The Bwired electricity monitor
- Willem4ever
- Global Moderator
It could be localization kicking in ... but check your query as Pieter suggested (that's what i always do) and examen the output. Be advised that NOW() includes the time component as well.
seems that my problem was the Count field, i was storing them devided by 250 (250 counts pr Kwh) so the results in the sql fiels alwas included a " , ", mysql dosen seem to like that
all is looking good now.
i am not very good at this sql stuff, so can somone help me out with a quary that does "consumtion pr hour for the last 24 hours", and one that does "consumption pr min. for the last 60 minutes" ? would be of great help for me
heres the one that does consumption pr day for the last 30 days :
strSQL = "SELECT Date, sum(Count), DAYNAME(Date) FROM energi_monitor GROUP BY Date ORDER BY Date DESC LIMIT 30"
Thanks for all the help
Morten
Morten
- Willem4ever
- Global Moderator
Hi Morten,
In order to do that you should have a field with minutes and hours ...
Willem.
Willem.
Yup, i have that, it's stored in a field called Time that is setup as Time
Morten
Morten
- Willem4ever
- Global Moderator
ok, can you dump your database and mail it to me (willem4ever at yahoo dot co dot uk). I'll see what i can do for you. (results will be posted) I have some experience, but i'll have to do a little bit of playing to get it right.
Hi Spawn,
As I told you before I create one record for every hour and update it every minute. So for one day I have 24 records added in my database.
Here is my select for a graph which shows the energy usages per hour in the Bwired house.
strSQL = "SELECT dayhour, wattage/1000 FROM energy ORDER BY id DESC LIMIT 24"
As you can see it's very simple
Regards Pieter
Regards Pieter
Do you reset the counter every minute after storing the countervalue in the mysql database?Keep in mind that the 1-Wire TAI8585 only can count to 65535 before it resets to zero. As there are 480 flashes in 1 KWh the pulse counter will reset after counting 136KWh. I read the 1-Wire once every minute and store about 60 readings in one hour.
I am using velleman 8055 usb board that have double counter and the max value is 65535. (Have 1000 flashes/KWh)
http://www.velleman.be/ot/en/product/view/?id=351346
Thanks for any help.
Hi Ton,
No I'm not resetting the counter value to zero, you can handle that in your program. I read every minute the counter value also store that counter value. Once you have a starting count lets say 1.02 hour 65501 and the next count is getting at 1.03 hour 00101, the total flashes will be (65535 - 65501) + 00101 giving a total of 135 flashes as in your case 0.135 KWh.
Pieter Knuvers
Pieter Knuvers
Thanks Pieter, my brain was not with me;)
The solution was to easy...
/Tony
/Tony
Am I on right way or is there any better way to do it?
Not sure if I miss one watt when every time when the counter reset.
Dim latest As Integer = 0
Dim counter_value As Integer = 0
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Kontrollera.Tick
counter_value = TextBox1.Text '(Here should the recived value from the counter)
If counter_value < latest Then
Debug.Print((65535 - latest) + counter_value)
Else
Debug.Print(counter_value - latest)
End If
latest = counter_value
End Sub
Hi Tony,
This looks good, I don't think you are missing any count. Let it run and see!
To check you can add the counter setting of the powermeter as well and check if it runs equally.
Thanks, I will compare it later when we have moved in into that house that have this digital powermeter. I just try to make the program in advance:) Later I will make a HomeSeer Plugin. Thanks for all great idéas.
- b_weijenberg
Pieter,
You will mis 1 count;-)
It should be:
Debug.Print((65536 - latest) + counter_value)
Else
If the latest count = 0xFFFF (65535 decimal) and the counter value increments with 1 the result will be 0x0000
(65536-65535) + 0 = 1
Bert
It should be:
Else
Bert
Right Bert, everytime I forget the dawn Zero [:D]
I'm having the logging function okey now. Saving every minute.
But I have some problem to read out correct data from mysql.
I want to list hourly data of the power consume.
I am trying "SELECT Date, sum(watt)/1000, DAYNAME(Date) FROM energie GROUP BY hour(Date) asc"
It give me wrong result, wrong value and not the last days data.
Tony
Tony
