Page 2 of 22
Bwired Googlemaps upload data webservice
Posted: Sun Mar 15, 2009 12:23 pm
by Rene
@Wifi: You need to use the vb extension for the script name
Posted: Sun Mar 15, 2009 12:27 pm
by Noel
LOL.. I've got BV :-)
I'm thinking about selling this data to the highest bidder
As long as Nieuwegein is plotted where it is right now, you won't get 1 cent [:D][:D]
Posted: Sun Mar 15, 2009 12:32 pm
by Noel
Hmmm<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> Error 1 Running script xml2bwired.vb :method not found <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
It's not my day..
Posted: Sun Mar 15, 2009 12:33 pm
by Rene
Chak is covering up his real location;-)
Posted: Sun Mar 15, 2009 12:34 pm
by Noel
this is what I have.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Imports System.IO
Imports System.Net
Imports System.Text
sub main(parms As Object)
const url = "http://www.bwired.nl/Bwiredservice/receive.asp"
const screenname="wifi"
const name="wifi"
const passwd="xxxxxxx"
const city="Almere"
const gpslat="52.364463"
const gpslong="5.068431"
const title="Home"
const temp ="[5"
dim myXML
dim xmlhttp
myXML = hs.CreateStringClass
myXML.Add("<?xml version=""1.0"" encoding=""UTF-8"" ?>")
myXML.Add("<BWired>")
myXML.Add("<Init>")
myXML.Add("<DateTime>" & Now() & "</DateTime>")
myXML.Add("<UserName>" & name & "</UserName>")
myXML.Add("<Password>" & passwd & "</Password>")
myXML.Add("<ScreenName>" & screenname & "</ScreenName>")
myXML.Add("<Gpslat>" & gpslat & "</Gpslat>")
myXML.Add("<Gpslong>" & gpslong & "</Gpslong>")
myXML.Add("<City>" & city & "</City>")
myXML.Add("<Website />")
myXML.Add("<WebCamPicUrl />")
myXML.Add("<Title>" & title & "</Title>")
myXML.Add("</Init>")
myXML.Add("<Entry>")
myXML.Add("<Name>Outside Temperature</Name>")
myXML.Add("<ID>1</ID>")
myXML.Add("<Units>C</Units>")
myXML.Add("<Value>" & CStr(hs.DeviceValue(temp) / 10).Replace(",", ".") & "</Value>")
myXML.Add("</Entry>")
myXML.Add("</BWired>")
xmlhttp = WebRequest.Create(url)
xmlhttp.Method = "POST"
Dim byteArray As Byte() = Encoding.UTF8.GetBytes(myXML.Value)
xmlhttp.ContentType = "text/xml"
xmlhttp.ContentLength = byteArray.Length
Dim dataStream As Stream = xmlhttp.GetRequestStream()
dataStream.Write(byteArray, 0, byteArray.Length)
dataStream.Close()
Dim response As WebResponse = xmlhttp.GetResponse()
response.Close()
myXML.Reset
End Sub<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Posted: Sun Mar 15, 2009 12:40 pm
by Rene
@Wifi: I don't know what is causing this error, seems something to do with .Net
@Chak: You are probably using the coordinates you configured in Homeseer by choosing the Amsterdam presets.
Posted: Sun Mar 15, 2009 12:49 pm
by Droezel
Ok, I'm in. Sent a sample for authorisation.
Posted: Sun Mar 15, 2009 12:51 pm
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by wifi</i>
<br />Hmmm[quote] Error 1 Running script xml2bwired.vb :method not found <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">Chak Or Rene can you mail wifi the script, perhaps that helps, could be something in the format etc, then we can rule those things out!
Posted: Sun Mar 15, 2009 12:53 pm
by TANE
52.052846;5.093622
This what I'm using.
did change it few times to see why it was not working
Posted: Sun Mar 15, 2009 1:01 pm
We got out first foreigner (Belgium) on the data service! [:)]
Welcome Droezel!
@chak: you are all set now, Coordinates changed.
Posted: Sun Mar 15, 2009 1:45 pm
by Noel
Okay.
I redid the script, and it looks like I've got it working (no clue why it did not work 1st)
So.. You should see some stuff comig in from me'. At the moment only one device, but I will be adding more later.
Posted: Sun Mar 15, 2009 1:48 pm
Works, saw you coming in!
I authorized you, so if you send again you are on the map (close to Rene :-))
Posted: Sun Mar 15, 2009 1:51 pm
by Noel
Data is on it's way.
Re: close to Rene.
Yes I (we) know. Just as well that I have a netfilter :-)
Posted: Sun Mar 15, 2009 1:55 pm
Welcome Wifi, you're there :-)
