Page 2 of 3
How to connect to lan-rfxcom with linux
Posted: Tue Nov 04, 2008 12:53 pm
by Snelvuur
have you looked at some pieces i posted on
http://wiki.binkey.nl ? some xpl documentation is there..
Posted: Tue Nov 04, 2008 8:17 pm
by francisb
Well, seems to be down.....
Posted: Wed Nov 05, 2008 12:31 am
by pvbrakel
I also use xpl-perl as a test. xpl-perl works but is not as stable as it should be. Commandline arguments missing from the help, help missing, etc. As said, a lot of work for one person.
If you want to use it, sometimes you have to look at the perl sourcecode to see whats realy going on and maybe fix a bug.
Posted: Thu Nov 06, 2008 3:46 pm
by Snelvuur
yeah my server crashed sortoff, i'am in the process of putting up a new server.. but this will take some time, have a backup and its coming along.. hopefully it should be back up end of the week.. then i'll get 500 domotica forum mails, if they didn't bounce allready..
Posted: Thu Nov 06, 2008 5:30 pm
by Pieterpaul
I agree that xpl-perl help text is often wrong (missing commandline options, using wrong options, etc) and that there are some bugs in the commandline arguments, but I wouldn't call it unstable. I have never seen one of the modules crash or something like that. I don't know much about Perl, but I have always been able to figure out the proper commandline options by looking at the code.
I do have problems getting RRD to work though - for some reason I can't get graphs from RFXMeter or RFXPower devices (they are empty). RFXSensor works perfectly. I don't know enough of RRD and Perl to be able to understand what could be wrong, but I have always been able to figure out the proper commandline options. (I don't use Zenah)
Regards, PP
Posted: Fri Nov 07, 2008 1:58 pm
by francisb
Well, i was able to get some readings from the rfxcom power en gas sensors, but getting the rrd to work is for me also a problem.
I hope someone can help us, maybe he has some howto.
You can find a lot of info but its very scattered, what a lot of (beginning) users need is a step to step howto, otherwise they giveup very soon, and think the products are crap.
Most of the time i think at it to difficult at the end it is mostly very simple
Posted: Fri Nov 07, 2008 2:34 pm
by Pieterpaul
Domotica under Linux is in my experience not really suitable for beginners, and unfortunately xpl-perl is no exception. This is of course somewhat true for Linux in general, but home automation is apparently one of the areas that are still for geeks only. Most of the open source projects are not very well designed and/or maintained and seem to die because of lack of interest after some time. Strange, as the windows tools are relatively stable and userfriendly. Maybe with growing interest in domotica things will get better.
If I find some more time I will see if I can figure out the rrd problem. In case anyone has gotten this to work, any hints are welcome!
/PP
Posted: Sun Nov 09, 2008 2:49 am
by Snelvuur
http://wiki.binkey.nl/index.php?title=Main_Page does work, but if you click on a link it says not found.. change the link name to index.php?title=<name>
Its a bit overkill but i'am leaving for the plain tomorrow so i dont have that much time, my mail is working (2000+ spam) and the files.binkey.nl of the forum is up aswell.. i'll fix it when i get back..
Posted: Wed Nov 12, 2008 8:38 pm
by francisb
Well, i think i getting the hang of it, resolved the HOSTNAME error (my server hostname was with a symbol the program could not understand (dash)).But i still can not figure out how to connect to lan.
When i use the setup i get the same error as gb1980, snelvuur answers with: "i just use the xpl-perl setup. There you can say xpl-rfxcom ip:port at startup". I do not understand what he is saying, should i alter the setup script?
regards,
Francis
Posted: Wed Nov 12, 2008 9:59 pm
by Esteban
<br /> then i'll get 500 domotica forum mails, if they didn't bounce allready..
Hehe, I was wondering why my e-mails bounced.
Posted: Wed Nov 12, 2008 11:42 pm
by Snelvuur
francisb: last time i used it, i did it like that. if i check my service:
debian:/var/service/xpl-rfxcom# cat run
#!/bin/sh
exec 2>&1
exec chpst -uxplperl:xplperl /usr/bin/xpl-rfxcom -v 192.168.1.98:10001
so you can see its started like that, xpl-rfxcom ip:port.. and then the spamming came by itself (temperature, etc, ec)
p.s. i fixed the wiki now, its normal again. Hopefully it has some information for you aswell.
Posted: Thu Nov 13, 2008 11:08 am
by francisb
He snelvuur,
Well i am probaly very stupid, but i do not have a /var/service/ so i am stuck again.
And this is not helping either:
francis@domserver:/$ sudo sv up xpl-rfxcom
[sudo] password for francis:
fail: xpl-rfxcom: unable to change to service directory: file does not exist
The search goes on.
Posted: Thu Nov 13, 2008 1:14 pm
by Snelvuur
/var/service comes from the sv service (this is a service to keep your programs up and running)
if you get that message, that usually means you changed the syntax..
if i did sv stop xpl-rfxcom , instead of sv xpl-rfxcom stop (this is just a example though) then it did work, so check the syntax really good.
Posted: Thu Nov 13, 2008 2:49 pm
by Kroonen
I'm curious if heyu should work with the lan version. I'm using heyu with rfxcom instead of xpl-perl, because x10 and oregon sensors are supported.
Posted: Thu Nov 13, 2008 4:52 pm
by Snelvuur
x10 and oregon sensors are supported by xpl-perl too as far as i know.
