Toon App: Water
oepi-loepi
Re: Toon App: Water
Post by oepi-loepi »
Edgar wrote:I have put an USB (male-female) extension cable and that works. The only problem I still have is the right positioning of the sensor :D
I will send you a pm.
oepi-loepi
Re: Toon App: Water
New version 1.2.0:
different way to send data to domoticz, better webportal with info screen, fixe for back button on update screen, differtent AutoConnectAp, Logo and many other small fixes.
let op het betreft een freeware uitgave, software is niet bestemd voor verkoop
free release can be found here:
github.com/oepi-loepi/water_ESP_part/re ... 1_mini.bin
Krisrock
Re: Toon App: Water
Post by Krisrock »
oepi-loepi wrote:New version 1.2.0:
https://github.com/oepi-loepi/water_ESP ... 1_mini.bin
can this update be done via the update button?
in the online environment
Bruce the boss
Re: Toon App: Water
Post by Bruce the boss »
Ik zie de update nog niet terug in de Toonstore. Kan dat even duren?
I don't see the update in the Toonstore. Does this take some days?
Verstuurd vanaf mijn SM-G950F met Tapatalk
Jasper
Re: Toon App: Water
Post by Jasper »
Bruce the boss wrote:Ik zie de update nog niet terug in de Toonstore. Kan dat even duren?
Probably is the wemos firmware not the Toon app because that doesn't send it to domoticz
oepi-loepi
Re: Toon App: Water
Indeed this is the wemos firmware. To update:
Use the online update function (download the .bin and use the update button on the wemos webpage)
OR
Reflash the wemos using usb cable.
Arnout2000
Re: Toon App: Water
Post by Arnout2000 »
After updating to the new Wemos firmware, the network settings have disappeared.
Wemos now has a wrong IP address (192.168.10.137) whereas my LAN has 192.168.2.X.
What is the quickest way to re-enter the right network settings? I cannot access Wemos via the network...
I flashed the unit again via cable connection, but no AutoConnectAP.
After flashing first with the blank_4MB file and then the ToonWater it works.
I cannot remember I lost the network settings during the previous update...
Tebogo
Re: Toon App: Water
Post by Tebogo »
oepi-loepi wrote:
Tebogo wrote:By the way, found a "bug" in the portal, version 1.1.11
When you go to "update" and than choose "terug" you get the following: "http://10.187.1.121/%22//%22"
Ok, i will check that.
Problem solved, was a defect cable…
oepi-loepi
Re: Toon App: Water
Arnout2000 wrote:After updating to the new Wemos firmware, the network settings have disappeared.
Let me do a quick check...... i tried a couple of times to update the firmware but they were all without problems. I even tried updating from 1.1.10 to 1.2.0 . I could not get to the same errors. Anyone else expriencing update errors? Please let me know the old firmware version.
Tebogo
Re: Toon App: Water
Post by Tebogo »
oepi-loepi wrote:Indeed this is the wemos firmware. To update:
OR
Trying to update from 1.1.11 to 1.2.0 via de update function.
Selected the downloaded bin, ToonWater2_version_1.2.0.ino.d1_mini.bin, but the update button does not response.
I'll try tomorrow to do a refresh...
oepi-loepi
Re: Toon App: Water
OR
Please give the upload some time. It wil take ab. 20 seconds for the upload.
mogwai
Re: Toon App: Water
Post by mogwai »
OR
Same here. Update via the "update botton" does not work. Tried both Chrome and Edge browser.
Edgar
Re: Toon App: Water
Post by Edgar »
I had the same, but I haven't checked the IP address and flashed it new, the 4 MB blank was necessary. I came from version 1.1.10
oepi-loepi
Re: Toon App: Water
I understand now. Some new parameters are stored in flash memory. The cannot be found in the old firmware. Simply because they are not there. If you cannot reach the wemos with usb cable do not update. Also for updating you first have to flash the empty 4mb to fully clear the flash memory.
Arnout2000
Re: Toon App: Water
oepi-loepi wrote:I understand now. Some new parameters are stored in flash memory. The cannot be found in the old firmware. Simply because they are not there. If you cannot reach the wemos with usb cable do not update. Also for updating you first have to flash the empty 4mb to fully clear the flash memory.
Thanks. That explains my experience.
Keep up the good work!
