QT websockets
QT websockets
Postby TheHogNL » Sat Feb 16, 2019 9:17 am
From firmware 5.0.4 the original Toon resources also include libraries for QT5 websockets!
To use the libraries install them when having the VPN running with "opkg install libqt5websockets5" (I will probably add an option to the update-script to install this for you soon).
After this you can use the library in your qml code with "import QtWebSockets 1.0"
From there just use the docs at https://doc.qt.io/qt-5/qtwebsockets-qmlmodule.html and the examples at https://doc.qt.io/qt-5/qtwebsockets-examples.html
Using websockets in your qml code would allow your Toon to be externally controlled. Much more possibilities then the current ones using the /happ_thermstat (and other) urls which only supports a few commands.
For example, the use case where a forum members wants to put a doorbell-camera picture on the Toon when someone is ringing the phone could now be implemented easily. Much more ideas are welcome!
Re: QT websockets
Postby Toonz » Sat Feb 16, 2019 10:59 am
I can now finally have a realtime status on Toon of the status of the klikaan/klikuit lights in the bedrooms (controlled via domoticz on a raspberry Pi)
No need for sending http requests to domoticz anymore every 5 seconds to query the status of the lights.
Re: QT websockets
Postby Toonz » Sat Feb 16, 2019 11:03 am
It is also a perfect solution for someone to write a comprehensive mobile app to control the Toon remotely (using a companion app on Toon itself).
Basically everything is possible now, far beyond the options of the official mobile app from Quby :-)
Develop our own API?
Re: QT websockets
Postby hvxl » Sat Feb 16, 2019 12:01 pm
Works like a charm. And it avoids my web server logs from filling up with all those poll requests!
Re: QT websockets
Postby Toonz » Tue Feb 19, 2019 9:47 am
great stuff. By any change, did they also complie an UdpSocket class?
handy for sending discovery packets
Re: QT websockets
Postby WickedMaster » Tue Apr 09, 2019 11:53 am
Toonz wrote:It is also a perfect solution for someone to write a comprehensive mobile app to control the Toon remotely (using a companion app on Toon itself).
Me and RoadXY are trying to make use of QT websockets for the app we're currently working on. Any help is welcome!
WickedMaster
Re: QT websockets
Postby RoadXY » Tue Apr 09, 2019 12:06 pm
Yes, any help is appreciated
RoadXY
Re: QT websockets
Postby Toonz » Tue Apr 09, 2019 12:15 pm
a lot you can find in the QT documentation : https://doc.qt.io/qt-5/qml-qtwebsockets-websocket.html including sample code.
The WebSockets allow you to receive/send from/to a Toon QML app directly without making user of the lighttpd webserver.
Do you have already ideas about functionality you want to build?
Exactly what type of help is requested?
Re: QT websockets
Postby WickedMaster » Tue Apr 09, 2019 12:23 pm
At this point we're looking for a possibility to change/add programs from the app. Eventually we want to do everything with websockets in the app. So, also changing the temperature, fetching information etc.. This is currently done by using HTTP requests. But, changing/adding programs, doesn't seem to be able by using HTTP post/requests.
It would be helpful if someone can assist us with setting up a new QML app/module for the Toon, so that we have a base to lean on. We've got no experience with developing apps for the Toon itself.
WickedMaster
Re: QT websockets
Postby RoadXY » Tue Apr 09, 2019 12:37 pm
By programs we mean the heating schedule
RoadXY
Re: QT websockets
Postby Toonz » Tue Apr 09, 2019 12:48 pm
That is not so straight forward. We can also look into modifying the quby schedule programming app for this (use websockets there)
Re: QT websockets
Postby oepi-loepi » Wed Oct 16, 2019 10:33 am
Toonz wrote:I can now finally have a realtime status on Toon of the status of the klikaan/klikuit lights in the bedrooms (controlled via domoticz on a raspberry Pi)
Did you manage to use the Websockets for this and could you share the Toon and Domoticz code? I now have the doorbell camera, my Onkyo receiver control, washing dryer status and waching machine status on the Toon but all by pulling Domoticz status. Websockets will be much neater.
oepi-loepi
Re: QT websockets
Postby Toonz » Wed Oct 16, 2019 11:33 am
oepi-loepi wrote:Did you manage to use the Websockets for this and could you share the Toon and Domoticz code? I now have the doorbell camera, my Onkyo receiver control, washing dryer status and waching machine status on the Toon but all by pulling Domoticz status. Websockets will be much neater.
Ha, good call, I completely forgot about this. Current domoticzboard app is not using it.
I will have a look at it after I finished the new Fileinfo app (is almost finished on a Toon 2 but I still have to check the gui elements and performance on a Toon 1).
Re: QT websockets
Postby oepi-loepi » Wed Oct 16, 2019 12:23 pm
Toonz wrote:Ha, good call, I completely forgot about this. Current domoticzboard app is not using it.
Well it seems it should be integrated in the newest beta of Domoticz https://github.com/domoticz/domoticz/co ... 34ca617dc0. However i have newer worked with it so a good example would be very nice. Maybe some other forum member has tried?
oepi-loepi
Re: QT websockets
Postby oepi-loepi » Tue May 05, 2020 9:25 am
TheHogNL wrote:From firmware 5.0.4 the original Toon resources also include libraries for QT5 websockets!
if i run opkg list-installed then libqt5websockets5 is not in the list and when i run "opkg install libqt5websockets5" it throws an error. Even when i open the VPN (in inittab and then init q)
Installing libqt5websockets5 (5.11.2+git0+e71467cb56-r0) on root.
Downloading http://feed.hae.int/feeds/nxt/oe/angelica-1.7.0-master-kernel-4.9.88/cortexa9hf-vfp-neon/libqt5websockets5_5.11.2+git0+e71467cb56-r0_cortexa9hf-vfp-neon.ipk.
Collected errors:
* opkg_download: Failed to download http://feed.hae.int/feeds/nxt/oe/angelica-1.7.0-master-kernel-4.9.88/cortexa9hf-vfp-neon/libqt5websockets5_5.11.2+git0+e71467cb56-r0_cortexa9hf-vfp-neon.ipk: Couldn't connect to server.
* opkg_install_pkg: Failed to download libqt5websockets5. Perhaps you need to run 'opkg update'?
Do I do something wrong or would it be possible to post the .ipk package in the files section?
oepi-loepi
Next
Return to Toon software development
