponse activated=1 standalone=1 productOption=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_scsync to eneco-001-081284:qt-gui/specific1: n=GetRegistrationInfoResponse activated=1 wizardDone=1
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_usermsg to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_usermsg to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet notifications=
Firing handler 114B648 for eneco-001-081284:happ_usermsg:notifications
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 32768
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 49152
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 65536
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 81920
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 98304
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 114688
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 131072
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 147456
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 163840
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 180224
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 196608
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 212992
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 229376
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 245760
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 262144
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 278528
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 294912
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 311296
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 327680
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 344064
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 360448
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 376832
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 393216
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 409600
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 425984
[libhcb_com:../../src/libhcb_com2.c@_hcom2_recv_private():115]Increasing receive buffer to 442368
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/ConfigProvider: n=GetPackageConfigResponse Config=
   PackageName=qt-gui
Using locale: nl_NL
Locale has been set: "nl_NL"
stub Widget init for qrc:/qb/stage/Logo.qml
stub Widget init for qrc:/qb/stage/BackButton.qml
stub Widget init for qrc:/qb/stage/HomeIconButton.qml
stub Widget init for qrc:/qb/stage/MenuIconButton.qml
stub Widget init for qrc:/qb/stage/SaveButton.qml
stub Widget init for qrc:/qb/stage/CancelButton.qml
stub Widget init for qrc:/qb/stage/CustomButton.qml
filterEnabledApps homescreen,systray,thermostat,clock,systemSettings,thermostatSettings,internetSettings,eMetersSettings,settings,graph,inbox,customerService,domesticHotWater,winwit
enabledApps 0 appsToLoad 14
Loaded fullscreen qrc:/qb/utils/AlphaNumericKeyboardScreen.qml > AlphaNumericKeyboardScreen_QMLTYPE_84(0x13f1538)
stub Widget init for qrc:/qb/utils/AlphaNumericKeyboardScreen.qml
Loaded fullscreen qrc:/qb/utils/NumericKeyboardScreen.qml > NumericKeyboardScreen_QMLTYPE_89(0x14d8ef8)
stub Widget init for qrc:/qb/utils/NumericKeyboardScreen.qml
<<<<<<<<<<<<<<<<<<<<<<<<<< STARTED LOADING APPS >>>>>>>>>>>>>>>>>>>>>>>>>>>>
Executing "/etc/init.d/psplash.sh progress 30"
Load app homescreen
Loading language from apps/homescreen/lang
Loaded fullscreen qrc:/apps/homescreen/ChooseTileScreen.qml > ChooseTileScreen_QMLTYPE_95(0x11d2b70)
Loaded fullscreen qrc:/apps/homescreen/Homescreen.qml > Homescreen_QMLTYPE_101(0x123d370)
Loaded fullscreen qrc:/apps/homescreen/MenuScreen.qml > MenuScreen_QMLTYPE_112(0x1532590)
stub init for MenuItem qrc:/apps/homescreen/AddTileMenuItem.qml
Registered dialog qrc:/apps/homescreen/RemoveTilePopup.qml > RemoveTilePopup_QMLTYPE_119(0x1563868, "rmTileArea")
stub Widget init for qrc:/apps/homescreen/RemoveTilePopup.qml
Executing "/etc/init.d/psplash.sh progress 32"
Executing "/etc/init.d/psplash.sh progress 34"
Load app systray
Loading language from apps/systray/lang
Failed loading a language file for: "apps/systray/lang"
topRight widget registered: qrc:/apps/systray/SystrayContainer.qml
