hi,
i have a rooted toon and have done a "factory reset" (probebly should not have done this).
Now im stuck with a "insert activation code" message.
i have tried to login trough putty but i have no luck. probebly im a noob in doing this. can someone help me telling me in mickey mouse language how to log in and get rid of this activation code?
many thanks,
kevin
cant log in via ssh
Re: cant log in via ssh
You first need to login with SSH (for example using putty) to the IP address of the Toon (IP address which you can find in the Toon menu).
If that doesn't work anymore you need to root it again. Just running factory default will never lose SSH access though, so there is something else wrong.
- Administrator
You already told me that you found the password and you could connect to the toon right?kevinvantuyl wrote:hi,
many thanks,
kevin
If you, download the update-rooted.sh file to the Toon and run “sh update-rooted.sh -a” to activate, reboot afterwards.
- Starting Member
i found the sticker on the backside of toon, and enabled te activation of toon. thanks for your helpTerrorSource wrote:You already told me that you found the password and you could connect to the toon right?kevinvantuyl wrote:hi,
many thanks,
kevin
