Page 2 of 2
Re: Toon 2 hardware.
Posted: Sun Aug 26, 2018 11:49 pm
by marcelr
If you decide to get one and open it up, be REALLY REALLY careful. It's easily irreparably broken.
Posted: Tue Sep 18, 2018 11:53 am
by Rudolf
I think the off-white rim around the screens edges was a bad design choice. In the picture without it Toon looks so much better.
Pleasantly supprised with Zigbee though.
Posted: Tue Sep 18, 2018 12:12 pm
by Toonz
Rudolf wrote:I think the off-white rim around the screens edges was a bad design choice. In the picture without it Toon looks so much better.
Although Zigbee is not used yet....
Posted: Tue Sep 18, 2018 2:18 pm
by TerrorSource
Really curious what Quby will do with the Zigbee sensor though.
As far as i know (and Quby told us during the meeting at their office). The Zigbee-LL and Zigbee-HA protocols are/will be both enabled.
Posted: Tue Sep 17, 2019 8:56 pm
by Daniel
What kind of tools for opening the toon have you used?
I bought a secondhand toon2 but someone bent the power connector ,the both pins are almost broken.
Maybe I can open the toon and resolder de pins.
Posted: Tue Sep 17, 2019 9:27 pm
by marcelr
Plastic prying tools. You can lift the clips holding the screen inside the housing, with very narrow prying tools (<3mm wide). When facing the screen, the clips at 9 and 12 hours can be lifted the easiest, the other four are inaccessible with a prying tool.
Posted: Thu Sep 19, 2019 7:33 pm
by Daniel
WoW respect for you!
I stopped trying to opening it. I am afraid to brake the screen.
But I fixed it whit a needle solder iron. The Toon is alive again.
Seller told me he checked the pins before shipping! Yeah right!
Posted: Thu Oct 24, 2019 9:11 am
by TheHogNL
Check this patent from Quby how they manage to keep their temperatue management 'correctly'. Gives also another inside of the inners of the toon2:
https://patentimages.storage.googleapis ... 9936B1.pdf
En ook deze over de, nog niet geactiveerde, aanwezigheidssensor via geluidsgolven:
https://patentimages.storage.googleapis ... 9934B1.pdf
Posted: Sun Jun 12, 2022 12:42 pm
by ikookmaar
Hi.
Does anyone know how to open the Toon2 boiler module and reach the circuit board?
I'm affraid I used to much force while connecting the wires from the module to the Boiler and the conector has come loose.
I would like to resolder it.
If that's (really) too tricky, can anyone tell me where I can get a new boiler module?
Thanks!
Posted: Sun Jun 12, 2022 3:08 pm
by oepi-loepi
It is clicked together, not glued.
Posted: Mon Jun 13, 2022 10:19 pm
by TheHogNL
Indeed. You might need to give some force to open it and it will not look pretty afterwards. But just pry it open with a flat screwdriver.
Posted: Tue Jun 14, 2022 11:40 pm
by ikookmaar
Ik couldn't get it off/ out. The lid is glued to the terminal blocks.
But I "fixed" the losse contact by shoving a flat piece of metal in between the terminal block and the circuit board.
Posted: Sat Feb 22, 2025 5:43 pm
by jvdlinde
Toon boiler module ,
i have NO voltage on the toon side
on de boiler side the voltage is oke
is thare someone who can help.
I have opening the boiler module making the midle hole bigger
best regards
Posted: Mon Feb 24, 2025 11:19 pm
by aabre
jvdlinde wrote: ↑Sat Feb 22, 2025 5:43 pm
best regards
Or the power adapter is defective (24 volt AC) or your boiler unit, try to by is on Markplaats or buy a complete Toon 1 set
