After upgrading my (rooted) toon to version 5.43.2 lighttpd is not starting and remote (mobile) access is not working anymore.
After some digging and manually starting the lighttpd:
/usr/sbin/lighttpd -D -m /usr/lib/lighttpd -f /qmf/etc/lighttpd/lighttpd.conf
2021-05-27 21:14:56: (/home/jenkins/workspace/oe/build-qmf-snapshot/oe/build/tmp/work/cortexa9hf-vfp-neon-angelica-linux-gnueabi/lighttpd/1.4.35-r6/lighttpd-1.4.35/src/configfile.c.957) source: /qmf/etc/lighttpd/lighttpd.conf line: 54 pos: 2 parser failed somehow near here: }
/qmf/etc/lighttpd# diff lighttpd.conf lighttpd.conf.lastversion
--- lighttpd.conf
+++ lighttpd.conf.lastversion
@@ -46,6 +46,14 @@
server.document-root = "/qmf/www"
+$HTTP["remoteip"] !~ "localhost|127.0.0.1|192.168.2.139" {
+ $HTTP["url"] =~ "^/happ_thermstat/" {
+ url.access-deny = ( #"" )
+ "" => "application/json",
## where to send error-messages to
server.errorlog = "/tmp/lighttpd_error.log"
@@ -111,7 +119,8 @@
".tbz" => "application/x-bzip-compressed-tar",
".tar.bz2" => "application/x-bzip-compressed-tar",
# default mime type
- "" => "application/octet-stream",
+ #"" => "application/octet-stream",
# Use the "Content-Type" extended attribute to obtain mime type if possible
After replacing the old version everything started correctly.
