DS2423 going crazy
Posted: Fri Sep 08, 2006 12:22 pm
Robert,
The 741 opamp is a very good amplifier that is best driven by a dual powersupply, +5, 0, -5. However a single supply 0, +5 is also possible. But it depends on the use. Used with a single supply in some cases you have to take precautions to get the output nice in the middle for AC use and need to use a capacitor to stop the DC current flow through the output. But that is not the case here, we use this amplifier for DC switching and amplifying.
I use the LM324 because this opamp is designed for a single powersupply and can switch from 0 to almost 5V when driven by a single 5V supply. There are 4 opamps in this case so when you need a buffer amplifier just use 'm.
Still the signals you get from the 741 looks very good, so maybe it is not as worse as it looks. If you made a serious mistake the 741 would have explode [:D]
Draw the schema again and publish it.
What do you use as busmaster for the DS2423? Check if this busmaster has already the pull-up resitor on the 1-wire bus line. This resistor 1k5 .. 5k is important. The devices which pull down the line must get enough sink current otherwise you get strange results.
Marcel
Marcel
