Yep 4.10.6 is the first next mandatory firmware. The script will force it for you if you try any higher.Smiggel wrote:I run version 3.3.8 right now. What Would be the best version to upgrade to from here? 4.10.6?
Toon firmware - update script
it worked like a charm;
From 4.9.* to 4.10.* to 4.15.*
Only minor issue; Dastics and Rotating Tile; aren't TOONStore apps.
And you need to manual reactivated those.
Add 'dashticz' to the array of 'appsToLoad' in '/HCBv2/qml/qb/base/Globals.qml'
The rotating tiles is a mod of the standard homescreen app. I have not yet applied the mod to the 4.15.6 firmware. Will do after the holidays......(or do it yourselves
Worked like a charm here too! Upgraded to 4.10.6 and then to the latest available version without much of an issue. SSH still works - I am happy!
I have pressed the factory recovery?
And now he asks to activate.
I have read that <wizzardDone> and <Activated> on 1 in
Folder: /HCBv2/config or /mnt/data/qmf/config
File: config_happ_scsync.xml must be set.
I have manual seen in viewtopic. ...971#p83254
But with me there is a lot different: /mnt/data/qmf/config# config_happ_scsync.xml
How can I solve this
I have the toon with Version: 2.0 - ThehogNL - 24-3-2018 upgrade from version 2.9.26 upgrade to 4.10.6. Update failled / Bus error
OPKG Do Not Work / Bus error / orange screen with 2 points.
What can I do
What can I do
Trying to understand your question Jumperone but failing to do so.
You are in the correct file. Just modify it to reflect the settings which has been talked about in the forum many times.
@TheHogNL
I download the latest update script and when I starten I received this message where I need to enter yes or no.
Is it okay to say yes? or is this an old script because this message: Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)
Version: 2.85 - ThehogNL - 25-4-2018
You are currently running version 4.13.7
Available versions: 1.9.10 2.1.0 2.2.24 2.3.17 2.3.29 2.3.36 2.4.12 2.5.11 2.5.14 2.5.18 2.6.24 2.6.33 2.8.16 2.8.21 2.9.15 2.9.26 3.0.29 3.0.32 3.1.22 3.2.14 3.2.18 3.2.21 3.3.8 3.4.4 3.5.4 3.6.3 3.7.8 3.7.9 4.3.20 4.4.21 4.7.23 4.8.25 4.9.23 4.10.6 4.11.6 4.12.0 4.13.6 4.13.7 4.15.2 4.15.6
Which version do you want to upgrade to?
4.15.6
Alright, I will try to upgrade to 4.15.6
Warning: upgrade script from source server is changed. Do you want to continue downloading the files (if not sure, type no and report in the forums)?
They changed their update script again. I just checked it for any problems regarding upgrading on a rooted toon but it is still ok.
I just updated the rooting update script with the new md5sum so when you use the new script (2.86) from the github it will not complain anymore.
Super, this time it works very smoothly no issues at, it did also all the fixes.
The only thing what is strange for me is that it shows in the menu connected with service center I never had that before.
How do I now that it is not connected with the service center? I checked
and I see #ovpn: is with #
So I think this is fine? and it is not connected with the service center?
/etc/inittab
That's the magic fixing part of the script in the end
It changes the notification bar to hide the service center error messages and changes the internet settings app to fake a connection to the service center. These are mods which are somewhere in the forum but not in the general how-to-root-guide.
If you have the # in the inittab file in front of the openvpn you can rest asure that the connection is not really there.
is it needed to have VPN access to Eneco?
If you want to update using this script, yes.maomanna wrote:is it needed to have VPN access to Eneco?
- Administrator
This script enabled the VPN for updating so if VPN is disabled it will the temporarily enabled for the update.marcelr wrote:If you want to update using this script, yes.maomanna wrote:is it needed to have VPN access to Eneco?
is there an other way? Quby deleted my vpn keys when they root my Toon.marcelr wrote:If you want to update using this script, yes.maomanna wrote:is it needed to have VPN access to Eneco?
I think you were warned that this would happen...
