/etc/init.d/chronyd restartMyZ wrote:How do I restart chrony?
Toon's clock is 2 minutes behind
Re: Toon's clock is 2 minutes behind
Thnx. Did some restarts, but didn't had any effect. I'm getting these messages after rebooting:
ep 6 17:58:44 eneco-001-209949 daemon.info chronyd[1299]: chronyd version 1.27 starting
Sep 6 17:58:45 eneco-001-209949 daemon.info chronyd[1299]: Linux kernel major=2 minor=6 patch=36
Sep 6 17:58:45 eneco-001-209949 daemon.info chronyd[1299]: hz=100 shift_hz=7 freq_scale=1.00000000 nominal_tick=10000 slew_delta_tick=833 max_tick_bias=1000 shift_pll=2
Sep 6 17:58:45 eneco-001-209949 daemon.err chronyd[1299]: Could not open IPv6 NTP socket : Address family not supported by protocol
Sep 6 17:58:45 eneco-001-209949 daemon.err chronyd[1299]: Could not open IPv6 command socket : Address family not supported by protocol
Sep 6 17:58:45 eneco-001-209949 daemon.info chronyd[1299]: Frequency 6.556 +/- 1.712 ppm read from /var/lib/chrony/chrony.drift
Sep 6 17:58:49 eneco-001-209949 daemon.warn chronyd[1299]: No intersecting endpoints found
You are not describing your issue
only posting a good logfile
problem = topicname
To be more exact, it's 3 minutes behind
And did you also modify your chrony config as said earlier?
Not yet, first I went the "easy way" as you described:
Will modify the file with the other time server.Just restart chrony a few times and it will create the necessary files for it to sync properly
Changed the server to:
In sync now!
server 0.nl.pool.ntp.org 8
That restart was necessary to fix the errors shown in the log (after the change to the pool.ntp.org servers)
Ah! It makes all sense now