Loading systrayIcon qrc:/qb/notifications/NotificationSystray.qml, posIndex: 1000
stub Widget init for qrc:/qb/notifications/NotificationSystray.qml
Loading systrayIcon qrc:/apps/homescreen/DimIcon.qml, posIndex: 100
stub Widget init for qrc:/apps/homescreen/DimIcon.qml
Executing "/etc/init.d/psplash.sh progress 37"
Executing "/etc/init.d/psplash.sh progress 39"
Load app thermostat
Loading language from apps/thermostat/lang
[hdrv]Adding driver handler Thermostat'8'GetHolidaysResponse
[hdrv]Adding disco handler 0x487B0 for happ_eventmgr
Loaded fullscreen qrc:/apps/thermostat/TemperaturePresetScreen.qml > Screen_QMLTYPE_43(0x16019a0)
stub Widget init for qrc:/apps/thermostat/TemperaturePresetScreen.qml
<Unknown File>: Error: Cannot assign [undefined] to QString
stub init for MenuItem qrc:/apps/homescreen/DefaultMenuItem.qml
prominent widget registered: qrc:/apps/thermostat/ThermostatSidePanel.qml
prominent tab button registered: qrc:/apps/thermostat/ThermostatSidePanelButton.qml
onTabButtonClicked( qrc:/apps/thermostat/ThermostatSidePanel.qml )
Loaded fullscreen qrc:/apps/thermostat/ThermostatProgramScreen.qml > ThermostatProgramScreen_QMLTYPE_161(0x1820910)
<Unknown File>: Error: Cannot assign [undefined] to QUrl
Loaded fullscreen qrc:/apps/thermostat/EditDayScreen.qml > EditDayScreen_QMLTYPE_170(0x18ca960)
stub Widget init for qrc:/apps/thermostat/EditDayScreen.qml
Registered dialog qrc:/qb/components/WaitPopup.qml > WaitPopup_QMLTYPE_180(0x18f86b8)
stub Widget init for qrc:/qb/components/WaitPopup.qml
Loading systrayIcon qrc:/apps/thermostat/VacationSystray.qml, posIndex: -999
SystrayIcon qrc:/apps/thermostat/VacationSystray.qml has no posIndex, using 999
stub Widget init for qrc:/apps/thermostat/VacationSystray.qml
Widget registered (2): qrc:/apps/thermostat/ThermostatWeekProgramTab.qml
Widget registered (2): qrc:/apps/thermostat/ThermostatWeekProgramButton.qml
stub Widget init for qrc:/apps/thermostat/ThermostatWeekProgramButton.qml
onTabButtonClicked( qrc:/apps/thermostat/ThermostatWeekProgramTab.qml )
Executing "/etc/init.d/psplash.sh progress 42"
Load app clock
Loading language from apps/clock/lang
Executing "/etc/init.d/psplash.sh progress 44"
Executing "/etc/init.d/psplash.sh progress 47"
[hdrv]Received PING from 'eneco-001-081284:hcb_watchdog' as 'eneco-001-081284:qt-gui', sending PONG back...
Load app systemSettings
Loading language from apps/systemSettings/lang
[hdrv]Adding driver handler default'7'PreExitNotice
[hdrv]Adding driver handler default'7'GetRebootConfirmation
[hdrv]Adding driver handler default'7'ConfirmContactInfoUsageByService
[hdrv]Adding driver handler specific1'8'AddContactResponse
[hdrv]Adding driver handler specific1'8'GetFirmwareUpdateStatusResponse
[hdrv]Adding driver handler specific1'8'CheckFirmwareUpdateResponse
[hdrv]Adding driver handler specific1'8'GetDeviceInfoResponse
Need (sourceUuid or sourceType) and serviceId
[hdrv]Adding disco handler 0x487B0 for hdrv_zwave
[hdrv]Adding disco handler 0x487B0 for hdrv_p1
Registered dialog qrc:/qb/components/WaitPopup.qml > WaitPopup_QMLTYPE_180(0x1aaa9c0)
Registered dialog qrc:/apps/systemSettings/CleanLoadingPopup.qml > Popup_QMLTYPE_99(0x1b09fe8)
stub Widget init for qrc:/apps/systemSettings/CleanLoadingPopup.qml
Registered dialog qrc:/apps/systemSettings/SoftwareUpdateInProgressPopup.qml > Popup_QMLTYPE_99(0x1b12b60)
stub Widget init for qrc:/apps/systemSettings/SoftwareUpdateInProgressPopup.qml
Registered dialog qrc:/apps/systemSettings/MaUpdateInProgressPopup.qml > MaUpdateInProgressPopup_QMLTYPE_223(0x1b532c8)
stub Widget init for qrc:/apps/systemSettings/MaUpdateInProgressPopup.qml
Registered dialog qrc:/apps/systemSettings/LanguageSettingPopup.qml > LanguageSettingPopup_QMLTYPE_225(0x1b5d990)
stub Widget init for qrc:/apps/systemSettings/LanguageSettingPopup.qml
Registered dialog qrc:/apps/systemSettings/RebootInProgressPopup.qml > Popup_QMLTYPE_99(0x1b6bae8)
stub Widget init for qrc:/apps/systemSettings/RebootInProgressPopup.qml
Loading systrayIcon qrc:/apps/systemSettings/SystemSettingsErrorTray.qml, posIndex: 300
