Toon app: ToonStore
Re: Toon app: ToonStore
I can't update any of the apps using the Toonstore?
I also can't uninstall the apps using the Toonstore?
It just returns to the home screen after pressing "Toon Bijwerken" and does nothing.
Manually removing the app, reboot GUI and try to install via the Toonstore also doesn't work?
I tried rebooting, but somehow it doesn't want to (un)install anything anymore using the Toonstore.
What can I do to fix this?
Toon1 running firmware 5.33.9 (rooted)
most likely you need to fix the hcb_web settings in /qmf/etc/qmf_release.xml.
Especially the tags defaultEntry and enforceWhitelist>.
<hcb_web>
<defaultEntry>/qmf/www/</defaultEntry>
<enforceWhitelist>0</enforceWhitelist>
<whitelist>
<item>hdrv_zwave</item>
<item>happ_zware</item>
<item>rsrc</item>
</whitelist>
</hcb_web>
You mean the extra spaces in front of those lines?
Changed it to exactly what you had and did a full reboot still doesn't update the apps.
Ok, second usual suspect : /etc/hosts
Can you check whether that looks normal (no double entries)
So that was the problem, I put the content from /etc/hosts.toonstore_backup into the /etc/hosts file and I could update the apps.
Thanks for pointing me in the right direction, but how could this happen?
Running firmware version 4.13.6
After i update toonstore from 2.0.2 to 2.1.2 i have the following issue,
When i try to update app's i get the message firmware update available and the message and download icon are shown
But the app that i select in the toonstore isn't updating.
What could be the reason ?
issue solved by updating toon to version 5.0.4
- Member
Known error?opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk
Downloading http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk.
Installing toonstore (2.1.2-r0) to root...
Executing pre-install script for toonstore-2.1.2
Hmmm ... no project file found. Shouldn't happen.
Edit: Fixed it by creating qmf_release.xml manually. I think I somehow deleted it accidentally.
As we stated in the install script :this should never happen.... . Glad you fixed it. Would like to hear from others if they experience the same
- Administrator
On what firmware did you receive this error?WickedMaster wrote:Known error?opkg install http://files.domoticaforum.eu/uploads/T ... r0_qb2.ipk
I had the same error on a 5.0.4 (officially updated to 5.0.4) Toon, which was never rooted before.
- Member
This was also on a 5.0.4, updated manually. But this one was rooted already.
- Starting Member
Had almost the same, my /etc/hosts file had 2 lines with 127.0.0.1 , one for local and one for feed.hae.intMP51 wrote:Running firmware version 4.13.6
- Starting Member
and also no luck... My toonstore won't install or remove apps.
SW 2.12
Firmware 5.04
I've checked hosts and the lines in qml_release. nothing strange... i guess.
Help
SW 2.12
Firmware 5.04
Help
