Page 2 of 2
CM15A vs CTX35
Posted: Wed Dec 03, 2008 12:16 pm
by drmacchi
Hi All, today i received my CTX35, i used starting trick for HS by Chak (THANKS!) and setted simply speed at 19200. It works perfectly! (let's hope for future too....) My damn CM11A serial/usb is going to be sold out!
CM15A vs CTX35
Posted: Wed Dec 03, 2008 1:05 pm
by Noel
drmacchi,what starting trick for HS is this?
CM15A vs CTX35
Posted: Wed Dec 03, 2008 2:07 pm
by drmacchi
simply to add a "fake start" of ctx35 in HS file startup.txt, i add :
hs.ExecX10 "A10", "off", 0, 0
CM15A vs CTX35
Posted: Tue Dec 09, 2008 3:42 pm
by Paul H te O
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by MindBender</i>
<br />Andro, Does the problem still show if you type commands to the CTX directly, using TeraTerm (or Hyperterm, if you have to)? The CTX offers the great advantage of a human-readable protocol, unlike the CM11. just download the manual and start typing away!
Be careful with these USB-to-serial converter: They have given me a head ache too. Including the one built-into the PMIX35.
<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">MindBender, what do you think is a good USB to serial converter for the CTX35 and Vista. Regards Paul.
CM15A vs CTX35
Posted: Tue Dec 09, 2008 11:32 pm
by drmacchi
Paul, why usb? mine works perfectly on a notebook without serial ports, i'm using a serial server connect to lan. USB in this situation means problems!
CM15A vs CTX35
Posted: Wed Dec 10, 2008 9:17 pm
by Paul H te O
Hi drmacchi, I didn't know that that was possible serial to lan. thanks for the tip.
CM15A vs CTX35
Posted: Thu Dec 11, 2008 12:24 am
by drmacchi
Paul, You're welcome. you can find many post in this forum about serial servers. I was very interested about this one from ANTRATEK (NL)
http://www.antratek.com/Sollae.html
EZL-200F Ethernet-RS232 converter (in housing) 69,00 .
But then i bought TIBBO
http://www.tibbo.com/ , because i found it in Italy. tibbo is really an allround product with tons of settings
cheers, Lorenzo.
CM15A vs CTX35
Posted: Sun May 24, 2009 9:53 am
by Andro
Sorry for kicking this one again, but I have found the problem.
Today I did an upgrade of the homeseer drivers and after that my CM15 seized to work. So I pulled out the CTX again. And again the same error that some appliances cannot be reached. This time I have found what kind of switches can't be reached namely the x-10 lamp modules (plug in socket). The appliance modules can be reached no problem, but apparently the CTX interface (driver) has a problem with lamp modules. So I replaced them and all works fine now
CM15A vs CTX35
Posted: Sun May 24, 2009 11:53 am
by Edwin2008
thanks for presenting the solution
CM15A vs CTX35
Posted: Mon May 25, 2009 10:08 am
by RDNZL
Funny to read about problems with CTX35 and USB serial converters on windows.
It works fine and 100% reliable using a USB-serial cable on my Linux box this way.
So I think it should be no issue on Windows.
CM15A vs CTX35
Posted: Thu May 28, 2009 12:54 pm
by Andro
I don't think it has anything to do with the serial-usb converter. Somehow the CTX doesn't work correctly with marmitek light switches and only the light switches. If I put an appliance switch in exactly the same socket the signal is received, but if I use a light switch the signal doesn't get converted. They both receive the same X10 signal (e.g. A1 ON).
My guess is that the CTX sends out a slightly different X10 signal which is interpreted correctly by the appliance switch and not by the light switch. Maybe the light switch expects a different signal or the appliance switch is less picky. Another option is that Xanura's A10 protocol is not completely compatible with X10 and there are differences.
