Rooting Toon (or boxx)
Re: Rooting Toon (or boxx)
It's pinging google:
$ nslookup 8.8.8.8
Server:		192.168.73.1
Address:	192.168.73.1#53
Non-authoritative answer:
8.8.8.8.in-addr.arpa	name = google-public-dns-a.google.com.
But you're right, this hasn't been working for some time now. Your suggestion should be added to the rooting manual.
mogwai
Post by mogwai »
marcelr wrote:It's pinging google:
$ nslookup 8.8.8.8
Thanks for your quick response. Pinging google probably doensn't hurt. Then I'll just skip the modification of hosts altogether...
martenjacobs
Post by martenjacobs »
Gleno0hh wrote:
TheHogNL wrote:Did you use the Toon Rooter on https://github.com/martenjacobs/ToonRooter ?
Tried, didnt work with raspberry 1a. Actually, nothing worked with the 1a, see my previous post. After using a model b, it was easy. I believe with the model b it gave me a import error on pyserial with toonrooter.
I've made some changes in my dev branch so it should now work on RPi 1 as well. Make sure you do a git checkout dev after cloning the repo. I'll merge it into master as soon as I get some feedback that it's working or when I have the time to test it myself.
msv
Post by msv »
Hi guys,
I have an fully rooted Toon i try to change the root password.
If i change the password with command passwd i am able to set an new password, thereafter i exit the console and i am able to login with the new password.
If i reboot the Toon i can only login with the old password.
What is going wrong here?
yjb
Post by yjb »
Have a look at the timestamp of the /etc/passwd file.
Did you root it yourself or is the unit "preowned"? Might be that there is an init script which copies the old password file over the existing one, I guess to make sure that the password is not changed by Eneco.
I would expect that there is some where a backup copy hanging around of the passwd file search with
find / -name passwd* -print
And see if it matches your passwd file after a reboot.
TerrorSource
Post by TerrorSource »
msv wrote:Hi guys,
Can you check if you have multiple passwd files? Had that issue once before. It created version/temporary copies of the passwd files. Reason why is still unknown.
Cctl01
Post by Cctl01 »
Am I correctly understanding that the only way to make Toon adapt to a new house (bought second hand) is to perform a factory reset? On the official toon forum different people seem to think differently.
secondly, am I correctly understanding that a factory reset will only make me lose my schedules etc. Not the root access ssh keys etc?
Can't see any reason why you would want to do a factory reset.
And adapting to a new house? What does that mean?
TerrorSource
marcelr wrote:Can't see any reason why you would want to do a factory reset.
Well, I recommend a Factory Reset when moving to a new house so the meter values are resetted. Easiest way to do that.
Also, when buying a Toon 2nd hand, a factory reset is the way to go to remove the info of the previous owner.
Cctl01
Post by Cctl01 »
Obviously I was not clear explaining what I want to achieve.
I would like (unless it happens automatically) to have Toon reinitiate the self learning process. Stookgedrag, zelf lerend if you wish in Dutch.
what options do I have in this matter? Is it as simple as overwriting some file perhaps?
It's a continuous process, no need to restart anything.
Cctl01
Post by Cctl01 »
marcelr wrote:It's a continuous process, no need to restart anything.
Thanks for clarifying that. Now that I think about it, it makes sense since heat-up- and cool-down-rate is different is autumn, winter and spring.
Yep, it's called controller auto-tuning. The whole "inleren" thing is just a transient of that tuning process. Some forum members at the toon forum were adamant that it needs to be set/reset to start the process. Ignorant fools :roll:
Rudolf
Post by Rudolf »
I started using my Toon this summer; would be pretty cold :( here if it hadn't adapted to new (outside) temperatures by now.
Good thing it's continuous process. Would be quite tedious to reset Toon every season. :lol: :mrgreen: :lol:
Stay warm! :wink:
WickedMaster
Post by WickedMaster »
Prutzer wrote:Hi Marcel and Rboers,
First of all, thank you for your manual how to root a Toon thermostaat.
I'm also trying to root a Toon but I get stuck. First I tried to use a Orange PI, but that did not work. I did not succeed in configuring openocd. Next I used my raspberry Pi and that is going better.
But now i'm stuck here:
root@raspberrypi:~/rootToon# ls
ed20.cfg raspberrypi.cfg
root@raspberrypi:~/rootToon# openocd -s /usr/share/openocd -f ~/rootToon/raspberrypi.cfg -f ~/rootToon/ed20.cfg
Open On-Chip Debugger 0.9.0 (2018-01-22-06:14)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
Info : only one transport option; autoselect 'jtag'
/root/rootToon/raspberrypi.cfg:13: Error: invalid command name "bcm2835gpio_peripheral_base"
in procedure 'script'
at file "embedded:startup.tcl", line 60
at file "/root/rootToon/raspberrypi.cfg", line 13
Before I could start openocd I had to install it. Sudo apt-get install openocd.
What am I doing wrong?
I'm getting the same error on a RPi3 B+. How did you fix it?
Return to “Toon Rooting”
