Firmware 5.28.9
Joskep
Firmware 5.28.9
Post by Joskep »
Somebody tested this newest version?
Re: Firmware 5.28.9
Post by TheHogNL »
Joskep wrote:Somebody tested this newest version?
Yes safe to install. Just same functions as 5.28.6 but then with the toon2 update issue fixed.
Joskep
Re: Firmware 5.28.9
Post by Joskep »
Thanks!!
hansgrave
Re: Firmware 5.28.9
Post by hansgrave »
Updated to 5.28.9 on my Toon 1 it seems like it reacts much faster now!
Homey, rooted Toon 1 and HomeAssistent.
Darkje
Re: Firmware 5.28.9
Post by Darkje »
Same here, pretty fast.
And there seem to be a symbol in de left power corner.
Dont know what is does.
Re: Firmware 5.28.9
Darkje wrote:Same here, pretty fast.
by pressing that button you can start rotating homescreenpages when in dim mode
Darkje
Re: Firmware 5.28.9
Post by Darkje »
@toonz thnx.
This firmware jeeps awesome. It is still fast and really responsive. I wonder what they changed.
hansgrave
Re: Firmware 5.28.9
Post by hansgrave »
There is also a green leafe if your temp setpoint is below 19,5 :lol:
Re: Firmware 5.28.9
Darkje wrote:@toonz thnx.
hmmm, most of the recent versions did not add any new relevant functionality, mainly fixing their own bugs they created themselves in earlier releases.
But that approach is working, everyone is happy now with the fast responding screen after they screwed up. It is a way to get happy customers indeed :D
Darkje
Re: Firmware 5.28.9
Post by Darkje »
@Toonz, It is actually a difference of day and night.
Its not 3%faster. I think it is like 300% faster.
Timeless
Re: Firmware 5.28.9
Post by Timeless »
I updated from 5.22.14 -> 5.28.9 and also noticed better responsiveness overall.
But unfortunately the z-wave connection became very unstable since the update resulting in zeroed out readings and gray segments in the metering details.
I unpaired->paired the meter-adapter which did not help, and the distance between Toon and the meter-adapter is +/-6m.
It worked flawlessly for the past year, and the times I checked it always showed 5 stars for the connection status, but now it sometimes show 5, other times 1, and most times none at all :?.
Anyone else noticed z-wave problems with the meter-adapter since the update?
"The greatest good you can do for another, is not to share your own riches, but to reveal to him, his own."
- Benjamin Disraeli -
Re: Firmware 5.28.9
Post by TheHogNL »
Timeless wrote: Anyone else noticed z-wave problems with the meter-adapter since the update?
First time I hear this. There wasn't a z-wave part update also from your firmware to 5.28.9 so i'm guessing it is something else. Don't know what
Timeless
Re: Firmware 5.28.9
Post by Timeless »
Yeah I have no idea what it could be.
I've power cycled Toon and this seem to have improved it a bit.
But I do still see these messages in the logfiles:
["2020-05-31 14:14:21 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","NCONN"]],
["2020-05-31 14:14:33 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","OK"]],
["2020-05-31 14:37:17 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","NCONN"]],
["2020-05-31 14:37:24 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","OK"]],
["2020-05-31 14:44:17 +0200",10,2,0,"Connection of module intAddr:%s devType:%s changed to %s",["HIDDEN","ZWAVE_HAE_METER_v2","NCONN"]]
["2020-05-31 20:00:07 +0200",99,4,0,"%s",["HAE_METER_v2 CRC ERROR data:
["2020-05-31 10:19:51 +0200",93,1,0,"%s",["First test gave error rate of 0, stop the rest and give full marks"]],
["2020-05-31 10:19:51 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=53533 nhv=10"]],
["2020-05-31 10:19:51 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 10"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=266478 nhv=1"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=67986 nhv=1"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=68794 nhv=2"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=49 NO_ACK=1 ERROR=0 AVGTIME=83144 nhv=2"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=31974 nhv=3"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=75170 nhv=3"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=77521 nhv=4"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=100758 nhv=6"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=48 NO_ACK=2 ERROR=0 AVGTIME=92985 nhv=8"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=42 NO_ACK=8 ERROR=0 AVGTIME=100949 nhv=8"]],
["2020-05-31 12:20:36 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 8"]],
["2020-05-31 14:20:13 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=287785 nhv=1"]],
["2020-05-31 14:20:13 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=39 NO_ACK=11 ERROR=0 AVGTIME=184448 nhv=1"]],
["2020-05-31 14:20:13 +0200",93,1,0,"%s",["HealthValue Device HAE_METER_v2 intAddr 9 value 1"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:0rnd:[1/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=118737 nhv=1"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:1rnd:[2/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=25159 nhv=1"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:2rnd:[3/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37335 nhv=2"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:3rnd:[4/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=53176 nhv=2"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:4rnd:[5/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=58335 nhv=3"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:5rnd:[6/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37356 nhv=3"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:6rnd:[7/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=37141 nhv=4"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:7rnd:[8/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=61345 nhv=6"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:8rnd:[9/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=59168 nhv=8"]],
["2020-05-31 16:20:18 +0200",93,1,0,"%s",["RESULT: plv:9rnd:[10/10] SENT=50 ACK=50 NO_ACK=0 ERROR=0 AVGTIME=77384 nhv=10"]],
["2020-05-31 13:09:42 +0200",98,1,0,"%s",["MeterAdapter restarted uuid=NUMBER1 nodeID=9"]],
["2020-05-31 13:09:52 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:11:27 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:17:15 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:24:36 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
["2020-05-31 13:25:10 +0200",98,2,0,"invalidDevice c:device i:NUMBER2"],
Very strange why it's showing "invalidDevice" since I only have one meteradapter bound to Toon.
Re: Firmware 5.28.9
Post by TheHogNL »
Try to 'remove all meteradapters'' in the advanced meter adapter configuration screen and then re-add it.
Timeless
Re: Firmware 5.28.9
Post by Timeless »
Ok, going to give that a try.
Does that reset the homeID of Open-Zwave so instead of nodeID=9 it will become nodeID=1 again?
It's still strange that it mentions a invalidDevice while there is only one meter-adapter plugged in.
And, does Toon trigger this restart or did the meter-adapter somehow crash?
Return to “Toon Firmware”
