Page 2 of 4
Stealth product sheet.
Posted: Wed Apr 22, 2009 10:09 pm
by Reinder
Please when builing the Stealth in (by example a wall rails) that you don't mount it in a metal construction, this won't work (Faraday Cage).
Posted: Wed Apr 22, 2009 11:19 pm
by jcasteel
Luckly you mention it since I was planning to order 10 modules but the electricity board is completely from metal. So it will clearly not work in my case :-(
damn
Posted: Thu Apr 23, 2009 11:00 pm
by jheerink
I,am awaiting the price quote of my supplier, but we figured it out already that building in the metal wallrail would probably not work We will now use a plastic box in the supply line to the rails. This should work since it,s also rather close to an other plugwise connection . We.ll keep you posted on the progress.
Posted: Sat Apr 25, 2009 12:33 pm
by jcasteel
Hmmm strange
I did put a cirlce as test in my electricty board and to my surprise it was working.
I could connect to the circle+ and enable/disable it.
However the case is completly in metal/aluminum.
I will add a picture soon but does this mean that the stealth plug might work?
Posted: Fri May 01, 2009 9:23 pm
by SNG
hmmm this 'Stealth plug' can then also be used in other countries with other plug systems?
I am from one side very interested into the Plugwise but I don't have the Dutch powerplug in my house...
Posted: Mon May 04, 2009 8:41 pm
by Reinder
Yes you can.
It is working from 100-250V en 50 or 60Hz. The accuracy will be little bit less with 100V, because the modules are calibrates at 230V.
Posted: Tue May 05, 2009 9:53 am
by jheerink
We have a request out for a set of stealth's (10) (via official installation service) for over 2 weeks now,but no word yet, we have to wait for the price quote, which we still not have before we can order. We hoped we would get them in time to install during the school holiday but that will be a problem now, holiday ends friday, as soon as we have it we will install it and start reproting it's performance.
Posted: Wed May 06, 2009 6:04 pm
by Post-IT
I have asked my electrician for a quote on a set of 10 of these also. Let's hope they are cheaper then SAIX modules :-)
Posted: Wed May 06, 2009 8:15 pm
by Chiel
Maybe a dumb question, but why is the stealth (a minimalised circle!) more expensive than a circle?
Posted: Thu May 07, 2009 10:20 am
by DJF3
Good question... Maybe because the volume of devices is a lot lower than the regular Circles? Technically I would think they could be cheaper, but I don't know the details...
Posted: Thu May 07, 2009 2:28 pm
by Post-IT
I just got a message from my electrician. A set of 10 stealths would cost around 475,- EUR excl. VAT/BTW (excl, the base set). The problem however is the size, they warned me they would probably not fit behind a power socket, and it would most likely need a whole socket with blindplate. So it seems the stealths not the perfect solution for built-in plugwise implementations just yet.
Plugwise did say they are working on a smaller model so it would fit behind the powersocket, and the Stealth was more aimed toward implementing in appliances such as airconditioning.
Posted: Fri May 08, 2009 10:23 am
by jheerink
My stealhs should arrive today. We will install them this weekend. A question to prevent problems later on. I noticed the conventional plugs install best if you first log them on close to the stick (within lets say 5 or 10 mtr)en then move them to their location farther away. Is this valid for the stealths as well. since when we build them in the distance will be much farther from the circle+ or stick. It will of course be in range of the network If this is better we will first have to log them on on a temp location close to stick/circle+ and after initial logging they can be build in. Is this a correct view ?
Posted: Fri May 08, 2009 1:06 pm
by Bjochems
It should not matter where you configure the plugs /stealths. As long as you make sure that the plugs are "reachable" in your network it will work. The only difference when installing the plugs close to the circle is that they will be recognized earlier.
Posted: Fri May 08, 2009 9:40 pm
by jheerink
Thanks, i,ve got the stealth here, and will install them tomorrow. I will first log them on close by, just to be sure they work and then build them in on their final location, thanks for the answer
Posted: Sat May 09, 2009 5:44 pm
by jheerink
And today we put in the first 4 (of 10) stealth. Installation was easy and the were easily identified in the plugwise network.
For more pictures:
http://hoeksteen-bussum.nl/index.php?pa ... section=23
