Toon app: Afvalwijzer
Re: Toon app: Afvalwijzer
Postby Toonz » Thu Sep 24, 2020 4:05 pm
TwentseExperience wrote:Goede dag ik heb vraag hoe werkt de afal agenda ik heb mijn adres toe gevoegt alles blijft wit niks komt te voorschijn wat doe ik fout
Welk bedrijf haalt het afval op in jouw woonplaats (je kan me ook een PM sturen met je postcode)?
Postby Martijne » Mon Sep 28, 2020 6:55 pm
Toonz wrote:
Martijne wrote:I'm having issues with the afvalwijzer app for area-afval.nl (my region). I have configured 'Afvalverwerker' number 25 and set my 'Postcode' and 'Huisnummer'.
I have dowloaded the .ics file from https://www.area-afval.nl/ and saved it on my Toon as /root/waste/waste_calendar.ics.
This results are shown in the pictures below. The dates are correct, but no info about the type of waste. Can this be fixed?
can you PM me your zipcode?
Did you receive my zipcode via PM? Still can't get it working after reconfiguring :roll:
Martijne
Postby Toonz » Mon Sep 28, 2020 9:40 pm
missed it, was in between another bunch of pm's. Will have a look now....
Postby Toonz » Mon Sep 28, 2020 9:52 pm
This file contains alarm settings as well, next to the normal calendar events , which is the first time ever I see this.
This is mixing up the logic for the other gemeentes a bit.
Will see if I can change the app to cope with this without too much changes
Postby Toonz » Mon Sep 28, 2020 10:56 pm
version 4.46 is available in the ToonStore with a fix for area-afval.nl for Hoogeveen.
I hope this didn't screw up the other gemeentes supported by area-afval.nl.
No need to update for other users.
Postby Martijne » Wed Sep 30, 2020 11:08 am
Toonz wrote:Hi all,
Great, it works perfect for me now! Many thanks.
Martijne
Postby djgodlike » Sun Oct 11, 2020 12:23 am
It seems like afvalwijzer-arnhem.nl have been changed into inzamelwijzer.suez.nl. When I choose afvalververwerker 13 with postcode and number it stays blank..
djgodlike
Postby Isheara » Mon Oct 12, 2020 11:59 pm
Thanks for this great app. Unfortunately code 21 (Leeuwarden) also provides wrong information
Isheara
Postby TerrorSource » Tue Oct 13, 2020 9:06 am
Isheara wrote:Thanks for this great app. Unfortunately code 21 (Leeuwarden) also provides wrong information
djgodlike wrote:It seems like afvalwijzer-arnhem.nl have been changed into inzamelwijzer.suez.nl. When I choose afvalververwerker 13 with postcode and number it stays blank..
To both, please PM your zipcode + housenumber to me so i can check
TerrorSource
Postby Toonz » Tue Oct 13, 2020 9:42 am
suez.nl can be easily integrated, will try to do this week.
Postby Toonz » Tue Oct 13, 2020 10:30 pm
For provider Omrin you will need to download the data manually (html file) and copy to your toon as /root/waste/omrin.htm
Typically once a year or as often as the schedule changes. Did you do this recently?
Postby Toonz » Tue Oct 13, 2020 10:39 pm
version 4.47 is published in the ToonStore for our clients in Arnhem. The waste provider is changed from arnhem.nl to suez.nl.
Provider stays "13" but instead of your zipcode/housenr you will have to put your ical number in the config screen on Toon.
You can get your ical number on your PC by:
1. go to https://inzamelwijzer.suez.nl/
2. login with your zipcode/housenr
3. press "Maand en Jaar kalender"
4. press "Zet inzameldata in agenda"
5. your ical number is the last part of the url under "Synchroniseren"
Postby frank-pda » Wed Oct 14, 2020 7:00 am
:D To Toonz, it works like crazy.
Now I can sit back and my wife and kids can take the dirt out again :lol: :lol:
frank-pda
Postby Isheara » Wed Oct 14, 2020 9:28 pm
Where do I find the html file? Sorry for my ignorance.
Can I just upload the file via the browser interface to the IP address?
Isheara
Postby Toonz » Wed Oct 14, 2020 11:51 pm
Isheara wrote:Where do I find the html file? Sorry for my ignorance.
On your PC goto to omrin.nl with the Internet Explorer (No Chrome).
Login with your zipcode/housenr
Goto the 'AfvalKalender'
Save the page as 'webpage complete' on your PC.
Copy(and rename) that file to toon as /root/waste/omrin.htm (using winscp or another ssh client of your choice)
I will have a look when I have time to remove this step and collect the data from Toon directly (no ETA).
PreviousNext
Return to Toon Apps
