Page 10 of 86
Posted: Sun Oct 22, 2017 10:56 am
by michel30
Hello toonz,
Could you also make something for the RD4? What you did for the Rova?
https://www.rd4info.nl/NSI/Burger/Aspx/ ... &nr=141&t=
or do I only need to save the page and it works?
Thanks,
Posted: Sun Oct 22, 2017 11:06 am
by Toonz
The approach will work. However, the format is completely different from all others, is a little bit more work to implement (needs a bit of coding).
Will be the next one to implement (not sure if it will make the next release which I plan to release Monday or Tuesday).
Posted: Sun Oct 22, 2017 2:07 pm
by jnieuw
Toonz wrote:
Not so easy. The dates are not returned in plain html but retrieved from the server via function calls. Cannot be handled by Toon unfortunately.
Found the direct link:
https://vpn-wec-api.recyclemanager.nl/v ... number=129
Can this help?
Posted: Sun Oct 22, 2017 7:41 pm
by Toonz
Nice catch, works even via http so can be handled via Toon directly. How did you find this out of curiosity?
Posted: Sun Oct 22, 2017 8:35 pm
by globegrabber
Hello Fellow Members,
Currently is was looking to install the waste app on my rooted Toon, unfortunately the ZRD,(Zeeuwse reiniginsdienst) is'nt supported now i was trying to do this by Recyclemanager.nl/afalkalender/4587ER/25 but so i understand this wouldn't work also, so i hope it can be possible our postcode/ housenr. 4587ER can be implicated with the post of
https://vpn-wec-api.recyclemanager.nl/v ... &number=25.
Thumbs up guys
grz. Johnny
Posted: Mon Oct 23, 2017 9:49 pm
by jnieuw
Did it by following/reading the functions and code.
Posted: Mon Oct 23, 2017 10:02 pm
by Toonz
new version 2.4 available in the ToonStore.
Changelog:
- new, much better looking icons for everyone (Thanks to Vibestar)
- added provider rova.nl (On your PC visit the Rova website, enter your zipcode/housenr and save the page with your waste collection data as "ROVA Afvalkalender.htm.
Copy this file to Toon as "/root/waste/ROVA Afvalkalender.htm". On Toon select waste provider 14.
You need to repeat this every year around Dec/Jan when the new collection dates for the new year is shown.
- added provider afvalwijzer-arnhem.nl (waste provider 13, just enter zipcode and housenr in the configscreen)
Next release will contain support for rd4info.nl and recyclemanager.nl (in test already, looks fine)
Regardz,
Posted: Tue Oct 24, 2017 2:47 pm
by flamingbob
Hi Toonz,
Epic work. Love all this new stuff for the Toon.
For a lot of towns here near amsterdam we have this site:
https://afvalkalender.meerlanden.nl/
It can produce nice ICS based output but still fighting to see if it can be app based where you just post in a postcode and number. Seems its mostly ajax based and just need to get a hang of it.
EG this link procudes a nice output:
https://afvalkalender.meerlanden.nl/ica ... 0018940731
that is with 1433WE 62,
notice the integer for Ical does change when changing numbers at the end. Any chance to get the meerlanden also intergrated?
Thx
Bob
Posted: Tue Oct 24, 2017 9:19 pm
by Toonz
flamingbob wrote:Hi Toonz,
Thx
Bob
Yep, no problem. Will be in version 2.5 (already tested successfully)
You will need to use the wget method posted earlier to retrieve the file via the last link on Toon because it is https (see the manuals topic)
Posted: Tue Oct 24, 2017 10:22 pm
by Toonz
testing rd4info.nl as well as last new provider for version 2.5.
I noticed it has a unique waste collection called BEST-tas (
https://www.rd4.nl/inwoners/algemeen/co ... n/best-tas)
I am showing this now as 'Textiel'. If anyone feels inspired to develop an waste icon for this type of waste , feel free to do so .
Posted: Tue Oct 24, 2017 11:17 pm
by Toonz
I believe the new waste providers are implemented correctly now: recyclemanager.nl, meerlanden.nl and rd4info.nl.
I just need to finalize the helpscreens etc and create the new ipk for ToonStore.
I also want to do a write-up of the required config for each provider.
You can expect the new version 2.5 in Toonstore around the weekend
Posted: Wed Oct 25, 2017 8:23 am
by jnieuw
Toonz wrote:I believe the new waste providers are implemented correctly now: recyclemanager.nl, meerlanden.nl and rd4info.nl.
Thanks for all the hard work!
Posted: Wed Oct 25, 2017 10:19 am
by flamingbob
Toonz wrote:flamingbob wrote:Hi Toonz,
Thx
Bob
Awesome. Yesterday tested some nasty coding to 2.4. Using Cure (3) it works but seem to have a problem seeing the good GFT code.
On the bright side it does work indeed.
Seems cure and all the other based ones are comming from here:
https://www.afvalinfo.nl/
Was searching a lot for it and seems they are the ones who build that ics based platform.
Keep up the good work!
Posted: Wed Oct 25, 2017 1:48 pm
by Toonz
True, but there is a huge inconsistency between different companies in the population of data in the ics files unfortunately. This one was easy.
Posted: Thu Oct 26, 2017 11:26 am
by flamingbob
Understandable. Maybe its an idea to have the user set the codes for the trash. That is mostly differant between companies. I can also look to see where the ICS is diffefferant also. Should be still some sort the same as it is a standard. Time to get more familiair with this type of coding.
