Toon app: ToonStore
aabre
Re: Toon app: ToonStore
Post by aabre »
@TheHogNL
Yes update via your scriptfrom , Version: 2.5 from 4.13 to 4.15 and yes the refresh button was empty but also the (+) buttons
aabre
Post by aabre »
Sorry TheHogNl I used update script 1.8 instead of last version, that is maybe the problem
aabre
Post by aabre »
@TheHogNl
I reinstall traffic app with opkg install --force-reinstall fileinfo_1.0.6-r0_qb2.ipk and traffic app is working again and now my (+) buttons are back again in the Toonstore.
Refresh button is still blanc
aabre wrote:Refresh button is still blanc
Refresh button isn't showing because Quby renamed the refresh icon from refresh.png to refresh.svg from 4.15 onwards. However, the refresh button is working as expected.
If you want the icon back right now please change line 121 in ToonstoreScreen.qml into:
 			iconSource: "../../images/refresh.svg"
or wait for the next release.....
Kind regardz,
newwolf
Post by newwolf »
Hey, I was that clever to allready update to 4.16.8
Toonstore "Bijwerken" wasn't working so I thought to reinstall it.
NoGo :(
This is what I get in the console:
opkg install --force-reinstall --force-depends toonstore_1.1.4-r0_qb2.ipk
No packages removed.
Installing toonstore (1.1.4-r0) to root...
Executing pre-install script for toonstore-1.1.4
Previous installation detected.
Creating backup for /qmf/etc/qmf_release.xml ...
Patching /qmf/etc/qmf_release.xml for 403-forbidden error ...
Restarting http server ...
killall: lighttpd: no process killed
Collected errors:
* pkg_run_script: package "toonstore" preinst script returned status 1.
* preinst_configure: Aborting installation of toonstore.
* opkg_install_cmd: Cannot install package toonstore.
Could you please help me or maybe there has to be something fixed in the ipk.
Thanks
Need to check compatibility with 4.16.8 of the toonstore installation ipk. Stay tuned.
RDNZL
Post by RDNZL »
Is it possible to get toonstore working with toon 4.18.8?
It doesn't seem to show up after install/reboot.
At least I need the boilervalues.txt functionality, is it possible to install this separate or any other way?
# opkg install toonstore_1.1.4-r0_qb2.ipk
New installation of toonstore.
Backing up public keyring ...
Backing up /etc/hosts ...
Editing /etc/hosts to enable toonstore ...
hcb_config process ID now: 776
Restarting hcb_config ...
Waiting for 3 seconds ...
hcb_config process ID now: 2820
Configuring toonstore.
Executing post-install script for toonstore-1.1.4 ...
Writing app version number to /HCBv2/qml/apps/toonstore-1.1.4/version.txt ...
grep: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Adding toonstore to Globals.qml ...
sed: /HCBv2/qml/qb/base/Globals.qml: No such file or directory
Adding toonstore key to public keyring ...
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-1.1.4
Posting message ...
Oh, by the way, your toon cannot receive updates from the ServiceCenter anymore ...
Regards, Ron.
TerrorSource
Post by TerrorSource »
RDNZL wrote:Is it possible to get toonstore working with toon 4.18.8?
No, not at the moment.
4.18.8 is new, released last week.
Some time is needed to adjust the ToonStore for the new firmware.
RDNZL
Post by RDNZL »
I was a bit to enthusiastic to update, I know...
If I can help let me know.
Regards, Ron.
Post by TheHogNL »
A new resource file is just published http://files.domoticaforum.eu/uploads/T ... 4.18.8.zip
This is however without the wase collection mod (so no big waste collection icon in the homescreen near to the temperature)
I made a new version of the ToonStore available which can install on firmwares 4.16.8 and higher.
ToonStore itself is not changed, so no need to upgrade for existing users.
You can find the ipk here : files.domoticaforum.eu/uploads/Toon/app ... r0_qb2.ipk
Kind regardz,
RDNZL
Post by RDNZL »
I have installed toonstore 1.1.5 on my 4.18.8 toon without errors, but it isn't visible in the gui anywhere.
Do i need to install the resources file as well? If so how/where?
Install log:
# opkg install toonstore_1.1.5-r0_qb2.ipk
Upgrading toonstore on root from 1.1.4-r0 to 1.1.5-r0...
Executing pre-install script for toonstore-1.1.5
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/lang/lang_nl_NL.qm.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/Changelog.txt.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreScreen.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/bad_small.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/edit.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/toonstore.js.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/version.txt.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreMenu.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/qmldir.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreApp.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreDelegateChangelog.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreSettings.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/icon_arrowRight.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreThreeStateButton.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreDelegateGalleryPopup.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreSimpleList.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreDelegate.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/icon_arrowLeft.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/minus.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/DialogCross.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/ToonstoreTray.qml.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/repo.png.
Removing obsolete file /HCBv2/qml/apps/toonstore-1.1.4/drawables/plus.png.
Executing post-install script for toonstore-1.1.5 ...
Writing app version number to /HCBv2/qml/apps/toonstore-1.1.5/version.txt ...
Adding toonstore key to opkg keyring ...
OK
This is a Toon QB2
No settings to be restored
Removing stale link /HCBv2/qml/apps/toonstore ...
Creating symbolic link /HCBv2/qml/apps/toonstore to /HCBv2/qml/apps/toonstore-1.1.5
Posting message ...
Regards, Ron.
Post by TheHogNL »
RDNZL wrote:I have installed toonstore 1.1.5 on my 4.18.8 toon without errors, but it isn't visible in the gui anywhere.
Yes. See viewtopic.php?f=96&t=12071
RomMon
Post by RomMon »
On my Toon I get a message that an update is available (Nog meer Toon er is een softwware-update beschikbaar).
I have the ToonStore installed. I thought with ToonStore installed an update is not possible?
If I look in ToonStore I get '0 Apps in de ToonStore'.
/mnt/data/update does also show _opkg.qb2-ene-4.19.10.script.sh and a number of .ipk files dated 6-Sep 06:1x
I'm currently on 4.10.6, and no direct plans to upgrade.
Any suggestion to prevent an update, and get ToonStore working again?
Firmware updates via ToonStore don't work (yet) anyway.
Sometimes the list of apps cannot be retrieved from this forum's server. If you press the refresh button you can force the catalogue to be read again (otherwise once a day automatically)