stub Widget init for qrc:/apps/systemSettings/SystemSettingsErrorTray.qml
Loading systrayIcon qrc:/apps/systemSettings/SystemUpdateTray.qml, posIndex: 300
stub Widget init for qrc:/apps/systemSettings/SystemUpdateTray.qml
Registered dialog qrc:/qb/components/WaitPopup.qml > WaitPopup_QMLTYPE_180(0x1bbf3e8)
Executing "/etc/init.d/psplash.sh progress 50"
Load app thermostatSettings
Loading language from apps/thermostatSettings/lang
[hdrv]Adding driver handler Thermostat'8'GetDhwSettingsResponse
[hdrv]Adding driver handler Thermostat'8'GetChSettingsResponse
[hdrv]Adding driver handler Thermostat'8'GetTempOffsetResponse
[hdrv]Adding driver handler Thermostat'8'TestBoilerTypeResponse
Set boiler error handler to: qrc:/apps/thermostatSettings/OverviewHeatingSettingsScreen.qml
Executing "/etc/init.d/psplash.sh progress 52"
Load app internetSettings
Loading language from apps/internetSettings/lang
[hdrv]Adding driver handler NetworkInformation'8'GetWirelessNetworkInformationResponse
[hdrv]Adding driver handler NetworkInformation'8'GetWirelessNetworksResponse
[hdrv]Adding driver handler NetworkInformation'8'GetInterfaceInfoResponse
[hdrv]Adding driver handler specific1'8'getResearchStateResponse
[hdrv]Adding driver handler specific1'8'getMobileAccessStateResponse
[hdrv]Adding driver handler specific1'8'CheckServiceEnableResponse
[hdrv]Adding disco handler 0x487B0 for hcb_netcon
Loading systrayIcon qrc:/apps/internetSettings/InternetSystray.qml, posIndex: 400
Registered dialog qrc:/apps/internetSettings/ActivationPopup.qml > Popup_QMLTYPE_99(0x1c4bbf8)
stub Widget init for qrc:/apps/internetSettings/ActivationPopup.qml
Executing "/etc/init.d/psplash.sh progress 55"
Load app eMetersSettings
Loading language from apps/eMetersSettings/lang
[hdrv]Adding driver handler default'8'GetSensorConfigurationResponse
[hdrv]Adding driver handler default'8'GetMeterConfigurationResponse
[hdrv]Adding driver handler specific1'8'GetDevicesResponse
[hdrv]Adding disco handler 0x487B0 for happ_smartplug
[hdrv]Adding disco handler 0x487B0 for happ_pwrusage
Executing "/etc/init.d/psplash.sh progress 57"
Load app settings
Loading language from apps/settings/lang
Loaded fullscreen qrc:/apps/settings/SettingsScreen.qml > SettingsScreen_QMLTYPE_346(0x17642b8)
stub Widget init for qrc:/apps/systemSettings/ScreenFrame.qml
stub Widget init for qrc:/apps/thermostatSettings/HeatingFrame.qml
Executing "/etc/init.d/psplash.sh progress 60"
Executing "/etc/init.d/psplash.sh progress 62"
Load app graph
Loading language from apps/graph/lang
[hdrv]Adding driver handler specific1'8'IsHolidayOrWeekendResponse
[hdrv]Adding disco handler 0x487B0 for hcb_rrd
Executing "/etc/init.d/psplash.sh progress 65"
Load app inbox
Loading language from apps/inbox/lang
[hdrv]Adding driver handler default'7'addMessage
Registered dialog qrc:/apps/inbox/InboxFullScreenMsg.qml > InboxFullScreenMsg_QMLTYPE_416(0x2299208)
stub Widget init for qrc:/apps/inbox/InboxFullScreenMsg.qml
Executing "/etc/init.d/psplash.sh progress 67"
Load app customerService
Loading language from apps/customerService/lang
[hdrv]Adding driver handler default'8'getSupportStateResponse
Executing "/etc/init.d/psplash.sh progress 69"
Executing "/etc/init.d/psplash.sh progress 72"
Load app domesticHotWater
Loading language from apps/domesticHotWater/lang
Executing "/etc/init.d/psplash.sh progress 74"
Executing "/etc/init.d/psplash.sh progress 77"
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_usermsg to eneco-001-081284:qt-gui/Notification: n=DeleteNotificationResponse response=404 reason=no notification found
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_smartplug to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_smartplug to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet deviceConfigInfo=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet deviceConnectionTree={
  "dct": {
    "deviceConnectionTreeVersion": 1,
    "dctRoot": {
      "connections": []
