Toon 2 questions
If you don't know where to post, post here.
Re: Toon 2 questions
Not sure, will check tonight.
HansS
Post by HansS »
Great, thanks. Also, the vnc package is not for the Toon 2 architecture. I updated a previous post, but people might not have noticed that. There must be a package for Toon 2, since some of you are already using vnc to look at the Toon 2 screen ;)
here you go...… just for viewing, controlling the screen is not possible
http://files.domoticaforum.eu/uploads/T ... p-neon.ipk
HansS
Post by HansS »
Thanks guys. Have cron back up and running, so my Grafana dashboard is working again. Toon 2 is much less cpu intensive, and has a lot more free memory.
Tried to install vnc, but it seems I miss some dependencies:
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for x11vnc:
* libcrypto1.0.2 (>= 1.0.2p) * libssl1.0.2 (>= 1.0.2p) *
I know that I should be able to get them using vpn, from some feed address, but I guess the url's and versions are different for the fw I'm running? If you can point me in the right direction, or provide the packages, would be greatly appreciated ;)
HansS
Post by HansS »
Thanks. But I need different ones I'm affraid:
"Not selecting libcrypto1.0.2 1.0.2p due to incompatible architecture."
Are there Toon 2 versions?
moved to the right architecture subdir:
http://files.domoticaforum.eu/index.php ... ipk/armv5e
(probably means that these are for toon 1 ;-) )
Will check for cortexa9hf-vfp-neon versions.
Edit: Done.
http://files.domoticaforum.eu/index.php ... f-vfp-neon
WickedMaster
Post by WickedMaster »
09/04/2019 12:02:54 x11vnc version: 0.9.13 lastmod: 2011-08-10 pid: 1174
09/04/2019 12:02:54 This x11vnc was built without X11 support (-rawfb only).
09/04/2019 12:02:54
09/04/2019 12:02:54 *** XOpenDisplay failed. No -display or DISPLAY.
09/04/2019 12:02:54 *** Trying ":0" in 4 seconds. Press Ctrl-C to abort.
09/04/2019 12:02:54 *** 1 2 3 4
09/04/2019 12:02:58 This x11vnc was built without X11 support (-rawfb only).
09/04/2019 12:02:58
09/04/2019 12:02:58 ***************************************
09/04/2019 12:02:58 *** XOpenDisplay failed (:0)
Any suggestions?
Is this x11vnc for toon1? That version uses a framebuffer device which is slightly different from toon2's framebuffer dev. Incompatible, I'm afraid ...
WickedMaster
Installed the x11vnc_0.9.13-r3_cortexa9hf-vfp-neon.ipk file from files.domoticaforum.eu/index.php?cam=/T ... f-vfp-neon
I think that's quby's own. Not sure if it's any good, apparently not ...
Post by TheHogNL »
Currently x11vnc isn't working on a toon2
You can get the display to work (you just need to point to the correct framebuffer device) however the touch isn't working. X11vnc doesn't support multitouch and the toon only responds to multitouch (also a single touch is recorded as a multitouch response) messages.
There is a method to 'rewrite' single touch message to multitouch messages and let x11vnc use that as a input/filter/driver. I did try that once but due to lack of knowledge I could get it to work.
(to start it: x11vnc -rawfb map:/dev/fb0@1024x600x32 )
WickedMaster wrote:Installed the x11vnc_0.9.13-r3_cortexa9hf-vfp-neon.ipk file from files.domoticaforum.eu/index.php?cam=/T ... f-vfp-neon
On a Toon 2 start with (viewing only):
x11vnc -forever -shared -rawfb map:/dev/fb0@1024x600x32 -usepw -pipeinput UINPUT:touch,touch_always=1,abs,pressure=128,direct_abs=/dev/input/event0,direct_btn=/dev/input/event0,direct_rel=/dev/input/event0,direct_key=/dev/input/event0,nouinput
Rtbravo
Post by Rtbravo »
Thanks for all the info here, got vnc running on Toon 2 using it.
One thing i was missing here, but is crucial, add port 5900 to the iptables config, else you wont be able to connect.
Other question, someone made a pull request for the vnc lib to allow multitouch support. It is not merged yet, but if i can compile the vnc x11vnc package, i can apply the patch too. Was wondering is someone knows how the package was build?
Patch is here https://github.com/LibVNC/x11vnc/pull/218
Return to “Toon miscellaneous”
