I like itTerrorSource wrote:
Approved the 1.0.2 update yesterday evening in the ToonStore.
Check it out!
Toon app: DomoticzBoard
Re: Toon app: DomoticzBoard
first of all i dont know if this is possible
I have my P1 port of my "slimme meter" connected to domoticz on my raspberry, can we send this data to the Toon and show the data on the screen in the DomoticzBoard app without using the energy adapter from ENECO?
Rooted Toon 1, Domoticz running on a RPI3b+, RFXCOM XL, RFLINK.
- Administrator
Should be possibile but not on wishlist now, so not in the near-future.PeJeWe wrote:first of all i dont know if this is possible
Tried the app, but could not connect. Already added the Toon ip to the "Local Networks (no username/password):" inside Domoticz setup.
Think it has to do with the SSL connection and self-signed certificate. Is it possible to ignore self-signed certificates?
current version is only using http calls (not https).
Ah, ok. Are there plans to add it to a future version?
Also username and password would be nice...
- Administrator
Adding the IP address of the Toon to the “no password” settings should work. I don’t know anyone else with a self-signed certificate on Domoticz so I cannot test it out. Did you try removing the self-signed certificate? Does it work then?jnieuw wrote:Tried the app, but could not connect. Already added the Toon ip to the "Local Networks (no username/password):" inside Domoticz setup.
- Starting Member
Is it possible to add an extra switch on the Domoticzboard?
Toon 2 Rooted User
Firmware version: 5.94.7
Raspberry Pi 3B+
Domoticz 2022.1
10 Neo Coolcam PowerPlus
Domotica Beginner (need little help in beginning)
Raspberry Pi 3B+
Domoticz 2022.1
- Administrator
It is always possible technically but for what? You can already put 5 in the app.witteherder wrote:Is it possible to add an extra switch on the Domoticzboard?
Toonz and myself are thinking about re-doing the complete app so it retreives the switches from Domoticz without entering IDX's, but that's a long-term project.
Is there a option to show custom sensors like my own weather station, and place them in the dim screen?
- Administrator
Same answer as the post before you. yes it is technically possible but not anytime soon.PeJeWe wrote:Is there a option to show custom sensors like my own weather station, and place them in the dim screen?
- Starting Member
TerrorSource because i have more switches that's why my questionIt is always possible technically but for what? You can already put 5 in the app.
Toon 2 Rooted User
Raspberry Pi 3B+
Domoticz 2022.1
Raspberry Pi 3B+
Domoticz 2022.1
- Member
I used Dashticz..but that not available anymore on 5.13.9 unfortunate.
All Domoticz favourites were automatically visible @ ToonDashticz.
i liked it a lot.
domoticaforum.eu/viewtopic.php?f=99& ... 882#p84238
i liked it a lot.
- Starting Member
Three things that bug me:
- Icons for the groups have disappeared. Buttons work, but are grey
- The trayIcon is a bit larger then the others.
- Refresh time after pressing a button is too long.
Can these be fixed?
Can these be fixed?