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet thermostatInfo=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hdrv_p1 to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet thermostatStates=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet heatRecoveryInfo=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_thermstat to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet scheduleRuntime={}
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_scsync to eneco-001-081284:qt-gui/specific1: n=GetDeviceInfoResponse devices= Result=ok
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_scsync to eneco-001-081284:qt-gui/: n=GetDeviceInfoResponse requestId=2284-0 devices= Result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:hdrv_p1 to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet usageDevicesInfo=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:hdrv_p1 to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet connectedInfo=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hdrv_zwave to eneco-001-081284:qt-gui/specific1: n=GetDevicesResponse requestId=2284-4 devices=
No device known in usageDevicesInfo with uuid bc88556c-7709-4367-9413-7d8849d9153c status reported as 'not configured'
Device - Name: HAE_METER_v2 uuid: bc88556c-7709-4367-9413-7d8849d9153c isMeasureDevice: 0
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hdrv_zwave to eneco-001-081284:qt-gui/specific1: n=GetDevicesResponse devices=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hdrv_zwave to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:hdrv_zwave to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet networkHealth=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_usermsg to eneco-001-081284:qt-gui/specific1: n=GetMessagesResponse requestId=2284-5 messages=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_netcon to eneco-001-081284:qt-gui/NetworkInformation: n=GetInterfaceInfoResponse interfaceInfo=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet billingInfo=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet heatUsage=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet powerUsage=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:happ_eventmgr to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet gasUsage=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet boilerUsage=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_eventmgr to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet eventContacts=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_pwrusage to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet monthData=
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:happ_eventmgr to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet eventScenarios=
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: iface=wlan0
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: configtype=dhcp
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: ipaddress=192.168.42.9
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: netmask=255.255.255.0
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: default_gateway=0.0.0.0
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: nameserver=8.8.8.8
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/gwif: macaddress=54:27:1E:5A:53:6E
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/status: connector=0
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/status: network=1
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/status: internet=1
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/status: tunnel=1
[hcom]Received NOTIFY from eneco-001-081284:hcb_netcon/status: statemachine=5
   PackageName=qt-gui
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/ConfigProvider: n=GetPackageConfigResponse requestId=2284-1 Config=
   PackageName=qt-gui
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/ConfigProvider: n=GetObjectConfigResponse requestId=2284-2 Config=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/ConfigProvider: n=GetObjectConfigResponse requestId=2284-3 Config=
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/specific1: n=UpdateDataSetSubscriptionResponse result=ok
[hcom]Received HBXT_ACTION_INVOKE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/specific1: n=UpdateDataSet softwareVersionInfo=
