// Ping a remote server, also uses DHCP and DNS.
// 2011-06-12 <jcw@equi4.com> http://opensource.org/licenses/mit-license.php
// $Id: pings.pde 7725 2011-06-13 14:07:56Z jcw $
#include <EtherCard.h>
// ethernet interface mac address, must be unique on the LAN
static byte mymac[] = { 0x74,0x69,0x69,0x2D,0x30,0x31 };
static byte myip[] = { 192,168,10,75 };
static byte gwip[] = {192,168,10,60 };
static byte dnsip[] = {192,168,10,10 };
byte Ethernet::buffer[700];
static uint32_t timer;
// called when a ping comes in (replies to it are automatic)
static void gotPinged (byte* ptr) {
ether.printIp(">>> ping from: ", ptr);
void setup () {
Serial.begin(57600);
Serial.println("\n[pings]");
if (ether.begin(sizeof Ethernet::buffer, mymac) == 0)
Serial.println( "Failed to access Ethernet controller");
// if (!ether.dhcpSetup())
// Serial.println("DHCP failed");
if (!ether.staticSetup(myip, gwip, dnsip))
Serial.println("IP address setup failed");
ether.printIp("IP: ", ether.myip);
ether.printIp("GW: ", ether.gwip);
ether.printIp("DNS: ", ether.dnsip);
#if 1
// use DNS to locate the IP address we want to ping
if (!ether.dnsLookup(PSTR("www.google.com")))
Serial.println("DNS failed");
#else
ether.parseIp(ether.hisip, "74.125.77.99");
#endif
ether.printIp("SRV: ", ether.hisip);
// call this to report others pinging us
ether.registerPingCallback(gotPinged);
timer = -9999999; // start timing out right away
Serial.println();
void loop () {
word len = ether.packetReceive(); // go receive new packets
word pos = ether.packetLoop(len); // respond to incoming pings
// report whenever a reply to our outgoing ping comes back
if (len > 0 && ether.packetLoopIcmpCheckReply(ether.hisip)) {
Serial.print(" ");
Serial.print((micros() - timer) * 0.001, 3);
Serial.println(" ms");
// ping a remote server once every few seconds
if (micros() - timer >= 5000000) {
ether.printIp("Pinging: ", ether.hisip);
timer = micros();
ether.clientIcmpRequest(ether.hisip);
My guess is that DHCP doesn't work. It didn't here
So I commented out the DHCP part and added static IP. Change the IP addresses (myip, gwip and dnsip) according to your local LAN!
After this small modification, I get this (open the Serial Monitor window):
[pings]
IP: 192.168.10.75
GW: 192.168.10.60
DNS: 192.168.10.10
SRV: 74.125.79.104
Pinging: 74.125.79.104
24.728 ms
24.108 ms
24.232 ms
23.900 ms
24.732 ms
24.032 ms
24.492 ms
BTW, forget about the 2nd sketch you posted. That one is for the Arduino Ethernet shield, not for the JeeLabs EtherCard.
Using a sketch for Ethernet Shield with an EtherCard is like using a ATI driver for a nVidia card
If you need example, see File > Examples > Ethercard in the Arduino IDE, don't use the File > Examples > Ethernet examples.
Tip: I would report the issue at JeeLabs, this info can be useful for JCW.
