Switch updates wrong device?
Re: Switch updates wrong device?
Hmm that`s strange i only seen this issue with a specific firmware version and all the units holding that version. Did you add the second node after a longer period of time (using other Z-Wave inteface software version)
This week i added two additional dual relay modules in an new room (Fibaro Application Version 2.2)
Bijkeuken Fibaro Application Version 19 - Working Fine
Overloop Fibaro Application Version 21 - Working Fine
Douche Fibaro Application Version 19 - Issue with updating the correct button
This issue started after adding the two nodes, so something in the Z-Wave stack is generating this issues?
I have to Fibaro FGS-222 one V2-1 and one V2-2
Now they work both ok.
I had to remove "Assoiciation Group 3" to let it show the status ok in the web interface when controled local
I hope it helps for you to
HS4 Windows 10 Pro
All version are now working fine in my setup and it seems to have something to do with a rescan and adding devices (which also killed two switches completely so i needed to re-add them to the stick to get them working
