The final beta (latest release candidate) is released now.
Plugwise Source 2.22 beta 20120604 (RC5)
Please report any bugs to
helpdesk@plugwise.com
Include the version number of your Source application in your report.
You can find it in the bottom right of the blue title bar.
Changes:
- PTE: Up to 80% faster handling of arrays and array elements
- PTE: See PDF for new features
Fixed
#3140 Week graph shows all 52 weeks for current year
Known issues:
- Plugwise Smile-P1 is not yet supported
- French translations not complete and outdated
Plugwise Source 2.22 beta 20120521 (RC4)
Changes:
- Updated PTE documentation.
- PTE: on a script of runtime error in a function, a more informative trace back is written.
Fixed
#3139 PTE: Arrays operators like + and - have same effect as their compound versions += resp. -=
#3125 ConfigWizard: Manually added module ids, disappear and reappear again
#3137 Reports: Scrolling and zooming the graph with mouse wheel, does not refresh graph
Plugwise Source 2.22 beta 20120504
Changes:
- New WHQL certified driver for Stick
Fixed
#3120 Changes made just before backup are not stored in backup
#3109 Manually entering SLP settings does not work
Plugwise Source 2.22 beta 20120427
Changes:
- Japanese translation update
Fixed
#3107 ConfigWizard: Crash when entering module ID
#3103 ConfigWizard: "Invalid email address" message on correct email address
Plugwise Source 2.22 beta 20120424
Changes:
- Export: production columns are always exported
- PTE: Rounding method changed to 'Nearest' (0.5-->1) instead of .NET's default 'Bankers' (0.5-->0)
Fixed
#3102 Reports: Graph not correct when using bidirectional meter with production
#3101 Export: No production for bidirectional meters
#3100 Crash at startup: 'Invalid characters'
Plugwise Source 2.22 beta 20120419
Changes:
- Export: Sense and Scan data can be exported to CSV
- Export: CSV uses Windows' default field separator. Can be overruled in Settings->Program
- Settings: Current Windows' currency is always added in currency selection list
Fixed
#3087 Reports: Comparison graphs not correct
#3078 Rooms: Creating new and then canceling still creates room
#3077 Reports: Sense and Scan graphs cannot be copied to clipboard
#3064 Tariffs: Newly added tariff, cannot be used until Source is restarted
#2969 ConfigWizard: Hang or crash on network with 40 or more modules
- Some (potential) crashes
Plugwise Source 2.22 beta 20120412
Changes:
- Modbus: Presets are read-only.
Fixed
#3068 Reports: Graph of multiple submeters, ignores 'Skip in totals' flag
#3063 Settings->Program: Feature list is continuously refreshing
- Some crashes, especially when language is set to Japanese
Plugwise Source 2.22 beta 20120409
Changes:
- Updated German translation
Fixed
#3054 Deleting a switching group does not release trigger until refresh
#3050 Comparison graphs is empty when selecting a room
#3049 PTE: Production is added to usage
#3032 Newly created group not shown
#3029 Listviews show random icon changes during the first minutes after Source has started
#3023 New appliances do not show up in Reports, unless refresh button is clicked.
#3013 Changes in appliance type not visible unless refresh button is clicked
#3010 ModuleWizard: Newly added module gets skipped in configuration page.
#2987 P1: Total produced power value not correct.
#2935 Windows XP: High peak in memory usage at start up.
Plugwise Source 2.22 beta 20120404
New:
- Pro: SLP configuration, automatic and manual. Adding port in settings.ini is no longer required.
- Pro: Modbus. Read out separate phases even when multi-phase meters are defined.
Changes:
- Pro: New Modbus meter wizard. meters and gateways are stored in db, not in xml.
- Updated Dutch manual.
Fixed
- several crashes
#3042 Reports: Graph shows only power production or only consumption
#3029 Appliances: Icons change several times the first minutes Source is running.
#3028 ConfigWiz: 'Stick found' message, but Circle+ ID box remains disabled.
#3016 Reports: Comparison graph not correct
Known issues:
Plugwise Source 2.22 beta 20120322
New:
- Reports: Right click on graph to copy image to Windows clipboard
Changes:
- Updated German en Greek translations
- Several textual changes
Fixed
- several crashes
#3000 Add Module: manually entered module ID disappears from list
#2993 Modbus: Adding new meter requires restart of Source
Plugwise Source 2.22 beta 20120317
New:
- Reports: Change period with scroll wheel: Left+Wheel = expand/shrink period, Right+Wheel = move period
- Groups and rooms can be duplicated
Fixed
#2975 MeterWizard: Add meter causes crash
#2973 Group settings: Triggers are not listed
#2967 Sense settings: Advanced settings is gone
#2965 ModuleWizard: Module list is empty
#2952 Update button results in server error message
#2855 Sense: Modules only switch on Sense broadcast if Source is running
Plugwise Source 2.22 beta 20120312
New:
- Support for climate and movement graphs in web server
Fixed
#2963 Reports: Production from main meter shifted to start of day on timeline
#2958 Reports: Production not visible
#2949 Reports: Gas usage shown as production
#2945 Crash when opening Sense properties
Plugwise Source 2.22 beta 20120301
New:
- Comparison graph in Reports screen
- Combine 2 or more meters to 1 merged (virtual) meter
- Pro: SLP auto discovery (if supported by SLP)
- Pro: SLP configuration settings, no need for INI file
- Pro: Meter wizard for ModBus devices
Changes:
- Central meters and submeters have separate branches in Reports screen
- Use of terms 'meter' and 'sensor' instead of general term 'module'
- Separate icons for Stealth(+), Circle(+) UK and Circles US(+)
Fixed
#2939 Pro: Merged modules are lost in import
#2931 Translator program does not start
#2930 Reports: From date higher than Until date causes crash
#2928 Backup misses .PLU extension
#2923 Wrong titles in comparison graph
#2917 ConfigWizard: Crash on last page when PC is offline
#2916 MeterWizard: Adding new meter type causes crash
#2915 MeterWizard: Test uses error box for success message
#2914 Stealth is named Circle in module list
#2907 Pro: Merge item in context menu is disabled
#2905 Check marking 'No personal data' pops up error message
#2900 No graph when period starts and ends in same month
#2854 Using decimals in Sense boundaries cause crash
#2833 Context menu not working in schedule list
#2821 Multiple 'Usage' titles in graph
#2777 Pro: Import ignores SED locations
