Version 0.8 almost finished
Moderator: RdP
Re: Version 0.8 almost finished
Do you plan to support multiple voicemail boxes? The 7390 supports three (and I use currently two).
Thanks!
Thanks!
Ehhmm; 0.9?
I really need to get 0.8 released, it's taking too long (you're all being very patient, thanks for that...
)- adding multiple voicemail boxes will probably add an additional 2 months and I don't want that right now, nor does the majority of the Plugin users I think. I'm working my *** off, but the fact is that too many things are screaming for my attention.
However I briefly checked my 7170 and I can create a 2nd Answering machine (didn't finish the wizard though), so with a bit of luck it can be done with my 7170 too. BTW, if all goes well I'll have a 7360 soon... yep, checked XS4All and it says my new modem is on its way!
Oh and I think I'll need a 2nd phone number to test it all; right?
Yeah that would be nice, a phone number just for testing the Plugin
Good idea, that way only my phone in the office will ring while testing.
So, the short version of the answer is: yes, if there's enough interest for it, but don't count on it this year...
Don't worry, it was just a question. Don't do it just for me
You know how happy I am with the current status of the plugin!
It would be nice to have 2 answering machines, I have 2 as well. I for private use, the other one as VM for my mobile, active on a SIP account
Bernard
Hi Robert,
Komt er al witte rook uit de schoorsteen ??
Gr,
Gr,
Toevallig heb ik vandaag een punt bereikt dat een aantal aanpassingen in mijn eigen systeem zich eerst maar weer even moeten bewijzen de komende dagen, alvorens ik weer verder ga met uitbreidingen. En voor een ander project zit ik te wachten op onderdelen. Dus het kan zomaar gebeuren dat ik morgen (wat is de weersvoorspelling?
) de Plugin zo ver af maak dat er mee getest kan worden, want zoveel is het volgens mij ook niet meer wat er nog moet gebeuren...
Digit wrote:Toevallig heb ik vandaag een punt bereikt dat een aantal aanpassingen in mijn eigen systeem zich eerst maar weer even moeten bewijzen de komende dagen, alvorens ik weer verder ga met uitbreidingen. En voor een ander project zit ik te wachten op onderdelen. Dus het kan zomaar gebeuren dat ik morgen (wat is de weersvoorspelling?) de Plugin zo ver af maak dat er mee getest kan worden, want zoveel is het volgens mij ook niet meer wat er nog moet gebeuren...
Super, zit morgen alleen thuis en het weer wordt dramatisch, dus laat maar komen
Ik sta te popelen.........
kan niet wachten....ik test het graag
greetz,
Iwan
Iwan
+1RdP wrote:Super, zit morgen alleen thuis en het weer wordt dramatisch, dus laat maar komen
hij is er druk mee bezig...verteld hij me net......dus we wachten af...
greetz,
Iwan
Iwan
Goed nieuws, vanavond komt 'ie er hoor. Wel een beetje laat denk ik, maar toch.
Maar nu eerst wat andere dingen doen, duty calls...
