ZIR010 motion sensor
jakkes
Re: ZIR010 motion sensor
Post by jakkes »
Just a update.....:
In January i allready managed to get the ZIR in to the motion detections setting.
Now, a half year later the battery was empty......, and i had to re config the ZIR010, and forgot how i dit it....
This is how i got it working this time:\
I downloaded the Danfoss software.
With Homeseer shut down, and the danfoss software in the advanced mode, go to configuration tab.
Here you will be able to send the parameters to the ZIR010....
It will probably queue the command, but be patient....
Uriel
Post by Uriel »
I don't know if you have solved the problems yet with the "unknown?" status from your Zwave sensor but I have just made my first steps with Zwave and have a problem that looks like this.
My Duwi switch for my beamer screen had the same status in Homeseer also with using the Aeon labs stick. My server is in my "meterkast" at about 12 meters from the switch with another thin inner wall between it. It worked but the status stayed "unknown?"
I had tried several things but the all didn't work, I solved it by using a 3 meter usb cable and getting the Aeon stick out of my "meterkast" and nearer to the switch. The Aeonlabs stick and Homeseer recognized my switch directly and the "unknown?" status disapeared and I could set all the parameters for the device in Homeseer.
Return to “Z-Wave Forum”