   PackageName=qt-gui
[hcom]Received HBXT_ACTION_RESPONSE from eneco-001-081284:hcb_config to eneco-001-081284:qt-gui/ConfigProvider: n=SetObjectConfigResponse Success=true
Load app winwit
Loading language from apps/winwit/lang
[hdrv]Adding driver handler default'8'GetDoWhatsnewResponse
stub init for MenuItem qrc:/apps/winwit/WhatIsToonMenu.qml
Registered dialog qrc:/apps/winwit/ImageGalleryPopup.qml > ImageGalleryPopup_QMLTYPE_434(0x2388170)
stub Widget init for qrc:/apps/winwit/ImageGalleryPopup.qml
Executing "/etc/init.d/psplash.sh progress 79"
Executing "/etc/init.d/psplash.sh progress 82"
<<<<<<<<<<<<<<<<<<<<<<<<<< LOADING CUSTOM APPS >>>>>>>>>>>>>>>>>>>>>>>>>>>>
TSC found this app to be custom installed: buienradar
TSC found this app to be custom installed: homeassistant
TSC found this app to be custom installed: temperaturelogger
TSC found this app to be custom installed: toonstore
TSC found this app to be custom installed: wastecollection
TSC found this app to be custom installed: webcam
==================================Loading buienradar app============================
Loaded fullscreen file:////qmf/qml/apps/buienradar/BuienradarDetailsScreen.qml > BuienradarDetailsScreen_QMLTYPE_435(0x1f52c30)
stub Widget init for file:////qmf/qml/apps/buienradar/BuienradarDetailsScreen.qml
Loaded fullscreen file:////qmf/qml/apps/buienradar/BuienradarStationScreen.qml > Screen_QMLTYPE_43(0x274b910)
stub Widget init for file:////qmf/qml/apps/buienradar/BuienradarStationScreen.qml
Loaded fullscreen file:////qmf/qml/apps/buienradar/BuienradarActualRadarScreen.qml > Screen_QMLTYPE_43(0x22464e0)
stub Widget init for file:////qmf/qml/apps/buienradar/BuienradarActualRadarScreen.qml
Loaded fullscreen file:////qmf/qml/apps/buienradar/BuienradarEditLonLatScreen.qml > BuienradarEditLonLatScreen_QMLTYPE_439(0x2200b18)
stub Widget init for file:////qmf/qml/apps/buienradar/BuienradarEditLonLatScreen.qml
Loaded fullscreen file:////qmf/qml/apps/buienradar/BuienradarFullWeatherForecastScreen.qml > Screen_QMLTYPE_43(0x1bbb4b0)
stub Widget init for file:////qmf/qml/apps/buienradar/BuienradarFullWeatherForecastScreen.qml
stub init for MenuItem file:////qmf/qml/apps/buienradar/BuienradarMenu.qml
as a reference for squish, please define widgetInfo.args.objectName on the systray icon
Loading systrayIcon file:////qmf/qml/apps/buienradar/BuienradarTray.qml, posIndex: 9000
stub Widget init for file:////qmf/qml/apps/buienradar/BuienradarTray.qml
==================================Loading homeassistant app============================
file:////qmf/qml/apps/homeassistant/HomeassistantApp.qml:473: SyntaxError: Unable to parse JSON string
Loaded fullscreen file:////qmf/qml/apps/homeassistant/HomeAssistantConfigurationScreen.qml > HomeAssistantConfigurationScreen_QMLTYPE_445(0x1eab640)
stub Widget init for file:////qmf/qml/apps/homeassistant/HomeAssistantConfigurationScreen.qml
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:1045: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:1031: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:1001: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:987: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:957: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:943: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:912: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:898: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:868: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:854: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:809: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:769: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:729: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:689: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:649: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:609: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:564: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:533: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:515: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:497: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:481