Opentherm Gateway
wouterbaake
Re: Opentherm Gateway
Post by wouterbaake »
Check if you set up the RS232-USB link correctly: 9600 baud, 8bit, no parity.
jeroenc
Post by jeroenc »
Yep I did, with 1 stopbit.
I tried different drivers, to no avail.
I bought an USB-bub from Jeelabs, I'm still suspecting my RS232-USb converter.
vanisher wrote:Would it be possible to implement the "Openhaard" mode on the iSense?
What does "openhaard mode" mean to you? If this is some iSense feature, I don't expect the gateway would have to do anything special.
vossie wrote:The serial cable can be 150 meter max
I would not give any guarantees it will work over such a distance. I think the RS232 spec says 15 meters. That's on the very conservative side if using real RS232 drivers (with +/- 12V power supply). But with a MAX232, which has to generate +/- 12V out of 5V, I would try to limit the cable length to a few meters.
vanisher
Post by vanisher »
If you have an 'openhaard' in your living (where of course the isense is located) the rest of the house is getting colder.
With "Openhaard mode" ON the Remeha will keep burning at the level it did.
vanisher wrote:With "Openhaard mode" ON the Remeha will keep burning at the level it did.
You mention Remeha and iSense. So is this a feature of the thermostat? The part that is not clear to me is what kind of support you think you need from the gateway.
If you want the gateway to take over control of the boiler, that's not so simple. If you look at how the thermostat normally controls the boiler, you'll see that it doesn't set it to some level and leave it there. It periodically switches the heating on and off.
Maybe it would be possible to store a few parameters on the last full on/off cycle, like the amount of time the heating was off and how long it was subsequently switched on and at what level(s). Then make the gateway repeat that pattern when switched to "openhaard mode", but I don't know how well that would work. And it would require quite a bit of code and effort to implement that.
vossie
Post by vossie »
for as far as i know is the "openhaart mode" (fire place mode:) is something that the thermostat does but also with the boier it self.
reading from the manual is that when enabled the internal thermostat sensor is disabled the it starts regulating on the watertemperature of the boiler
little bit text from the manual in dutch srry
Daarbij wordt de ingebouwde ruimtevoeler, in de iSense,
uitgeschakeld. De op dat moment heersende cvwatertemperatuur
wordt nu gehandhaafd.
Als het in de overige ruimtes te koud of te warm wordt,
kunt u daar de ruimtetemperatuur verhogen of verlagen
met draaiknop C op de iSense. De cv-watertemperatuur
wordt hierdoor hoger of lager. Om in deze ruimtes de
ruimtetemperatuur verder individueel te regelen, kunt u de
radiatoren voorzien van thermostaatkranen.
vossie wrote:for as far as i know is the "openhaart mode" (fire place mode:) is something that the thermostat does but also with the boier it self.
Then I don't see why this shouldn't "just work".
vossie
Post by vossie »
not sure but i think what vanisher means is activating the function via the gateway. not sure if thats possible..
Digit wrote:Another option could be to connect a EZL70 (http://www.eztcp.com/en/products/ezl-70.php) to either the PIC or RS232 output.
http://www.domoticaforum.eu/viewtopic.php?f=23&t=8089
vanisher
Post by vanisher »
vossie wrote:not sure but i think what vanisher means is activating the function via the gateway. not sure if thats possible..
Indeed that is wat I meant to say :-)
jeroenc
Post by jeroenc »
as suspected the Conrad RS232-USB converter was the culprit.
With a Jeelabs USB-BUB everthings works like a charm!
raymonvdm
Post by raymonvdm »
jeroenc wrote:Hello,
You just made me google this link http://jeelabs.com/products/usb-bub
But did you plug the usb-bub on the OTG using the RS232 header or did you need to solder ? (Pics??)
jeroenc
Post by jeroenc »
I used these Wirejumpers to plug into the MAX232 socket (I removed the chip).
Today we had some problems on the powerline (a short dip in our case, but I also heard reports of 1.5 hours nearby), the kind where some devices power off (PC's, but not all), some reboot (Simplecortex board, ELV MAX), some just keep working (Server, NAS) and some die an hour later (switch). :(
And suddenly I started receiving those SE (Syntax Error) responses too, for about 41 minutes; they came and went automagically... :?:
I've never had those before and will probably not see them again either (until the next powerline problem...?)
Strange?
