Page 2 of 4
Dusk/Dawn sensor
Posted: Mon Mar 24, 2008 10:38 pm
Hi Guy's
A good Buddy of mine had a BPW85 so I installed this on the A/D input of a wireless RFXSensor (
www.rfxcom.com Order code: 60066, others will also do).
I have been testing with this settings for a while now and its working great. It's measuring light from 0 to 5 volts.
Nice thing about it that its only sending a message when the data is changed and even then it takes like max 60 seconds to send. So fluctuations are very minimal. If nothing changes every 45 minutes a heartbeat message is sended.
On 17:46 the weather became very bad (snow storm) and after that the sun came back again. At 18:30 its getting dark.
Pieter Knuvers
Dusk/Dawn sensor
Posted: Fri Jul 25, 2008 12:05 am
by Alexander
Any alternatives which are available in Dutch non-webshops?
BPW40 for example (
http://www.dil.nl/PartDetails.aspx?ProductID=BPW40), does that work?
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 12:50 am
by Alexander
I've bought the BPW85c (
http://www.okaphone.com/artikel.asp?id=460698) from a dutch webshop and used the diagram Pieter provided (checked the manual of the RFXsensor for pin details), but i don't get the right measures:
Vdd -> dq = 0,03 V (normal spot dimmed half light 2 meters below the light) +- 0,2 V (normal spot full light 2 meters below the light)
Vdd -> gnd = 9,23 V
dq -> gnd = 9,22 V (normal spot dimmed half light 2 meters below the light), 9,20 V (finger placed on the bpw85c)
The resistor is 10kOhm (
http://www.okaphone.com/artikel.asp?id=459280)
What is going wrong?
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 1:16 am
Maybe the BPW85c doesn't respond to artificial light as good as it does to real sunlight? (what's the wavelength of the light coming from your spot ???)
In other words, looking at the time you posted this and the fact you don't mention anything about voltages with real daylight shining on your BPW85c, i would do some more testing.
I would just log everything for 24 hours and see what you can conclude with those results.
Maybe i'm completely off-track, but that's what i would do if i were in your shoes.
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 10:26 am
by b_weijenberg
De gebruikte VDD is 5Volt in de RFXSensor!
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 11:27 am
by Alexander
Ja (ik zie dat ook in de resultaten van o.a. Pieter), vreemd iets dat ik toch echt deze waarden meet als ik de VDD en GND aansluitingen van de RFXSensor gebruik. Is er een manier om de waardes continue te meten achter een RFXSensor? De RFXSensor doet 1 maal een meting per minuut en sta dus iedere keer te wachten om een meting te kunnen doen.
Eveneens stopt ie na een aantal minuten om te meten (geen spanning op de VDD en geen led op de RFXSensor die brand/knippert).
DIGIT: Is een halogeen spot, zoals Bert ook gebruikte in zijn test (in ditzelfde topic) alleen dan een 25 Watt variant.
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 11:55 am
by b_weijenberg
De 9V batterijspanning wordt door een spanningsregelaar in de RFXSensor teruggebracht naar 5Volt. Als de batterij verkeerd aangesloten is dan zal de controller defect raken.
De VDD op de plaatst waar je de sensor aansluit wordt vanuit de controller geregeld. En als je daar 9V meet vrees ik het ergste.
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 12:05 pm
by Alexander
Ik was nog niet echt wakker. De waarden die ik eruit kreeg was nadat ik de 9volt batterij op de klemmen van de VDD en GND plaatsten van de externe sensor. Dit nadat ik de lage frequentie van metingen van de RFXSensor irritant begon te vinden om goed te kunnen meten. De meting duurt niet langer dan een seconden. Is dan erg lastig goed aflezen op een digitale meter.
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 10:07 pm
by Alexander
Oke ik krijg nu netjes met mijn spanningsmeter een resultaat. Tussen de DQ en GND (aangesloten op de RFXSensor) krijg ik de metingen:
- Zon schijnt op de BPW85c = 0,110 volt
- Zon schijnt op de BPW85c maar met screen ervoor = 0,228 volt
- Zon erop met een magazine ervoor gehouden = 1,335 volt
- Zojuist thuis gekomen (zon onder) = 5,002 volt
Lijkt dus te werken, alleen nu kijk ik binnen Homeseer en dan zie ik dat ik een temperatuurmeting om 19:0x had en een A/D Sensor van 1,5 Volt. De system voltage sensor geeft ie als "unknown" aan en dus geen resultaat ontvangen. Het tijdstip van 19:0x was een 1malige meting doordat ik de RFXSensor een reset gaf, daarna zijn er geen signalen meer ontvangen door de ontvanger (als ik de log mag geloven).
Wat ik wel 1malig in de logfile tot nu tegenkom is
<i>12-8-2008 19:04:40 ~!~RFXCOM~!~(processrfxsensor) Error: RFXSensor addr:32880 No end of read signal received from 1-Wire device
</i>
De RFXSensor is niet verplaatst (ontvangst moet dus mogelijk zijn).
