Toon app: Afvalwijzer
Xavier
Re: Toon app: Afvalwijzer
Post by Xavier »
michel30 wrote: Fri Aug 08, 2025 2:48 pm Hi,
Yes this link https://data.rd4.nl/api/v1/waste-calend ... &year=2025 works for me as well with my postcode and housenumber.
The only question is where must I add this script in? or is this something that Toonz needs to planned in?
The app is maintained by Toonz, I guess he would like to have a good look to the code, if everything is complete and works like he designed.
The app will be updatet in the ToonStore then by Toonz.
If you don't want to wait, you can modify the code by yourself by logging in Putty and replace the old code for garbage pickup number 17 by the new code. If you don't have any experience in coding, or Putty, etc. then please wait for the update in ToonStore.
michel30
Post by michel30 »
Thanks, this code is also working for me
Xavier wrote: Fri Aug 08, 2025 12:40 am This new code below works at my side.
Main difference, data is now based on JSON API.
This URL format provides data:
Adjusted code below
//<provider>17</provider><version>1.0.2</version><parms>"zipcode,housenr"</parms>
//provider rd4info testdata:6444GL 10
//provider rd4info via officiële JSON API
function readCalendar(wasteZipcode, wasteHouseNr, extraDates, enableCreateICS, wasteICSId, wasteStreet, wasteStreetName, wasteCity, wasteFullICSUrl) {
	var wasteDatesString = "";
	var cureAfvalbeheerDates = [];
	var xmlhttp = new XMLHttpRequest();
	var year = new Date().getFullYear();
	xmlhttp.onreadystatechange = function () {
		if (xmlhttp.readyState === XMLHttpRequest.DONE) {
			if (xmlhttp.status === 200) {
				var json = JSON.parse(xmlhttp.responseText);
				if (json.success && json.data && json.data.items && json.data.items.length > 0) {
					var afvalItems = json.data.items[0]; // data.items is een array met 1 object waarin dates zitten
					for (var i = 0; i < afvalItems.length; i++) {
						var date = afvalItems[i].date; // formaat: yyyy-mm-dd
						var type = afvalItems[i].type; // bv: residual_waste
						var wasteType = wasteTypeRd4api(type);
						if (wasteType !== "?") {
							cureAfvalbeheerDates.push(date + "," + wasteType);
					var tmp = sortArray2(cureAfvalbeheerDates, extraDates);
					for (var i = 0; i < tmp.length; i++) {
						wasteDatesString = wasteDatesString + tmp[i] + "\n";
					writeWasteDates(wasteDatesString, enableCreateICS);
			} else {
				updateWasteIcon("error");
	var url = "https://data.rd4.nl/api/v1/waste-calendar?postal_code=" + encodeURIComponent(wasteZipcode) + "&house_number=" + wasteHouseNr + "&house_number_extension=&year=" + year;
	xmlhttp.open("GET", url, true);
	xmlhttp.send();
function wasteTypeRd4api(apiType) {
	switch (apiType) {
		case "gft": return 3;               // Groente/fruit/tuinafval
		case "residual_waste": return 0;   // Restafval
		case "pmd": return 1;              // Plastic/Metaal/Drankkartons
		case "paper": return 2;            // Papier
		case "pruning_waste": return 4;    // Snoeiafval
		case "christmas_trees": return "#";// Kerstbomen
		case "best_bag": return "!";       // BEST-tas
		default: return "?";               // Onbekend type
function sortArray2(inputarray, extraDates) {
	var newArray = inputarray.concat(extraDates);
	newArray.sort();
	return newArray;
function writeWasteDates(wasteDatesString, enableCreateICS) {
	var doc2 = new XMLHttpRequest();
	doc2.open("PUT", "file:///var/volatile/tmp/wasteDates.txt");
	doc2.onreadystatechange = function () {
		if (doc2.readyState === 4) {
			if (doc2.status === 0) {
				updateWasteIcon("no");
	doc2.send(wasteDatesString);
	if (enableCreateICS) {
		var outputICS = "";
		var tmpICS = wasteDatesString.split("\n");
		for (var i = 0; i < tmpICS.length; i++) {
			if (tmpICS[i].length > 10) {
				outputICS += "BEGIN:VEVENT\r\n";
				outputICS += "DTSTART;VALUE=DATE:" + tmpICS[i].substring(0, 4) + tmpICS[i].substring(5, 7) + tmpICS[i].substring(8, 10) + "\r\n";
				outputICS += "SUMMARY:" + wasteTypeFriendlyName(tmpICS[i].substring(11, 12)) + "\r\n";
				outputICS += "END:VEVENT\r\n";
		var doc3 = new XMLHttpRequest();
		doc3.open("PUT", "file:///var/volatile/tmp/wasteDates.ics");
		doc3.send(outputICS);
function wasteTypeFriendlyName(typeChar) {
	switch (typeChar) {
		case "0": return "Restafval";
		case "1": return "PMD-afval";
		case "2": return "Papier";
		case "3": return "GFT";
		case "4": return "Snoeiafval";
		case "#": return "Kerstboom";
		case "!": return "BEST-tas";
		default: return "Onbekend";
