Need help with creating a Plugwise XML file
Otherwise i can also send you an older version of the setup file which does refresh the data after every hit.
Hi Lostdreamer
So we can be sure they took it out, i thought so!
The script works fine for me here, havent updated Source in the last 6 months.
Since I'm not on 50 posts yet, I can't email it to you so I uploaded it :
http://www.lostdreamer.eu/plugwise.zip
Good luck
Good luck
Thanks, can you post which version this exactly is.
thnx for taking the trouble to uploading it..
I just downloaded it but sadly when i try to install it i cant use my 2009 license key on the 2008 plugwise version
Actually, I dont know which version this is,
I believe this one is from before when they started putting their version number in it.
At least, I can't find it in any screen.
Edit: I checked the file version of the executable:
1.3.0.0
Assembly Version: 1.3.3237.31422
1.3.0.0
Also not here, it's hard to see!
BTW: Plugwise took the polling out not that long ago.....
haha, now I see it
This one is V20081110
grrr so there is no way to get this to work? ;(
I bought the plugwise kit kinda for this reason so it would suck if i couldnt use it ;(
I mailed Reinder from Plugwise and asked him to respond to this thread.
Marek which version are you using. According to Plugwise this functionality should still work. They tested it with the latest beta and according to them it still works (I am currently unable to verify this).
The plugwise source says its version v20091102.18
I've got it from the site so its prob the latest version..
Though since it also didnt work for Bwired there is prob something different in the latest version
I've also mailed plugwise but they arrnt responding
In my version it works. I have the beta V20091205.0B version.
Maybe you can send an email to helpdesk@plugwise.com and tell them you want te be a beta tester, and ask them if they want to add you to the beta users. You must provide you license key in your email.
i just mailed them regarding the Beta testing and the betatesting software.. I hope it works!!
thnx for your response!
got a mail back from plugwise and downloaded the beta software.. It did the trick!!!
It is working now so it was the latest live software that didnt support it... The beta version did so i am happy now
thnx all!
thnx all!
