Toon app: Kalender
Re: Toon app: Kalender
Can you try file:///.... (three slashes....). Haven't tried myself...
Templar
Post by Templar »
Toonz wrote:Can you try file:///.... (three slashes....). Haven't tried myself...
It does work! But with the wrong display of the birthdays.. No DTEND used in this ICS file....
2018-12-17 (*) Birthday of <Person A>
2018-12-22 (*) Birthday of <Person A>
2018-12-24 Kerstavond
2018-12-25 Eerste kerstdag
2018-12-26 Tweede kerstdag
2018-12-30 (*) Birthday of <Person A>
2018-12-31 Oudejaarsavond
2019-01-01 (*) Birthday of <Person A>
2019-01-01 Nieuwjaarsdag
2019-01-09 (*) Birthday of <Person A>
2019-01-16 (*) Birthday of <Person A>
2019-01-17 (*) Birthday of <Person A>
2019-01-22 (*) Birthday of <Person A>
.........etc.
Wait for 1.0.11 to fix the missing end dates
marcog
Post by marcog »
Toonz wrote:
marcog wrote:Is it an option when Toon is in a dim state to show the date of the upcoming event in a format like "Today at 08:00" or "Wed 12 December 2018 08:00" instead of "12 December 2018 08:00". I'm not that good in remembering the current date so this would be a nice add-on.
version 1.0.10 is available in ToonStore.
Changelog:
- date of the first appointment on the tile in dim state now shows as 'vandaag', 'morgen' and 'overmorgen' for the coming three days.
- Later dates are including the short day name, now formatted as "Ma 18 december" on the tile in dim state.
- Appointment title is now the top row, date and time the bottom two rows in dim state
I guess this will be the last update for now (unless bugs are found), focus will be on getting ToonStore and apps running on firmware 5.0.x
Kind regards,
Thank you Toonz, I just installed 1.0.10 and it brings a smile to my face.
hi all,
version 1.1.0 is released on ToonStore. This is the first installation package which is compatible with firmware 4 and firmware 5 (when the newly modded resource files are released)
Changelog:
- if the end-date is missing, I assume that the enddate is the same as the startdate (might leave it blank in the future)
This version will show entries correctly without end-dates like the space launch calendar and others.
mAiden
Post by mAiden »
@Toonz
My Toon1 does not like this version of the Calendar :cry: .
When i load my private google url (Its the only one i put in settings file), after about 5min, Toon crash and reboot itself.
mAiden wrote:@Toonz
That's not good, is it on a Toon 1 or Toon 2? Which firmware?
mAiden
Post by mAiden »
Toonz wrote:
mAiden wrote:@Toonz
On Toon1 on firmware 5.0.1. Have got the resourcefile from Thehog.
mAiden wrote:
Toonz wrote:
mAiden wrote:@Toonz
ok, I have tested it on a Toon 1 on 4.22, it even loads the huge space calender properly and on a Toon 2 on 4.22 and a Toon 2 on 5.0.1 without issues.
I don't have a Toon 1 on 5.0.1 at the moment.
could it be that Toon runs out of memory? Does deleting other custom apps help (or even better, disable a lot of the internal apps)?
mAiden
Post by mAiden »
Give me 3 mins, lets boot my laptop.
Will look in Toon. Give you some screens, even better watch with me with teamviewer?
mAiden
Post by mAiden »
Think this one it the problem Toonz, remove it with opkg remove, but when i installed it agian, got this:
Installing calendar (1.1.0-r0) to root...
Running preinstall for calendar-1.1.0
Older installation detected.
Backing up previous settings ...
Pre-inst script completed
Need to remove older installation.
mAiden wrote:Think this one it the problem Toonz, remove it with opkg remove, but when i installed it agian, got this:
Thinking about it, it is probably best to completely uninstall all custom apps before or right after upgrading to fw5 and then install everything again.
mAiden
Post by mAiden »
Have removed all custom apps, and reinstalled the calendar. Now he picks up the standard calender.
I'm curious what it does with my own calendar in it now.
//EDIT:
Crash agian and Toon reboot himself with my own .ICS file in it.
App works ok with the stabdard calender in it. But when a add my own in it, it's goes wrong.
mAiden wrote:App works ok with the stabdard calender in it. But when a add my own in it, it's goes wrong.
can you email me your ics file for debugging?
Templar
Post by Templar »
Toonz wrote:Wait for 1.0.11 to fix the missing end dates
It handles the launch calendar okay but the birthday calendar just like before.