Mijn vragen:
- Wat kan ik aan deze error doen?
- Is deze error het probleem?
- Welke type zou de V output moeten geven binnen HS? RFX A/D Sensor? of RFX System Voltage Sensor? (De A/D sensor gaf zonder de externe sensor gewoon 1,5 Volt aan na een reset te hebben gehad. Ik heb dus nu geen idee welke het resultaat zou moeten geven.)
Overigens mijn constatering dat ik maar 1malig per minuut kan meten is incorrect. Nu kon ik gewoon continue meten wat het spanningsniveau was. Met hologeen aan (terwijl het buiten donker is) gaf een verschil van een 0,5 volt. BPW85c "voelt" het dus wel.
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 10:14 pm
by b_weijenberg
start RFreceiver, druk op reset van de RFXSensor en wat zie je dan in RFreceiver?
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 11:13 pm
by Alexander
A05246330A RFXSensor Type-3, Fast sampling mode, version:10, bits=32 from SLAVE
A853454EC026 Sensor C0 type=DS2438 bits=40 from SLAVE
B061BCB6000000 noise or a 1-Wire sensor internal address bits=48 from SLAVE
20C03019CA RFXsensor[49200]T RFXSensor addr:C030 ID:49200 Temp:25,75C | 78,35F bits=32
A0C03019CA RFXsensor[49200]T RFXSensor addr:C030 ID:49200 Temp:25,75C | 78,35F bits=32 from SLAVE
20C2323EA1 RFXsensor[49714]V RFXSensor addr:C232 ID:49714 Supply Voltage:5,01 bits=32
A0C2323EA1 RFXsensor[49714]V RFXSensor addr:C232 ID:49714 Supply Voltage:5,01 bits=32 from SLAVE
20C13101EF RFXsensor[49457]Z RFXSensor addr:C131 ID:49457 RH:-21% Barometer:139hPa A/D voltage:0,15 bits=32
A0C13101EF RFXsensor[49457]Z RFXSensor addr:C131 ID:49457 RH:-21% Barometer:139hPa A/D voltage:0,15 bits=32 from SLAVE
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 11:29 pm
by Alexander
Overigens krijg ik nu geen continue resultaat te zien op mijn multimeter. Alleen eens per minuut en nu geeft ie 0,61 volt aan, maar ik zie niets verschijnen binnen RFreceiver.
Dusk/Dawn sensor
Posted: Tue Aug 12, 2008 11:36 pm
by Alexander
Temperatuur geeft ie wel netjes door.
20C03019AC RFXsensor[49200]T RFXSensor addr:C030 ID:49200 Temp:25,625C | 78,125F bits=32
A0C03019AC RFXsensor[49200]T RFXSensor addr:C030 ID:49200 Temp:25,625C | 78,125F bits=32 from SLAVE
Ook al heb ik in de vorige meting 0,61 volt gemeten. Nu gaf ie 0,857 volt aan op de multimeter, maar geen resultaat in RFreceiver.
Dusk/Dawn sensor
Posted: Wed Aug 13, 2008 6:44 am
by b_weijenberg
Ik zou alleen even met de RFXSensor werken en geen meter gebruiken. Dat heeft weinig zin want de spanning wordt er alleen even opgezet als de sensor gesampled wordt en dat is eens per minuut als je fast sampling ingesteld hebt.
Hier geeft de sensor 0,15 volt af:
Of de sensor is defect of hij staat volop in het licht. Als je de sensor afschermt en weer een reset geeft dan zou er dus iets om en nabij 5 volt aangegeven moeten worden.
Dusk/Dawn sensor
Posted: Wed Aug 13, 2008 9:43 am
by Alexander
Als ik de externe sensor niet aansluit en ik doe om de 10 seconden een reset, dan geeft de RFreceiver telkens een andere waarde aan. Is dit normaal? In homeseer zie ik altijd 15v (zonder de delimiter ingevuld te hebben).
20E111022A RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-20,24% Barometer:144hPa A/D voltage:0,17 bits=32
A0E111022A RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-20,24% Barometer:144hPa A/D voltage:0,17 bits=32 from SLAVE
20E1110167 RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-22,26% Barometer:130hPa A/D voltage:0,11 bits=32
A0E1110167 RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-22,26% Barometer:130hPa A/D voltage:0,11 bits=32 from SLAVE
20E1110383 RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-16,85% Barometer:168hPa A/D voltage:0,28 bits=32
A0E1110383 RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-16,85% Barometer:168hPa A/D voltage:0,28 bits=32 from SLAVE
20E1110284 RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-19,45% Barometer:150hPa A/D voltage:0,2 bits=32
A0E1110284 RFXsensor[57617]Z RFXSensor addr:E111 ID:57617 RH:-19,45% Barometer:150hPa A/D voltage:0,2 bits=32 from SLAVE
Waartussen meet de RFXSensor? QD & GND of VDD & QD ?
