looks nice too, but basicly it comes down to this:
- scanner duplex (color too)
- one button press to scan to network share (it can be via usb, then it dumps it on a share drive, which has same effect)
- twain
- optional, pdf software for global overview (indexing all pdf's via ocr)
- allowed to be a all-in-one printer aswell, but for best result i presume it should only be a scanner only.
A lot of scanners have a button on the front, but you still need to say "ok" on the pc itself. I just want my mail scanned, so i walk in , put it in the scanner, press a button and be done with it.
Scanner + software?
Scanner + software?
Keep in mind that with the brother everything works over tcp/ip. I doubt you're able to find a duplex color tcp/ip scanner for a lower price
- Snelvuur
Scanner + software?
i allready found the cdw for 714.- euro's including taxes. i can still get the taxes back.. so it would be 600.. or maybe a bit less..
Scanner + software?
btw if you setup the firewall in the right way then it would tik some boxes like
- scanner duplex (color too) (yes)
- one button press to scan to network share (it can be via usb, then it dumps it on a share drive, which has same effect) (no need for ok on pc)
- twain (yes)
- it can be set in a way it produces pdf files
- twain (yes)
- Snelvuur
Scanner + software?
i read that it can also dump it to a ftp server.. which in my case can also be a samba share on a linux server to my windows (so in the end same result as one button press) if i understand it correctly.
Because if it sends it to ftp share, it cant really have any user input.. i think
Scanner + software?
it's just place paper on scanner and press button to scan to a pc (i'm not sure for the ftp option)
