Page 2 of 7
Report Bugs Plugwise Beta Source April 2009
Posted: Tue Apr 21, 2009 10:26 pm
by Reinder
backup of the current system.
And maybe also a backup from before the beta.
Posted: Tue Apr 21, 2009 11:08 pm
by Rene
I opened the database to find out the 'old appliance', that was missing was still in there preventing the new appliance from being named the same. So I removed the 'old appliance' and then started the Source again. Finally I was able to rename the new appliance.
Posted: Wed Apr 22, 2009 7:11 pm
by jheerink
What i hoped would be fixed, but is not, the possibility to edit the plug after installation. You can edit the name,but not the rest of the info. Deleting it, then adding again did not work good either because then it says Name already in use, (the name you just deleted, and then you can only add it under an other name. (and can not select device type/room etc.)
And on my monitor the (older TFT) the multi day grapihs for usage are hard to read, thin lines and the color of the line (greyyish) are hard to see, I would prefer a slightly thicker line and darker color
Posted: Wed Apr 22, 2009 7:13 pm
by Reinder
Strange, deleting and adding again should work. Maybe bug?
Posted: Wed Apr 22, 2009 10:05 pm
by Reinder
Is someone working with the schedules?
If so, have you tested this with the new beta?
Posted: Thu Apr 23, 2009 12:20 am
by jcasteel
The display with the consumed energy is working correctly now since it is now reported to the correct date (previously is was (current day + 1)
At the other hand it is very difficult to know when a schedule has been transmitted and is available in the plugs.
It would make sense to me to show the progress on what plugs already have the schedule information and witch dont in "breadcrum style" or a progress bar or something.
Also if you delete a schedule, is it also deleted from the plugs? Or do you need to send the schedules to delete them?
Jan
Posted: Thu Apr 23, 2009 8:04 am
by jheerink
And what is nice, i didn,t see on the older software is the Red Sign on the device which tells you if there's a double schedule on it.
And the mentioning earlier of the hard to see schedules Iin my previous post)was monitor related it is solved. Scheduling seems to work ok on the beta. I will check today if the chedules did waht they are supposed to do by checking the ussage logs of the plugs (30+ installed)
Posted: Thu Apr 23, 2009 11:45 pm
by Reinder
@jcasteel, thanks for the tip. I'm afraid not for this beta/update but sure for a update later on (new functionality).
@jheerink, please keep us informed. I heard some doubts about the reliability of the schedules in the beta.
Posted: Fri Apr 24, 2009 1:09 am
by jcasteel
Opening the Help at the 'Schedule' page will try to access the internet with the following link
http://www.plugwise.com/source/manual/u ... V2_enl.pdf but the document does not exist :-(
Posted: Fri Apr 24, 2009 5:48 pm
by jheerink
Schedules seem to work so far.
question (i did not see it before) What does a green "vinkje" mean on an appliance ? I,ve seen it only once now in this beta. The red exclamation mark (bedoel uitroepteken) works ok signaling a problem with a schedule)
Am i correct that it is not possible to cancel schedules of a whole group and then add an new one ?
We went (school)into holiday mode and i wanted to make a holiday schedule signaling all schedules to go to off, but that creates a double schedule. For the time i changed all my schedules to empty and sent them off that works, after the holiday i will reprogram them again. I will check next week if the schedules do as told.
Posted: Sat Apr 25, 2009 10:16 am
by Reinder
@jcasteel
user manual is not ready yet. After pdf posterd, "bug" should be solved
@jheerink
The green "vinkje" you describe I only now from within "schedules" and that means there are no conflicting schedules.
You can cancel a group, just left mouse click the group (within schedules) and choose del. Please keep us posted about the schedules. I am very interested.
Posted: Sat Apr 25, 2009 10:21 am
by Reinder
New beta update ready!
version 20090424.0
When you are a beta user, you can update your version, using the update button.
The full beta setup can be downloaded from www.myplugwise.com/source/pwsetup_beta.exe
Changes:
- Language selection dialog in update installer.
- Added Preparation page to Configuration Wizard.
- New switching schedules are filled with 'On' by default.
Fixes since beta 20080415.1
- #82 Update wizard crashes when update has multiple files.
- #76 Peak/Offpeak calculations during weekends
- #68 Last 3 days of 2008 are shown as week 53 instead weak 1 of 2009 (Dutch week numbering)
- #67 Configuration wizard does not use the language as selected during setup.
- #64 Country list in Usage Data and Personal Info forms are empty when Windows phone/modem setting are not set.
- #62 Cannot add new tariffs
- #63 Savings report incorrect when selecting a group or room
- #60 Webserver: Appliance.TypeText and Appliance.Module cause error
Posted: Sat Apr 25, 2009 11:48 am
by Rene
The upgrade procedure looks far better now and it doesn't crash anylonger as it did before. However, the Appliance.Module.TypeText stull returns an object instead of a string describing the type of module.
Posted: Sat Apr 25, 2009 12:28 pm
by jcasteel
I played around with some tarif stuff and found the following issue.
It is now possible to create new tariff plans but it is possible that they are active at the same time.
As a consequence it can be confusing what costs are presented in the graphs.
I would expect that you can have the following
|--- Tarif 1 (Active) ---|
| --- Tarif 2 (Active) ---|
|--- comparison tarif X (non active) --------------|
|--- comparison tarif Y (non active) ---------|
but not something like
|--- tarif X (active) --------------|
|--- tarif Y (active) --------------|
Posted: Sat Apr 25, 2009 1:05 pm
by jcasteel
I played around with the groups :-)
And I can add a group if I click on Add Group however if I perform GRoups -> Right Click -> New then nothing happens
