Toon firmware - update script
Post by TheHogNL »
mrgnex wrote:
TheHogNL wrote:
mrgnex wrote:what is the username? Putty asks me for one..)?
Commonplease.... you have ROOTed your toon.. so what should the username be...
Argh. I tried admin, user, nothing, Toon and even Eneco and nothing would work. In hindsight it is logical. Doh!
It worked flawlessly and I am updated! Thank you for your help. Onto installing the Toon Store!
For that, just read the rooting manual viewtopic.php?f=100&t=11235#p82533
(just run the update-rooted.sh script with option -f )
estate
Post by estate »
user mostly is: root
and pwd: toon
worked for me :)
mrgnex wrote:
TheHogNL wrote:That automatic rooting printed the password for you at the end of the process :) The whole idea of 'rooting a toon' is about having root acccess, so with a password :) How did you install toonstore and other stuff afterwards? With root password you can not install those.
I did not install those yet because I figured I'd update first. I redid the rooting process and made sure I have the right password. I used putty and the build in SSH in the Raspberry Pi. Both gave me an access denied (what is the username? Putty asks me for one..).
I made sure the Toon shows up in the router and the static IP is correct. I also made sure I was using port 22 (otherwise I do not even get the option to enter a password).
Why does it keep telling me access denied?
Ierlandfan
Post by Ierlandfan »
NVM
iMars
Post by iMars »
Hi, I'd like to upgrade my toon, which is running on version 4.10.6.
I've downloaded the script, yet my VPN won't come up:
toon:~# ./update-rooted.sh
Version: 4.16  - TheHogNL & TerrorSource & yjb - 25-12-2019
You are currently running version 4.10.6 on a qb2 with flavour ene
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.7 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.8.27 2.9.15 2.9.26 2.10.15 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.2 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.9.124 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6 4.16.8 4.18.8 4.19.10 4.20.7 4.22.7 5.0.4 5.0.5 5.0.6 5.2.11 5.5.7 5.9.6 5.13.9 5.13.12 5.15.6 5.18.8
4.22.7
Alright, I will try to upgrade to 4.22.7
Could not enable VPN in a normal reasonable time!
DEBUG information:
10.0.0.0/24 dev wlan0 scope link  src 10.0.0.18
default via 10.0.0.1 dev wlan0  metric 10
# <persistent /etc/hosts content can be added to /etc/hosts.template file>
127.0.0.1		localhost.localdomain		localhost		toon
172.24.0.1		feed.hae.int		feed
END DEBUG information
toon:~# /usr/sbin/openvpn --config /etc/openvpn/vpn.conf
Sat Jan 25 16:24:34 2020 DEPRECATED OPTION: --tls-remote, please update your configuration
Sat Jan 25 16:24:34 2020 OpenVPN 2.3.11 arm-hae-linux-gnueabi [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Nov 30 2016
Sat Jan 25 16:24:34 2020 library versions: OpenSSL 1.0.2h  3 May 2016, LZO 1.08
Sat Jan 25 16:24:34 2020 Control Channel Authentication: using '/etc/openvpn/vpn/ta.key' as a OpenVPN static key file
Sat Jan 25 16:24:34 2020 Attempting to establish TCP connection with [AF_INET]3.248.26.144:443 [nonblock]
Sat Jan 25 16:24:36 2020 TCP connection established with [AF_INET]3.248.26.144:443
Sat Jan 25 16:24:36 2020 TCPv4_CLIENT link local: [undef]
Sat Jan 25 16:24:36 2020 TCPv4_CLIENT link remote: [AF_INET]3.248.26.144:443
Sat Jan 25 16:24:38 2020 [VPN-Eneco] Peer Connection Initiated with [AF_INET]3.248.26.144:443
Sat Jan 25 16:24:41 2020 AUTH: Received control message: AUTH_FAILED
Sat Jan 25 16:24:41 2020 SIGTERM[soft,auth-failure] received, process exiting
toon:~#
I get an AUTH: Received control message: AUTH_FAILED
Even after reboot, I get the same results. Anybody knows how to fix this VPN issue?
Post by TheHogNL »
iMars wrote:Hi, I'd like to upgrade my toon, which is running on version 4.10.6.
It seems that your VPN key is invalidated bij Eneco/Quby. You will need to get a new key from a donor Toon. I you contact me in a PM I am happy to sell you a key from a broken Toon (so not used anymore).
Stampre
Post by Stampre »
In the TSC when push update I get the update 5.22.14 with a warning of being in beta. Anybody allready on this one?
TerrorSource
Post by TerrorSource »
Stampre wrote:In the TSC when push update I get the update 5.22.14 with a warning of being in beta. Anybody allready on this one?
Yes. I’m on 5.22.14 and you can upgrade to it if you want.
Stampre
Post by Stampre »
Only i need to so is push update in TSC i guess?
TerrorSource
Stampre wrote:Only i need to so is push update in TSC i guess?
For example yes. Or start the update-rooted script manually.
Boulevard
Post by Boulevard »
firmware 5.22.14 contains an icon at the bottom left, what is the purpose of this icon?
https://photos.app.goo.gl/1gJFQcESeg7hfHJK6
Ron_nl
Post by Ron_nl »
It is for rotating the tiles when your screen is dimmed.
forum.eneco.nl/software-en-hardware-upd ... gaan-22875
Ron.
Stampre
Post by Stampre »
My Toon won't update to the last firmware. In the mnt/data/update folder are several files. Can i delete all of these without any problem?
Post by TheHogNL »
Stampre wrote:My Toon won't update to the last firmware. In the mnt/data/update folder are several files. Can i delete all of these without any problem?
Yes, all files in /mnt/data/update can be deleted safely
Lucien
Post by Lucien »
I'm new here, so sorry for stupid questions or actions....
I bought and rooted my Toon using an RPi with martenjacobs/ToonRooter and ToonSoftwareCollective/update-rooted. Thanks for all the work to help us out.
Unfortunately I selected the latest firmware 5.25.8. The Toon is functioning fine and SSH works fine. But I do not see the Toonstore?! I tried using updating the Toonstore by using https://cyberjunky.nl/updating-rooted-toon-5-9-6/. No luck.
Shouldn't I have installed 5.25.8 and is there a way back? Or should I do some additional stuff to get this up and running?
Hope you guys can help me.
TerrorSource
Lucien wrote:I'm new here, so sorry for stupid questions or actions....
first of all, you should get your information here on this forum and not some website which isn't supported by the TSC-team :)
Did you upgrade the Toon to the latest firmware 5.25.8 and did you run the fix at the end of the script?
you can run the fixes manually by using the -f parameter: sh update-rooted.sh -f
Return to “Toon Firmware”
