Special discount for Forum members on Plugwise.
Tiz
Re: Special discount for Forum members on Plugwise.
Post by Tiz »
Then I would definitely contact Plugwise about this because I believe that they do want this to work. If you fill in an imaginary discount code you explicitly get a message that it is not valid. Maybe this is a bug introduced when they changed the site. Good luck with that.
Mathijs
Post by Harry »
after 4 a 5 tries i got it, order is out .
what can it be hard to spent money,........i gese you have to be a women to make that easy :D
Wim2008
Post by Wim2008 »
At the first page from paying you have to give in the discount.
B.R. Wim :) :wink:
Post by Harry »
is there a new discount, have to expand whit two new circle's. :?:
John
Post by John »
Currently there is an discount of approx. 20% for memebers of "Vereniging Eigen Huis". The discount is valid till the 31th of August.
yjb
Post by yjb »
New discount available 20% when mentioning the code: UITBREIDING!
Valid until 18 October
RdP
20% discount on PlugWise modules
Post by RdP »
mike
Post by mike »
is the plugwise discount offer presently vailable (19 september 2010) ?
j.hoekstra
Post by j.hoekstra »
Affirmative!
Use it when checking out, at the bottom you can add UITBREIDING! after that it becomes visible at the place where you put customer data.
PietjeNL
Post by PietjeNL »
Its active till 18 oktober, like the link above says.
PietjeNL
Post by PietjeNL »
Found this on http://www.gaslicht.com/:
Direct 12% korting op de aanschaf van een Plugwise systeem
gaslicht.com/energiebesparen/plugwise/d ... fault.aspx
jheerink
Post by jheerink »
The Gaslicht code is still valid and can also be used to order other items in the online shop directly at plugwise
you can also get a further reduction on the new introduced switch which is presently "on sale"
You can order or via de Gaslicht site and use their link and then later continue to the standard plugwsie shop
or easier to use their discount ode and go strait to the plugwise store. The code is GASLICHT00ADEF
Good luck, Saved me an other €60,- on plugs and some switches
abl
Post by abl »
The discountcode of Gaslicht is not valid anymore. Does anybody know another code currently valid? I want to order the extension kit...
Niels
Post by Niels »
Try "SWITCH" for 20% discount, working until 15th of april.
abl
Post by abl »
Thanks for this discountcode. It works and I just ordered the extension set...
Return to “Plugwise Forum”
