Greetings,
Eric
Moderator: TheHogNL
All ok now, thanksBwired wrote:try again please....Digit wrote:Cannot upload avatar.
Fixedrklootwijk wrote:Hi Pieter,
Congratulations with the new forum. I am still finding my way around and I think it takes a while to get used to the new layout.
So far one question:
When I select the 'View active topics' in the top left corner, no topics are displayed while I expected to see the topics that received posts in the last day.
yep need to examine that first with logo's etc.Noel wrote:Are the themes gone? I do not really like the 'default' one.
you are right, did not fixed that because will solve itselfmo046 wrote:Pieter,
the "last post" column in the homepage doesn't show the correct last posts of that topic. Maybe that is also the reason that the "active topic" list is not showing any new topics.
Edit: I see the problem not only in the homepages but also in the subforums.
There where more settingsrklootwijk wrote:View active topics still does not work as I expect it to. This topic for instance is not in the list.
Solved...mhn wrote:Hi.
Looks good.
But I found a little more work for you.
I looked at one of my posts, to see if it looked right.
http://www.domoticaforum.eu/viewtopic.php?f=50&t=3629
Under Author the posts count is 0, and there are no images.
Regards
Morten
