New major firmware release 5.0.4 - UPGRADE AVAILABLE
Postby TheHogNL » Wed Dec 12, 2018 11:58 am
We have got the information that major firmware release 5.0 is soon to be released to customers (fixing the 10% dim setting for toon1 users).
However we discovered that release 5.0 also includes at lot of changes to the Toon (1 and 2). QT is upgrade to a recent version (5.11) and this includes a new resource file format. Also we are seeing some changes for which we need to rewrite some code for probably all custom apps.
Don't use the update script force-update-option to get your hands on 5.0 firmware if you want to keep using the custom apps for now!
Re: New major firmware release 5.0 - DO NO UPGRADE YET
Postby Toonz » Thu Dec 13, 2018 5:07 pm
Just because you say not to upgrade, I did so on a second development Toon :D .
A lot has changed indeed and many code changes are needed (in the resource files as well as in the custom apps itself) to get everything working again including ToonStore.
So, for all readers, stay far away from version 5 until you read on this forum that it is save to upgrade (not anytime soon I guess)
Postby michel30 » Thu Dec 13, 2018 7:59 pm
Thanks for the warning information.
michel30
Postby Ierlandfan » Thu Dec 13, 2018 9:23 pm
Does anybody knows how much is needed for downloading the packages? I have about 30M free space left and it cuts out at 25% for not having enough.
Makes me wonder how much is still needed...Tmpfs has 61.3M free space, can't I store them over there?
Ierlandfan
Postby TheHogNL » Thu Dec 13, 2018 9:35 pm
30M is normally enough.. from what version are you updating from?
Postby Ierlandfan » Fri Dec 14, 2018 12:16 am
Currently running version 4.22.7 on a qb2 with flavour uni
After a fresh start (reboot) and with the GUI disabled (I thought it would save some space somehow) df-h shows:
ubi0:rootfs 106.7M 74.7M 32.0M 70% /
tmpfs 40.0K 0 40.0K 0% /mnt/.psplash
tmpfs 61.6M 144.0K 61.5M 0% /var/volatile
(Had to delete all logs and rrd's for that after I backed them up on another remote place)
38%
Filesystem Size Used Available Use% Mounted on
ubi0:rootfs 106.7M 102.4M 4.3M 96% /
tmpfs 61.6M 184.0K 61.4M 0% /var/volatile
Not enough...under 5000 it quits.
After I freed up about 8MB deleting the .rcc files in /qmf/qml (Backed them up at another place ) and rebooted
I tried again:
ubi0:rootfs 106.7M 66.1M 40.6M 62% /
tmpfs 61.6M 136.0K 61.5M 0% /var/volatile
This finally worked...
After downloading I had 12MB free but...
during installation I saw
(watch df -h)
ubi0:rootfs 106.7M 106.7M 4.0K 100% /
And:
Collected errors:
* copy_file_chunk: write: No space left on device
But most of the packages are already installed so I have to do some manually labour :-)
Ierlandfan
Postby TheHogNL » Fri Dec 14, 2018 9:25 am
How are you updating? Not with opkg manually i hope? The eneco script (and my script) have some disk usage warnings and protection in it.
Postby Ierlandfan » Sat Dec 15, 2018 2:16 pm
The disk checking causesd the firmware update to fail when there's less than 5 MB free. A good thing.
The script returned no problems with 40MB free.
After downloading and installing there were a few packages that were crippled beacuse of no space left on the device so I forced a reinstall with opkg.
Had to fix the /etc/hosts.conf file (127.0.0.1 was still there) So I added the right IP.
Only package that failed to install is libz1
Installing libz1 (1.2.8-r0) to root...
Downloading http://feed.hae.orig/feeds/qb2/oe/angel ... armv5e.ipk.
Collected errors:
Removing package libz1 from root... <<<<<
* opkg_install_pkg: Failed to verify the signature of /var/lib/opkg/oe-armv5e.
* opkg_install_cmd: Cannot install package libz1. <<<<Whoops
After a reboot Toon is not starting because of that libz1 removed package so I have to fix that as well
I probably have to reinstall another package and them install libz1 again. We'll see.
Ierlandfan
Postby mAiden » Sat Dec 15, 2018 2:34 pm
@Ierlandfan,
Which version do you try? 5.0.0 ?
5.0.1 is also available, maybe that one get better.
mAiden
Postby Ierlandfan » Sat Dec 15, 2018 5:19 pm
At the moment i can't update or install anything since opkg returns:
opkg: error while loading shared libraries: libz.so.1: cannot open shared object file: No such file or directory
I can't download the package libz1 either ( http://feed.hae.orig/feeds/qb2/oe/angel ... armv5e.ipk.)
since feed.hae.orig times out. VPN is up.
If some could download that package and makes it available i can manually install the files in the right directories.
Ierlandfan
Postby mAiden » Sat Dec 15, 2018 6:11 pm
Will look for you, if i can download them.
mAiden
Postby TheHogNL » Sat Dec 15, 2018 6:26 pm
Ierlandfan wrote:At the moment i can't update or install anything since opkg returns:
feed.hae.orig is the one the script uses.. if you are doing it manually the real name is feed.hae.int
So when you have manually enabled the vpn the url would be http://feed.hae.int/feeds/qb2/oe/angeli ... armv5e.ipk
Postby Ierlandfan » Sat Dec 15, 2018 6:46 pm
There's something worng with my VPN I guess, I cannot ping any feed.hae. It's up but well, not really doing it's thing.
Can you download the package for me? Then I can figure out why vpn isn't working.
Ierlandfan
Postby mAiden » Sat Dec 15, 2018 7:15 pm
Ierlandfan wrote:There's something worng with my VPN I guess, I cannot ping any feed.hae. It's up but well, not really doing it's thing.
Think I have it for you.
https://ufile.io/hydxb
mAiden
Postby Ierlandfan » Sat Dec 15, 2018 7:31 pm
Thanx, you were fast!
Ierlandfan
Next
Return to Toon Firmware