: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:445: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:429: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:417: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:404: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:383: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:372: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:361: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:350: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:326: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:314: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:302: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:289: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:268: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:257: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:246: SyntaxError: Unable to parse JSON string
file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml:235: SyntaxError: Unable to parse JSON string
Loaded fullscreen file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml > Screen_QMLTYPE_43(0x29427d8)
stub Widget init for file:////qmf/qml/apps/homeassistant/HomeAssistantScreen.qml
==================================Loading temperaturelogger app============================
QThread::start: Thread creation error: Resource temporarily unavailable
Loaded fullscreen file:////qmf/qml/apps/temperaturelogger/TemperatureloggerScreen.qml > Screen_QMLTYPE_43(0x11180f8)
stub Widget init for file:////qmf/qml/apps/temperaturelogger/TemperatureloggerScreen.qml
Loading systrayIcon file:////qmf/qml/apps/temperaturelogger/TemperatureloggerTray.qml, posIndex: 9000
stub Widget init for file:////qmf/qml/apps/temperaturelogger/TemperatureloggerTray.qml
==================================Loading toonstore app============================
*************** ENE file does not exist
********** ToonStore: check downloads ready to be installed
makkie2002
Postby TheHogNL » Thu Aug 09, 2018 10:20 am
Maybe it is just a resource issue, you are loading a lot of custom apps:
Maybe remove some?
Postby makkie2002 » Thu Aug 09, 2018 7:11 pm
TheHogNL wrote:Maybe it is just a resource issue, you are loading a lot of custom apps:
Maybe remove some?
I remove all applications except toonstore ... still the same issues :(
makkie2002
Postby TheHogNL » Thu Aug 09, 2018 9:09 pm
But it was working just after the 4.16.8 upgrade right? And it stopped after a reboot?
Postby makkie2002 » Thu Aug 09, 2018 10:03 pm
TheHogNL wrote:But it was working just after the 4.16.8 upgrade right? And it stopped after a reboot?
It all started with upgrade to 4.15.6. The booting did not stop and often restarted (some timeout or watchdog kicking in?). TheHogNl adviced to upgrade to 4.16.8. And this intially had the same issue and TheHogNl even offered remote session to help, but somehow I got lucky and the GUI was showing, so I thought it was all solved. But then I did a reboot to find the same old problems once more. But this time my Toon never succeeded to get i to the GUI and allways restarts during the boot.
makkie2002
Postby TheHogNL » Fri Aug 10, 2018 6:12 am
Could it be that your disk is full? ("df -h")
Postby makkie2002 » Fri Aug 10, 2018 6:34 pm
TheHogNL wrote:Could it be that your disk is full? ("df -h")
I don't think so ?
eneco-001-081284:~# df -h
Filesystem                Size      Used Available Use% Mounted on
ubi0:rootfs             106.2M     71.6M     34.6M  67% /
tmpfs                    40.0K         0     40.0K   0% /mnt/.psplash
tmpfs                    61.6M    152.0K     61.5M   0% /var/volatile
makkie2002
Postby TheHogNL » Fri Aug 10, 2018 7:07 pm
No that looks ok. If you need assistance you know where to find me :-)
Postby pkaak » Tue Aug 14, 2018 9:46 am
so it has been some time that I looked at my rooted Toon (1-1.5 years I guess :P ).
So I wonder if I should upgrade or not. What are the benefits of upgrading?
And how safe is the script? Still needed to check things after an upgrade?
Can I just upload the script to Toon and run it by using SSH?
pkaak
PreviousNext
Return to Toon Firmware
