Rooted Toon stuck in install mode
- Starting Member
Help, I have a rooted Toon but its stuck in the installation mode.
I cant pass or go further without a activation code from Eneco.
Re: Rooted Toon stuck in install mode
You can fix that with the update-rooted.sh script. See elsewhere on this forum for details.
- Starting Member
Thanks, I’ve tried: curl -Nks https://raw.githubusercontent.com/IgorY ... -rooted.sh -o /root/update-rooted.shmarcelr wrote:You can fix that with the update-rooted.sh script. See elsewhere on this forum for details.
You are currently running version 5.0.4 on a qb2 with flavour uni
Available versions: 1.0.9 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4
Seems I already have the latest version…
update-rooted.sh can also "fix"fiiles which are not correct (without any update):
update-rooted.sh -f
update-rooted.sh -f
- Administrator
Didn't you need the manual/help before running it?AJAPPELDOORN wrote:Thanks, I’ve tried: curl -Nks https://raw.githubusercontent.com/IgorY ... -rooted.sh -o /root/update-rooted.shmarcelr wrote:You can fix that with the update-rooted.sh script. See elsewhere on this forum for details.
Tru using the "update-rooted.sh -h" to show help information. solution is right there!
- Starting Member
problem solved
super thanks to all
IS there a solution for this if someone else rooted for you and you cant remember who this was?
I dont have cables to connect myself....
- Member
If you have forgotten your SSH password, you have to root it again.robgeerts wrote:IS there a solution for this if someone else rooted for you and you cant remember who this was?
If you have the TSC menu you can reset the password there. The TSC menu is available from updates 4.16 and further for rooted toons as a mod in the resource files.robgeerts wrote:IS there a solution for this if someone else rooted for you and you cant remember who this was?
- Administrator
Isn't there a sticker on the back side of the Toon as some rooters/sellers do that
I know the password...
BUT i can only see the install menu... so not any additional icons..
SSH seems not be acessible when i try to connect? Or do i miss something here..
- Member
Then your Toon isn't rooted. You have to root the Toon, or let it do.
It was rooted!
I had appstore and installed some apps. Untill I did a factory reset.
This resets the root too?
Versions at the time of rooting:
Software: 4.8.25
Firmware ketelmodule: 37
Firmware meteradapter: 35/37
Software: 4.8.25
If it was rooted it is still rooted even after a factory reset. But after a factory reset you need to set the wifi first or else you can't connect ofcourse.robgeerts wrote:I know the password...
The wifi is set. The api calls the Domoticz use to set temperature are working.TheHogNL wrote:If it was rooted it is still rooted even after a factory reset. But after a factory reset you need to set the wifi first or else you can't connect ofcourse.robgeerts wrote:I know the password...
So even SSH should still work after factory reset? Even in my version?
