Toon is rooted but not working
I manage to root my toon, and it unlocked the full access buiten weer etc but rebooted it and all disappeared.
I re-rooted but did not make a difference. What am I doing wrong?
Re: Toon is rooted but not working
Did you follow the manual? viewtopic.php?f=100&t=11235#p82533jumans wrote:I manage to root my toon, and it unlocked the full access buiten weer etc but rebooted it and all disappeared.
I think you didn't run the update-rooted.sh script with option -f to finish/finalize your rooting.
Ok, I have Pi2,
The Toon is now rooted what next. The manual is not clear. I have the raspberry pi2, openocd is installed but I get errors. What is the correct procedure?
The Toon says rooted but what do I do next is not clear.
How to I use the openocd
I'm lost what your problem is. If your toon is rooted you don't need openocd anymore. Openocd is also not needed if you are using the toonrooter script (this script will use openocd for you).
They only thing is that, after you root your toon, you need to run the update-rooted.sh script to download the latest firmware and install some necessary software for your rooted toon.
Ok I tried that But I get this error
`sh update-rooted.sh`
update-rooted.sh: 41: [: 954bba48d55dd031405238d0f3e1f828: unexpected operator
strings: '/HCBv2/sbin/hcb_config': No such file
mkdir: cannot create directory ‘/HCBv2’: Permission denied
grep: /etc/opkg/arch.conf: No such file or directory
update-rooted.sh: 373: update-rooted.sh: cannot create /proc/sys/vm/vfs_cache_pressure: Permission denied
update-rooted.sh: 374: update-rooted.sh: cannot create /proc/sys/vm/drop_caches: Permission denied
update-rooted.sh: 1: update-rooted.sh: opkg: not found
update-rooted.sh: 381: [: unexpected operator
update-rooted.sh: 958: [: unexpected operator
update-rooted.sh: 964: update-rooted.sh: cannot create /HCBv2/tmp/opkg-cache/updated-rooted.status: Directory nonexistent
update-rooted.sh: 397: update-rooted.sh: cannot create /root/iptables.save: Permission denied
update-rooted.sh: 403: update-rooted.sh: cannot create /etc/default/iptables.conf: Permission denied
/bin/cp: failed to access '/root/iptables.backup': Permission denied
/bin/cp: failed to access '/root/passwd.backup': Permission denied
update-rooted.sh: 972: update-rooted.sh: cannot create /HCBv2/tmp/opkg-cache/updated-rooted.status: Directory nonexistent
iptables: Permission denied (you must be root).
iptables v1.8.2 (nf_tables): Chain 'UPDATE-INPUT' does not exist
Try `iptables -h' or 'iptables --help' for more information.
update-rooted.sh: 484: [: unexpected operator
sed: couldn't open temporary file /etc/sedz8yZnZ: Permission denied
update-rooted.sh: 505: update-rooted.sh: cannot create /etc/hosts: Permission denied
iptables v1.8.2 (nf_tables): Couldn't load match `tcp':No such file or directory
/HCBv2/tmp/opkg-cache/upgrade-qb2.sh: No such file or directory
update-rooted.sh: 516: [: 1: unexpected operator
update-rooted.sh: 522: [: qb2: unexpected operator
/usr/bin/md5sum: /HCBv2/tmp/opkg-cache/upgrade-qb2.sh: No such file or directory
update-rooted.sh: 529: [: unexpected operator
/bin/sed: can't read /HCBv2/tmp/opkg-cache/upgrade-qb2.sh: No such file or directory
update-rooted.sh: 996: update-rooted.sh: cannot create /HCBv2/tmp/opkg-cache/updated-rooted.status: Directory nonexistent
update-rooted.sh: 556: update-rooted.sh: opkg: not found
This is what I have done
INFO:rooter:Rebooting
INFO:rooter:Your Toon is now rooted. Please wait for it to boot up and try to log in using SSH
now the next stage. I'm a little lost how to code in the part.
Did you run update-rooted script on Toon? apparently not so.
It's not letting me do that.
How can I do that?
I got so far, how do you add the update to the Toon? I am connected with the Rasberry pi. Then I get lost. Sorry
How can I do that?
Try the code below is in a terminal of your raspberry pi .. Replace ipoftoon with you're Toon ip adresses
ssh root@ipoftoon
It tells you what to do. "INFO:rooter:Your Toon is now rooted. Please wait for it to boot up and try to log in using SSH"jumans wrote:This is what I have done
ok now got it working. How can I change the language on the toonstore to english?
The custom apps (including toonstore) don't have any language specific code so if you want another language then presented to you, you need to change the code or contribute to the community and add translations.jumans wrote:ok now got it working. How can I change the language on the toonstore to english?
ok fair enough, got to practice my dutch
