Toon app: Home Assistant controller
timkoers
Re: Toon app: Home Assistant controller
Post by timkoers »
Since there is another HomeAssistant app available for the Toon (viewtopic.php?f=87&t=12089), which has dynamic objects so you can add virtually unlimited switches etc.
My suggestion, just like marcelr's and Luc_S' is to combine forces and greate a good stable app.
Which layout do you preffer if I may ask?
The one of this thread or the one posted in the link above?
Hypermobile
Post by Hypermobile »
you need to type a Password....
But where to put Username of Domoticz??
it does not work right now
michel30
Post by michel30 »
This is build for Home Assistant controller not for Domoticz.
You need to build Home Assistant center.
Sundown89
Post by Sundown89 »
timkoers wrote:Which layout do you preffer if I may ask?
I prefer your layout. I think it is a great idea to combine the two apps into one, and both work on it. Maybe with some settings so users can choose between some parts that are different.
Keep up the good work! I was thinking about buying a wall mounted tablet, but now I'll wait and see how whether this app is going to satisfy my needs.
TheRedBull
Post by TheRedBull »
@marcelr can you update the current application on the toon store?
The current version doesnt support SSL, but the new version does: https://github.com/Luc-S/Toon-HASS
Would really like to see this app updated! Would help a lot in my home automation :)
legalr
Post by legalr »
Are there issues withe the Home Assistant from the Toon Store in combination with the latest firware?
I fill out the required fields, User, PW. Port, but no connection to my Home Assistant.
something else to check/do?
dennis071nl
Post by dennis071nl »
Ok guys, i actually don't wanna wait until this release it placed in the toon store, is it just a matter of replacing the files on my toon to install this version??
TheRedBull wrote:@marcelr can you update the current application on the toon store?
Yes, it is...
just that updating later via the ToonStore might be an issue. In that case remove the app manually and install again via the ToonStore
Homescreenassistent version 1.0.1 is available in the ToonStore.
Changelog:
- implemented SSL
Note for the author: Your screens are not scaled properly on a Toon 2 :-).
You need to use the isNxt variable to set different value for the screen element sizes and positions.
(see any other app for examples)
Luc_S
Post by Luc_S »
Hi all, thanks for the feedback. Just came back from holiday so I’ll try to look into it ASAP. Appearantly there’s also a new user system implemented in the latest HA update? Got some work to do :)
Cheers!
Luc_S
Post by Luc_S »
As of Home Assistant version 0.73.0 it's needed to have 'ssl_profile: intermediate' set in your http section of the Home Assistant configuration if you use SSL. If this is not added the Home Assistant api will not be available anymore for this app on your Toon.
http:
  <other http settings>
More info can be found on https://www.home-assistant.io/components/http/
kurniawan77
Post by kurniawan77 »
I can't seem to connect to HA with ssl. Updated to the latest HA and have set "intermediate" too.
Only thing i get is: Settings not saved, got response "".
I tried it both ways with internal ip and port 8123 and with my ha.myurl.nl with port 443 but no go. I am able to get response from rest api...
Any help from here? I am willing to assist
Regards
rickvnl
Post by rickvnl »
kurniawan77 wrote:Hi,
Regards
Hey, does it work for you now? I have the same problem.
kurniawan77
Regards
Nothing changed actually
